I went to the hardware store today. My mission was to locate the textured paint Gamera mentioned. It was quite the adventure because I forgot my glasses. The entire row is dedicated to Rustoleum. It was three passes and with blurry eyes that I finnaly located it. I am glad that I did.
I sprayed the test piece and below is the outcome. For clarity sake, the bottom third had a thin layer of Durhams, the middle third nothing, and the top third was also Durhams but I added white glue. I tested it with white glue because I was concerned that Durhams might not adhere well to the base putty. I was covering my bases. In the end, I think the concern was unfounded.
All I can say is, wow! The paint did the job and then some. So much so, I might eliminate Durhams from the equation. If anything, if I do use it, it will be for the sole purpose of altering the topography.
So, Gam, you sir, are the man of the hour. Thanks for mentioning this. It doesn't get any easier than this.
![](https://live.staticflickr.com/65535/53808775446_4d0560e5b3_b.jpg)
While I continue to work on the base, I turned my attention to the track assembly. Specifically, how will I mask the rims. I knew this would be the most problematic portion of the process, and it did not disappoint. I tried cutting circular Tamiya tape masks, then vinyl tape, and lastly, Bare Metal Foil. I could not get a good result with any of those. I came closets to achieving the goal using BMF but with the wheels being recessed, it was difficult to trim. I scrapped the idea using any of the mentioned.
What I came up with was to make a circular mask using styrene. I will paint the rims, mask the front face of the wheels, paint the tracks and most of the rubber tires, then remove the masking and one by one trim out the forward facing portions of the tires using the mask tool I made. I should be able to get a nice and tight wheel rim. That's the plan.
![](https://live.staticflickr.com/65535/53807845612_5cde152d5d_b.jpg)
I think from here I will prep the base for textured paint.
End.
