Russian armor color...what's more accurate???
    April 2007
Posted by SMJmodeler on Friday, December 28, 2007 8:12 PM
Having built a T34 and getting ready to build a SU122 I've been noticing how other modelers represent the colors of these tanks .  Some, including my T34, and the KV-1 on the cover of FSM Jan. '08, have a dark green (Tamiya color), while others are closer to olive drab or even a lighter green with more yellow in it.  Did Russian armor have this much variation in color?  I do try to be accurate where I can for something this important.  Can anyone help me on this?
Posted by m1garand on Friday, December 28, 2007 8:30 PM
I used to use Dark green (according to Tamiya instruction for SU85), but now I am exploring with Model Master Acrylic WWII Russian Armor Green.  Who really knows what was the true color.  There must've been so many variations due to different manufacturing plants, batches and field condition.
    April 2005
Posted by Rick Martin on Friday, December 28, 2007 8:51 PM
Hard to say what the actual color might be since we're over 60 years removed from the events in question. I used to use either Model Master or Tamiya dark green but have been leaning more toward Model Master acrylic Russian armor green. I have also used White Ensign Russian armor green and can't see much difference between it and Model Master Russian armor green. I've been building models for too many years now and generally use the "Nuclear Weapons" philosophy in painting my models. "Close enough works well for nuclear weapons, horseshoes, and model painting. In fact, if you like certain kinds of models i.e. Russian WW2 it might not hurt to use slightly different shades of color on different models. This should account for different vehicles painted at different times at different factories with paint from a variety of paint manufacturers. After 20 years in the military I learned there is nothing standard about any mililtary force. If you've found one or two colors that suit you, go ahead and use them. Rick Martin
"Whoever said the pen is mightier than the sword obviously never encountered automatic weapons" General Douglas Macarthur
Posted by T26E4 on Friday, December 28, 2007 9:11 PM
Steve Zaloga mentioned over on Missing-Lynx Allied forum that he was befuddled at the tendency for the bright green WW2 Soviet armor.  I seem to recall that there was some lack of uniformity but the bright color seems to be a modeller's fad, according to Steve Z.
Roy Chow
Join AMPS!
http://www.amps-armor.org
Posted by gjek on Friday, December 28, 2007 9:39 PM
I am also working on a T34 and would like to get close to the right shade. I used Forrest Green years ago but now? I probably use Model Masters Russian Green. What does Steven Z. say is a "bright " color? I could use some help.
Msgt USMC Ret M48, M60A1, M1A1
    May 2006
Posted by Brews on Saturday, December 29, 2007 12:24 AM
this is xtracolour's interpretation
amd with distemper
Tamiya  XF-61 dark green is too dark IMHO
    July 2003
Posted by madmike on Saturday, December 29, 2007 2:59 AM
I used Ceramcoat dark forest green and forest green for the Dragon 1:72 T-34/85 below. I have recently purchased Vallejo Russian green which appears to be the same dark shade of the ceramcoat DFG base coat I used and I look forward to trying it out on my KV-1S.
On doing some reading though, the green could conceivably be any shade.
cheers
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    April 2014
Posted by Carves on Saturday, December 29, 2007 11:01 AM
I really doubt that the Russian even ever thought of using a standart color green for their WWII tank. We have to also remember that at that time, they (the Russian) are at the loosing end, so I belive whatever green they can through to their tank is good enough.
I also remember sometime ago someone even told me that some of the Russian tanks rushed to the battle field baremetal color. If someone has photo of this, I like to see it. I want to see if their metal quicklyget rushted.
Ben
    May 2006
Posted by Brews on Saturday, December 29, 2007 11:14 AM
There was a build article in FSM in the 90s of an unpainted T-34 - driven straight into battle from the factory. It would be difficult to replicate without good quality colour photographs because, as you know, steel "blues" on heating, and armour is heat-treated steel. Also, freshly-rolled steel is covered in "scale" which is a bluish grey colour (FeO - magnetite) so it doesn't necessarily show rust all that quickly - until the steel beneath is exposed to the atmosphere, and then it will rapidly discolour in a humid atmosphere. How fast it would rust in a frozen, dry, atmosphere I couldn't guess. So, although unpainted, it would be multi-coloured bluish/dark grey with red and orange brown patches and mottles, with a bit of dark grey grease and other POL stains, and welding marks etc etc. It certainly wouldn't look like a 1950's bumper bar.
    May 2006
Posted by Brews on Saturday, December 29, 2007 11:40 AM
I might be wrong about that darker Tamiya (XF-65) colour. The inside of the hatches should be a good indication - presuming that the paint is original.
This would be the "bright green" colour:
This one is in Minsk (repainted, obviously - maybe with a "modern" colour?)
And these are in "standard" olive green ... anybody's guess as to authenticity
    December 2007
Posted by JViguers on Saturday, December 29, 2007 11:57 AM
I find Vallejo Russian Green (017) more accurate than others and I use chalk pastels to brighten the green color after adding the flat coat. Thumbs Up [tup]
On the workbench: Pegaso 90mm Templar Sergeant
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, December 29, 2007 3:00 PM
 Russian armor, well, My 2 cents [2c] it seems anything goes except the lime green. I think that color is maybe a misinterpretation of the underling green paint after a faded winter coat of white combined with fading from the sun. To me.....Russian WWII paint = low maintenance.
 I did my t34/76 in mm acrylic dark green and post-high lighted it with a mm acrylic dark green lightened with mm acrylic desert tan. I lightened the mix to my discretion. My techniques are described in your other post listed as.....
DONE!!!...almost...photos of my T34/76
You can see the results in the "testing" section of the forum under the title
  Yep, another test......
Steve
 https://i.imgur.com/LjRRaV1.png
    July 2006
Posted by Plastic_Cross on Saturday, December 29, 2007 5:12 PM
Ben
I think you hit the nail on the head Ben.
Among the other things that stand out to me is the fact that Soviet production lines continued pretty much non-stop in spite of having to physically move the tractor plants East on account of the encroaching Axis forces.  I've read interviews with factory workers describing the improvisations that occured in many aspects of construction.  Factory machines and equipment were loaded onto railcars as quickly as possible.  Tractor plants were up and running in new locations in the open air....before buildings could even be fabricated to house them.
I also find the wildly varying camo schemes employed by the Russians to be quite interesting.  I've found several Polish and Russian armor books that have great photos of outlandish paint jobs.  While the photos are black and white, the camo - particularly the winter schemes are quite evident.
I've included a few photos of recent Soviet AFVs. SU-122, SU-152 (aka KV-14), ISU-152, KV-2.   I used Tamiya acrylics in every case and typically blend and/or layer at least 5 different shades of green....so it's hard to say what the final color really is.  It's more or less greenish.
    April 2007
Posted by SMJmodeler on Saturday, December 29, 2007 5:35 PM
Thanks everyone for helping out on this one.  I was hoping to deviate from the standard Tamiya Dark Green scheme...OBVIOUSLY that is not a problem...I had no idea the color was that hit-or-miss.
SMJmodeler
    July 2003
Posted by disastermaster on Sunday, December 30, 2007 1:19 AM
 Plastic_Cross wrote:
Helpful suggestion. If you're storing those beauties in the sunshine for an extended time, Sad [:(] the paint will eventually deteriorate and discolor.
Steve
Posted by Anonymous on Sunday, December 30, 2007 2:14 AM
Steve
I think you are spot on about whitewash that is scrubbed off or wears off naturally lightening the original color of the Russian green and may account for some of the "lime" green colors that are now in favor...
One thing I don't agree with is the assumption that all things Russian were done in a helter-skelter fashion...Quite the contrary; the Russians were nothing if they weren't methodical and purposful in almost everything they did...much of this came from the huge buracracy that Communism created...in fact, someone risked the penalty of execution if they deviated from simple "orders"---like paint formulation (If you don't believe me research the story of the Russian aviation engineer who reverse-engineered the B-29's the Soviets interred during WW2...he even included battle damage repairs in his model mock-up because his orders were to build it EXACTLY like the American plane!!!)...
Much of this "haphazard way the Russians approached WW2 myth" is slowly being dispelled as more and more records are coming to light since the fall of the Russian Empire, but many myths still persist...end of rant...
    July 2003
Posted by madmike on Sunday, December 30, 2007 2:51 AM
I just wonder hoew many T3/76's and T-34/85's were truly weathered so extremely as is the fashion oft times?
Casualties among Soviet armoured formations were enormous, if information is to believed. I very much doubt that individual tanks had that amount of time to weather and have the hard worn neglected look they are shown in model form to have.
Looks good though Smile [:)]
The same argument occurs with WW2 aircraft constantly.
If you feel so inclined please check this video out showing a ditched T-34 being raised from the silt of a lake. The T-34 (in German markings) is in extremely good condition and the original green is pretty obvious.
cheers
    February 2007
Posted by Luftwoller on Sunday, December 30, 2007 6:09 AM
I recently came across this Russian site full of colour WW2 stuff. See what you reckon to these greens.
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    July 2003
Posted by disastermaster on Sunday, December 30, 2007 3:34 PM
Sigh [sigh] I sure wish they were bigger.
    February 2007
Posted by Luftwoller on Sunday, December 30, 2007 3:40 PM
Heres my source. Enjoy
http://www.wf.weltkrieg.ru/color/alger/
...Guy
    July 2003
Posted by disastermaster on Sunday, December 30, 2007 3:51 PM
Smile,Wink, & Grin [swg] I gotcha.
I was referring to the upkeep/maintenance of the paint.
Of couse, I've seen the picture of the stalingrad t-34 off to war in red primer, but then again I have read they sometimes didn't use primer. Factories without buildings....out the door, driven to the war.....  history can be confusing. Oh well.
Steve
    July 2003
Posted by disastermaster on Sunday, December 30, 2007 4:07 PM
...Guy
Excellent site.
Thumbs Up [tup] Thanks,
    Steve
    July 2006
Posted by Plastic_Cross on Sunday, December 30, 2007 4:42 PM
Steve
Thanks Steve.  Not to worry though.  That is a photo from my office.  I got laid off shortly after that photo, Boohoo [BH]  and have been unemployed for the last few months.  The models are currently residing safely at home.
The good news is that I've recently gotten a couple of interviews and my job prospects look very good for the start of the new year Party [party].
Thank you for your thoughtfullness.
Larry
    April 2007
Posted by SMJmodeler on Sunday, December 30, 2007 5:07 PM
Luftwoller,
FANTASTIC website...thanks for letting us know about itThumbs Up [tup]!!!
    May 2006
Posted by Brews on Sunday, December 30, 2007 7:26 PM
If you're at least warm and breathing, there are plenty of job opportunities in Alberta and British Columbia. The minimum age in Alberta is 12, now (still 14 in BC).
    December 2006
Posted by spaltro3 on Sunday, December 30, 2007 8:02 PM
I think you are pretty safe using a dark green/ forest green/ whatever as long as it tends towards the middle or dark shades. The prevailing opinions about US olive drab have been revised recently, so it seems reasonable that there will be variations in shade, weathering, etc. Look how long it has taken to recognize secondary shades on US armor from WW2, as well as some other camo schemes ( Reichswehr/Heer pre-war was 3 tone, not just panzer gray ).
There are several Russian modeling references that show some multi-shade schemes. There was a bright green shade used after the Revolution, it is clearly apparent on photos of Mk. V tanks, Whippets, T-18s, T-24s. I haven't seen any brighter green paint jobs from the GPW.
    July 2003
Posted by disastermaster on Sunday, December 30, 2007 11:54 PM
Steve
Larry
Big Smile [:D]Thumbs Up [tup] Good luck!
