There's some progress to report.
I coppered the hull halves with a great product- copper foil tape for stained glass and "Tiffany" lamp craftspeople.
A short session with the calipers found 7/32" to be the minimum width that would still slightly overlap. This product is quite reasonable. One $ 7.50 roll just did the two main halves, with about a foot to spare. I bought two rolls however, and my plan is to glue the hull halves together next, and copper the stem and keel after finishing the seam. And quite a seam it will be; trial fit shows both halves are pretty warped and much clamping will be required.
I love the copper look, and while I'll probably dull it with something, just now it's like a new penny! The tape seems to be coated with clear plastic; no fingerprints or oxidation seems to be happening. So I'll have to do some trials on scrap when I go to paint.
Taking the "investment" in goodies one step at a time, my first batch arrived from Jotika. All the cordage to rig the breeching lines on all of the guns, plus enough line and blocks for the tackle on the 20 or so guns that will be most visible. The two big ropes there of course are the cable and messenger. Just an example of the minutae builders get into- was the cable wormed or not at Trafalgar!? Longridge has a nifty setup to worm lines- I may play with it on some scrap for fun.
The gun project is about complete. I've scraped most of the barrels. next step is to fit on 102 breeching rings, paint the barrels, sort out the 20 best guns and detail paint their carriages. Believe me the middle and lowers are done!
You can see under the tray the (mis) results of the deck mask/ paint exercise. It was humming along fine until I started removing the tape and it left residue. I'm back to considering planking the upper in the waist, quarter etc. But the big problem will be that the guns will sit too high. Need to ponder that one, however I probably won't be fitting the upper deck for a few months yet. Any suggestions most welcome.
Bill
