Lindberg Douglass X3 Stiletto Review
    August 2005
Posted by Phil_H on Tuesday, November 8, 2016 7:07 AM
model make
I will be hand brushing the body with Testor's Acrylic White which should look okay.
Actually, with only two colours and a sharp demarcation line (in other words, easily masked), I think it's a perfect candidate for airbrush practice.
    December 2011
Posted by model make on Tuesday, November 8, 2016 7:58 AM
Phil
I'm still finishing 1/32 model car and hand painting is the way to go for
that. Lots of small surfaces.
Maybe when I'm done and take a new look at airplane kit
spraying may look better to me.
I'm not in a hurry to get it finished.
Thanks!
    April 2005
Posted by T_Terrific on Tuesday, November 8, 2016 9:38 AM
OK, a word of caution about acrylics.
Both my Sparrowhawk and Stuka were hand-brushed with water-based acrylics.
This is because the typical airbrush is designed for typical enamels, lacquers, etc. I have lost perfectly good airbrushes to the fact the acrylics can form a permant hard-coating inside the airbrush, messing up the precision internals, that cannot be flushed out with any kind of cleaner, once it sets up.
Now the acrylics can be just as hard on bristle-brushes, but since you can get them by the package-full for a lot less then the cost of the typical airbrush/compressor combination at Hobby Lobby art department, who cares?
That's why I also suggest the Testors Model Master Auto Lacquer Spay, again sold at Hobby Lobby, that comes in spray-cans, as well as their white primer. It is a two-step finish system where you also use their gloss clear-coat as well as the color. Again, cheaper, and less trouble then the care and feeding of an airbrush set-up.
By the way, Phil, what is the second color? The one in the museum is all-white, wings and all. A bit off-white from the clear lacquer coating aging, but still all the same color.
Now I've seen kits built with blue wings, but I believe that was from someone mistaking the blue-sky reflecting on the high-gloss white wings illustrated somewhere to be a different color.
Tom TCowboy
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    December 2011
Posted by model make on Tuesday, November 8, 2016 1:06 PM
Tom
Using acrylic paint in an internal mix airbrush is a Bozo no-no.
Got it!
Good thing my Testors Mighty Mini and Badger 250 are external mix.
Badger 250 is even needle and cone free!
Paint siphons out little opening and away it gets blown!
Spray paint cans are out for the present.
Even have a can of Testors Red Metal Flake 3 oz right here for car model.
Getting back into hobby just want to take things one thing at a time.
Thanks!
    April 2005
Posted by T_Terrific on Tuesday, November 8, 2016 2:04 PM
Hey Maker,
  1. Dull the model's surface with a fine grade of wet/dry sandpaper like the kind I get in Testors sandpaper packs.
  2. Then you go to a flat white, as a primer coat.
  3. Then go to a clear-coat for a final gloss finish!
All the above can be done with the Testors products as sold at Hobby Lobby (I prefer Testors clear coats over messing with floor polish), whether you spray or hand-brush.
Now notice, whenever you want a gloss finish from any flat paint, then simply clear-coat the flat color.
That also generally takes care of all my gloss-paints issue for water-based acrylics including the light-grey fuselage of the Sparrow Hawk kit I built from a Williams Bros. kit, many years ago that also was molded in white.
By the way, for that kit, I literally used a basic Testors Acrylic paint set I got from Wal-Mart many years ago. The main fuselage is the flat Light Gull Grey, gloss-coated.
Tom TCowboy
Tom TCowboy
    April 2005
Posted by T_Terrific on Tuesday, November 8, 2016 2:52 PM
Hey Tex,
Are you a "tanker" too?
As for grade level, yeah I got some built armor stuff as well. I tried some again a while back, was just like when I was in elementary school.
For me, the reasons the armor stuff is not the challenge aircraft are:
  1. Missing a headlight, damage the hole and chalk it up to battle-damage.
  2. Cover damage to finish from glue-runs with fake mud, zimmerit, whatever.
  3. Actual interior details not there, no issue, no windows to look into.Wink
  4. No need to consider the underside, as we do in aircraft-nobody sees the belly of a tank as we do usually do see the bird's underside first at any air base-so it can be full of sinkholes, recesses for axles, etc., but who cares?.
  5. No flaps, alerons, elevators, rudders, gear doors, bay doors, etc. Only a couple of hatches, maybe a turret to swivel if it is not an SP gun, howitzer, tank destroyer,etc., then you have nothing but the gun that moves up-and-down-Sleep
So, as far as what grade, I got bored with typically two-dimensional armor stuff long before I graduated High School to next go on to obtain my degree in engineering.
How about you, Tex?
Tom TCowboy
Tom TCowboy
    December 2011
Posted by model make on Tuesday, November 8, 2016 3:24 PM
Tom
I have a Hall of Shame story.
Tossed out Walmart Testors paint sets!!
They were old. Getting dried out because they were 6-8 years old.
Now I'm equipped with Testor's Acrylic Thinner so probably
could have save some of them.
Live and learn!
Bob
    December 2011
Posted by model make on Tuesday, November 8, 2016 5:16 PM
Modelers
Watched a little of "Towards the Unknown" with William Holden.
He walked by the X3!
Apperently the Air Force thought it would be a good idea for it
to be in the movie!
X3 is glossy white. Didn't catch wing color. Tail had yellow patch on it.
Model Maker
    June 2014
Posted by Tanker - Builder on Tuesday, November 8, 2016 5:57 PM
Okay ;
 So you wanna put me in the hotseat huh ?
 Here you go . Did my first proffessional model , for what it's worth at eighteen . I am now 73 and on my way to the next one . Have done models for the most well knowncompanies in this country although I didn't know that they put them into museums  . Found out years later .
 As far as pictures go I have never learned how to do this . Many have tried to help , but after many failures I am giving that a rest . I came close but still didn't get that coveted Havana ! If you choose , Send me an address and I will gladly mail you some of the many copies I have .  T.B.
    December 2011
Posted by model make on Tuesday, November 8, 2016 6:05 PM
 Tanker
Use Google Photo. They are a known outfit.
Upload pictures to Google photo. That's Step One.
That works like most uploads.
How this 'Insert picture' works on this forum is a mystery to me.
It's just a blank box that's titled 'Source'. What does that mean?
Thanks!
Posted by Texgunner on Tuesday, November 8, 2016 7:11 PM
T_Terrific
How about you, Tex?
Tom TCowboy
How about me what?  Confused
"All you mugs need to get busy building, and post pics!"
    April 2005
Posted by T_Terrific on Wednesday, November 9, 2016 2:04 PM
Is it the paint thinner, or the solvent cement, or the "Hoppe's no. 9" gunpowder solvent, that rrequires I explain the obvious, 'shooter?Whistling
Oh, that's right, your an "Aggie"!
You see, there were these two aggie grads (that's Texas A&M for the uninitiated) who decided to go into business buying and selling truck-crops. And...Off Topic
Oh, sorry, back to the subject:
What is your scale model genre'/experience?
Tom TCowboy
Post Edit
If you like, I can finish the joke sometime, or I can do the punch-line for "Do you know how to tell a Texan?"
Guess what, I am still married to one.Wink
Tom TCowboy
Posted by Texgunner on Wednesday, November 9, 2016 3:56 PM
Uh, I believe that would be "you're an Aggie".  Sorry, but that A&M education just creeps up on me sometimes...Pirate
http://imodeler.com/author/garybrantley/
    April 2005
Posted by T_Terrific on Thursday, November 10, 2016 11:25 AM
Very nice!
Thanks for the link.
Now, when you say "you're an Aggie" you're not trying to bestow upon me the distinction of being an Honorary Aggie, are ya?Wink
TomTCowboy
Tom TCowboy
Posted by Texgunner on Thursday, November 10, 2016 11:47 AM
T_Terrific
Very nice!
TomTCowboy
Thanks a lot!  And, you're welcome for your compliment.
No, see, I was just trying to show you the difference between "you're" and "your".   Geez, didn't you engineer-types ever learn anything useful in school?
Big Smile
Gary
    April 2005
Posted by T_Terrific on Thursday, November 10, 2016 1:14 PM
Texgunner
T_Terrific
Very nice!
TomTCowboy
Big Smile
Gary
LOL!
Honestly, they did't make it easy, since lab and math courses and the sciences didn't worry about ''perfect spelling". unlike more practical educational cirricula, such as Social Studies.Big Smile
By the way, thanks for letting me "off the hook" and not making me  an Honorary Aggie. You had me worried there for a while.
Tom TCowboy
Tom T
Tom TCowboy
Posted by Texgunner on Thursday, November 10, 2016 4:22 PM
I enrolled at Texas A&M for the spring semester 1995, I was 42.  The reason I was there was because it was a doable commute from my hometown.   I graduated in Dec. 1997 with a BA in History, 3.915 GPA.  And every damned semester that I was enrolled, the crazy Aggie administration pulled some crap that only Aggies could do. Huh? They've earned their reputation I assure you.
Now, for some somewhat seasonal Aggie humor:
**Two Aggie roomates were talking in their apartment one late November evening.  One said to the other, "You know, I think we should get a Christmas tree for our place.  All our neighbors are doing it and I think it would look cool!"
His roomie agreed and asked, "But, where could we find a Christmas tree?"
His buddy said, "They grow wild in the country.  We could drive out of town Saturday and cut one down."   So a plan was made, and when Saturday rolled around, it was cold and rainy.  The two drove out a country road and crossed into the woods.  They walked for hours, getting wetter and colder all the time.  It was getting late, and darker.
One turned to the other and exclaimed, "Damn, I never knew it would be so hard to find a Christmas tree!"  His roomate said, "Me neither.  I say we cut the next one we see...whether it has lights or not."**
bada bing!!
Hey folks, I'm here all week!  Try the veal, they tell me it's great!Big Smile
    April 2005
Posted by T_Terrific on Thursday, November 10, 2016 5:37 PM
Texgunner
bada bing!!
LOLROF!!!!!!!!!!!!!!!!!!!!!!!
So, there were these two Aggie boys who graduated together, and decided to truck vegetable crops from the farmers to the market.
So, they got a new Ford pickup (no chevvy dealers near there), and they bought tomatoes at $1.00 a lug.
Then they sold them for $1.00/lug.
After a while, the guy in charge of the books found out they were not making money, or "profit".
So they worked on the problem all night, and the driver said, "You know what, we need another pickup-truck!!"
Been married to a Tyler Rose for over 40 years.Wink
Dad-in-law been widowed twice-cool guy, looks better then you, former IBM employee, still in Tyler, and has a new lady-friend!-can you top that?
I mean I wouldn't want to!
BTY, mine's a 9x18 Makarov Tu-Tone-more then sufficient, as he has actually helped me more then onceWink
Tom TCowboy
Tom TCowboy
