KettenKrad
    February 2007
KettenKrad
Posted by T-rex on Monday, May 14, 2007 10:02 AM
Althought I haven't manege to submit my models to the Western canada regonal contest I didn't lost anything I did gain more, lesson about modeling and in this subjest Dragon's 1/35 german Kettenkrad half bike with a light artillery Puppchen. Work on this small kits with my firefly V should increase interest, Tiger driving me mad. What can you all tell me about germans half bikes, or even on artilery, this is my first artillery.
Here's the box
Working on: Trumpeter SU-152 (1/35) Trumpeter E-10 (1/35) Heller Somua (1/35)
"The world is your enemy, prince of a thousand enemy. And when they'll find you, they will kill you... but they will have to catch you first ''
Posted by HeavyArty on Monday, May 14, 2007 11:48 AM
Google is wonderful...took about 10 seconds...
The Püppchen ("Dolly"), a carriage-mounted rocket launcher with breechblock, fires the same 88-mm rocket that is used with the Ofenrohr. The breech prevents any flash to the rear while firing is in progress. To lower the Püppchen's silhouette, the wheels may be removed and the piece left standing on two sled-like rests. In preliminary positions the ground is dug out so that the horizontal section of the lower carriage and trail will lie below the surface. For an all-around prepared position, circular trenches with an inner radius of about 2 feet are prepared. The barrel is left just clear of cover, as is done in the case of the preliminary positions. The lower carriage is dug in and the trail wedged, so that the piece can be fired at an angle of 180 degrees. Positions are prepared in defilade or on reverse slopes, and are well camouflaged. In general, enemy doctrine governing the preparation of positions and the conduct of fire is similar to that for the Ofenrohr, except that only two projectors of the Püppchen type are considered necessary for satisfactory interlocking fire.
The maximum effective range of the Püppchen is considered to be 220 yards, although badly dispersed fire up to 275 yards is possible. For this reason the Püppchen, like the Ofenrohr, is employed in the foremost infantry positions. For added protection from artillery fire, the launcher may be detached from its carriage and removed to a shelter some distance away from the prepared position. Alternate positions are prepared only when the terrain restricts the field of fire and provides good cover for the maneuvering piece. In such terrain each position is constructed so that the Püppchen can be run in and out on wheels. Since the Püppchen is harder to conceal than the Ofenrohr, the Germans believe that it is necessary to furnish the larger weapon with antitank protection in the form of obstacles, natural or artificial, supplemented by mines. Because the Püppchen's carriage is not strong enough to stand up under motor towing at high speed, and since horse-draft sacrifices valuable time and involves the problem of replacing animal casualties, the Püppchen generally is transported on trucks and is used only in positional warfare.
[The Püppchen is a recoilless weapon firing the same ammunition as the Ofenrohr. It has no rearward flash and has a greater range than the Ofenrohr.]
The 88-mm rocket used in both the Ofenrohr and the Püppchen is heavy enough to cause ammunition-supply difficulties in battle. (A box of three rounds weighs 24 pounds.) This is why the Germans try to build up supplies in all main and alternate positions.
The same can be done for the Kettenkrad.  You can even find a
review of the Dragon kit easily and quickly.
A little research goes a long way.
    February 2007
Posted by T-rex on Tuesday, May 15, 2007 5:23 PM
At first I couldn't beleive that the puppchen is a anti-tank canon, its size is so small.
I barley started on the kettenkrad, the engine is almost done, but I'm not starting to like dragon that much, they say the engine is paint flat black, but I've never seen a engine completely black, so intead I painted it metalic grey for metal pieces. The puppchen small size makes it fast to build, sould get the canon done and painted in a week, maybe I'll put it in the tiger of firefly scene.
    February 2007
Posted by T-rex on Thursday, May 17, 2007 5:19 PM
Don't got photos of the assembley of this kit but I'm almost done on it, the Puppchen is already done, just need to paint it dark yellow with the wheels black and weather it, like the spings on the back are going to be lighty rusted.
There are no metal parts to this kit but the tracks are also diassemble.
    February 2007
Posted by T-rex on Tuesday, May 22, 2007 5:29 PM
Alright if nones answering i'll just try getting the photos of the completed puchhed and the the kettenkrad so far.
Meanwhile tell me this, is painting models with wall paint will work, which is also acrylic.
    August 2005
Posted by Phil_H on Tuesday, May 22, 2007 9:08 PM
Categorically, no. Wall paints aren't formulated to adhere to styrene. Yes, the base may be acrylic but otherwise, they are quite different. Wall paints are also much thicker than model paints and thinning to the consistency required for model painting will reduce their adhesive properties to about nil.
Now having said that, when he was much younger (he must have been 6 or 7 at the time) one of my nephews painted an Airfix Boulton Paul Defiant with white ceiling paint and declared it a "white fighter". Clown [:o)]Tongue [:P]
    February 2007
Posted by T-rex on Wednesday, May 23, 2007 5:23 PM
I don't know if it is going to work neither, but if I try only the interieur of the bike (where the engine is,) even if it doesn't then it won't matter cause its inside.
    July 2003
Posted by Dwight Ta-ala on Wednesday, May 23, 2007 5:50 PM
As advised earlier, wall paints are not recommended for styrene kits. I have tried it in my early years in modeling and it did not look good. Because it is too thick, some details will be covered and lost.
If you really intend to use wall paint, then I suggest that you try it on a piece of scrap plastic so that you will have an idea of how to handle it. But then again, I hope that you use model paints for better results.
    February 2007
Posted by T-rex on Thursday, May 24, 2007 9:33 AM
True, and paint thinner won't make it better cause wall paint isn't mixable with thinner no matter the type. What about airbrush it, airbrush reduce the quantity making it less thick, would that work.
Also lets get back to subject of the kettenkrad, this is what I want to talk about, not all and only wall paint!
Posted by HeavyArty on Thursday, May 24, 2007 9:47 AM
Wall paint won't work well through an airbrush either.   As you said, it doesn't thin well.  You can thin it with water, but it still looses its ability to adhere well.  Best bet is to stick to paints made for models.
Also lets get back to subject of the kettenkrad, this is what I want to talk about, not wall paint!
You asked about wall paint, what did you expect to get?
    February 2007
Posted by T-rex on Thursday, May 24, 2007 9:58 AM
One of the biggest problem that I mostly get when thinning acylic is getting the mixte even, to thick and the paint covers details, but too wet and is doesn't applie good and even on models, it should have the texture of 2% milk. The major advantage of wall paint is thta it is in larrge quantity, therefore if I srew up is won't be such a major problem, got the two most comon color, german grey and dark yellow, but I still use tamiya. My badger 350 can go with any acylic paint on the marcket.
And its doesn't hurt if you all any info about the kettenkrad or puchhen.
Posted by HeavyArty on Thursday, May 24, 2007 10:42 AM
It is a good little kit.  They go together well.  They will be small when finished.  What do you want to know?  Without pics, we can't comment on your build or how it is looking.  Maybe some questions from you on it would help to generate discussion as well.
I still wouldn't use wall paint for models though.
    February 2007
Posted by T-rex on Thursday, May 24, 2007 12:39 PM
I'm not going to paint it with wall paint for now, should tests it first with another more older and bad model.
Camera down, and never seen a cobination of sure a half-track and artillery before, I have made another kettenkrad, but in 1/72 and look like a dwart compare to my large scale one.
I don't know much about the kettenkrad so what about some info of it, like what was it purpose in the war? what are some battle it fought in , and maybe it could go with the tiger 1 dio.
    August 2004
Posted by Thehannaman2 on Thursday, May 24, 2007 1:39 PM
http://www.kettenkrad.com/
or
http://en.wikipedia.org/wiki/Kettenkrad
Dude, Google it or something.  These were super easy to find.
Justen
"The distance between genius and insanity is measured only by success."
Member IPMS Niagara Frontier. "The BuffCon Boys."
IPMSUSA Member 45680
Posted by Anonymous on Thursday, May 24, 2007 2:18 PM
HI
Try this site a wealth of information!  And not that you want to know but in my youth I actually got to ride on one!
http://www.kettenkrad.de/index_e.htm
 Here's a Russian front one
    February 2007
Posted by T-rex on Thursday, May 24, 2007 5:13 PM
Yes, there is alot of info of the kettenkrad on the web, but not much help in the puchhen. I couldn't find any info on my artillery book.
Posted by HeavyArty on Thursday, May 24, 2007 8:06 PM
If you Google, there is just as much on the Pupchen.  Look at my first reply to this post.
    February 2007
Posted by T-rex on Monday, May 28, 2007 11:23 AM
Alright I finally got some pictures of the kettenkrad
Sorry for the wait.
Nice one euh.
    February 2007
Posted by T-rex on Tuesday, June 5, 2007 4:28 PM
Oh forgot the figure, haven't painted him yet.
Here's a rear view of the bike, I haven't added the wheels yet.
Kettenkrad help move supplies for covoys like this one below.
Its going very good for now, and this was done by wall painting witha airbrush, tell me how you think of it.
Posted by HeavyArty on Tuesday, June 5, 2007 4:42 PM
Looks O.K.  It is thick in areas and it looks like you missed some other areas.  I would have used model paints with an airbrush on it.
Posted by T26E4 on Tuesday, June 5, 2007 5:06 PM
TRex: something to consider is that the 8.8cm Raketenwerfer Puppchen was a late war item.  Your grey Kettenkraftrad puts it mid war and before.
You mentioned that you're willing to try wall paint acrylics because you have a lot of it and if you screw up, then no waste, right?  Wall paint pigments are not ground very small.  Therefore they will always obscure details (like they SHOULD on your walls).  You're lost before you've started, IMHO.
You may have a lot of paint but you don't have unlimited models, I suppose.  Don't do it.  You've asked for advice?  Every poster has said the same.
But the learning curve can be pretty steep...  Get the Kalmbach book.  It'll help a lot.
Roy Chow
Join AMPS!
http://www.amps-armor.org
    February 2007
Posted by T-rex on Tuesday, June 5, 2007 7:06 PM
AH HA I got you, Of course I didn't really paint it with wall paint, completely. only the interieur around the engine is wall paint, I wasn't sure the color of german grey was, its almost black, so to make sure that the color was correct I paint it with tamiya german grey, it was, mixting flat black and grey was the correct color, but At the end it was cover with the tamiya german grey, so no more wall paint for models now.
Here's the Puchhen
Now that's a nice canon, any advise.
Posted by T26E4 on Tuesday, June 5, 2007 7:43 PM
hi Trex: Not officially a cannon.  The puppchen was basically a wheeled bazooka.  It was a launching tube for a HEAT warhead rocket.  The destructive power of the warhead depended on the molten jet from the warhead and not the kinetic energy of the impact nor hardness of the round.  For more info, google HEAT warheads.
Roy Chow
Join AMPS!
    November 2006
Posted by ww2modeler on Tuesday, June 5, 2007 7:49 PM
At the bottom of the puppchen where it meets the ground it looks like you didn't paint it there.
David
On the bench:
1/35 Tamiya M26 Pershing-0%
1/144 Minicraft P-38J Lightning-50%
Numerous 1/35 scale figures in various stages if completion.
    February 2007
Posted by T-rex on Wednesday, June 6, 2007 9:59 AM
The kettenkrad and the puchhen are almost complete, still need to put the tracks, wheels and weathering, but its going good. Here's both the models together.
Here's something that you would never see, a kettenkrad pulling a FLAK 38 wagon.
    February 2007
Posted by T-rex on Thursday, June 7, 2007 9:16 PM
Looks like all dragon's kits sell there track diassemble, cause just like the firefly his tracks have to be build, any advice on how to assemble them?
Here's another photo of the kettenkrad pulling the puchhend and flak wagon.
Along with all my other project.
    August 2004
Posted by Tankmaster7 on Saturday, June 9, 2007 9:15 AM
Looks like you're having fun, but I would really advise you to slow down and take your time with construction and paint. The paintwork looks sloppy in quite a few places. Try buying some decent brushes, like kolinsky sables, or use your airbrush which always provides a better finish than brushes.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    February 2007
Posted by T-rex on Sunday, June 10, 2007 11:02 PM
Just like the tigers earlies are german grey, lates are dark yellow, althougth I want to know if kettenkrad have been known to carry tiger supplie like fuel or ammo, not all of it of course but maybe carry the case at the backseat?
Posted by m1garand on Monday, June 11, 2007 7:38 AM
T-Rex,
First of all, hats off to you for trying to build your models and enjoying the hobby.
Kettenkrad (spelling?) did have trailer and I've seen some photos of it carrying jerry cans and ammo boxes.  Not sure if it did hauled any 88mm shells for tigers.  You should be able to find enough photos of it on the web.
Think about where you want to be and what you want to do in this hobby.  If you are just enjoying this hobby for your own satisfaction, then you should do whatever is pleasing you (that also includes painting your models with wall paints).  However, it seems like you are aiming to go for competitions and that will require you a lot more work, effort, time and money.
As many of us informed you (based on your comments and your request) that you should invest little time into doing some basic research of your own and invest little money into basic modeling guides and books (or if you have access to local libraries or bookstores, spend some time at these places).  I spend hours at my local library and guess what?  These public libraries have a WHOLE section dedicated to WWII subjects (as well as most conflicts).  Lots of books, photos and even magazines that are specific to WWII.
I also have Badger 350 airbrush and I've been using Tamiya paints and MM Enamels.  I thinned both of them (I use Tamiya paint thinner for Tamiya paints and Lacquer thinner for my Enamels).  I haven't had any issues with it.  If you are using arcrylic paints, don't let it sit in open too long.
Just like any other hobbies (my scuba gear set cost me about $1400, but to refill the air in the tank, annual inspection of my gear and cost of dives are even more) the cheapest and easiest part of this hobby is purchasing kits.  Everything else on top of that (books, paints, supplies, add-ons like photo etched parts, detailed sets.....) is really going to cost you an arm and a leg.  Invest a little at a time (you don't need to have fancy tools to make great looking models) and invest some time into your hobby as well.  In a long run, it will help you to move up to the next level.
    February 2007
Posted by T-rex on Monday, June 11, 2007 9:46 AM
There is nothing wrong of making the model as accurate as I can, if I want to be a great model I can't always  place any vehicules of any scale from different time, it just doesn't work that way now. Althought you are right, I should be investing in research, I've been so indepented to this website lately, sorry for the trouble.
And I'm typing a little too fast that I forgot to check my spelling.
