Twin Turreted monitor U.S.S. MONODOCK
    March 2007
Posted by bondoman on Friday, June 1, 2012 11:07 AM
My that's looking great!
    March 2005
Posted by philo426 on Friday, June 1, 2012 4:43 PM
Thanks
    March 2005
Posted by philo426 on Friday, June 1, 2012 11:55 PM
Painted the deck today.I decided that the straight black was boring so I cut out some squares on .10 styrene and airbrushed very dark gray. I like the result.
    March 2005
Posted by philo426 on Saturday, June 2, 2012 12:05 AM
Here is the mask;
    March 2005
Posted by philo426 on Monday, June 4, 2012 1:11 AM
Fabrigated the bosses for the stacks.i cut a square piece of .80 styrene and draw a circle of the appropriate diameter with a circle template.I the drill a 1/16 hole in the center and chuck in the mototool utilizing the disc mandrel.I cut the corner with tin snips and hold the spinning disc against a coarse sanding drum until it is perfectly round.I remove it from the mandrel and drill progressively larger holes until the correct inside diameter is achieved.Sometimes i have to use the small sanding drom or shaped stones to do this.I put the .60 drill bit in the moto tool to drill the holers for the rivets.I epoxy the ring to the deck and drill through the rings into the deck for a strong structural bond.
    March 2005
Posted by philo426 on Monday, June 4, 2012 3:57 PM
I airbrushed Tamiya clear black (smoke)to tone it down.
    March 2005
Posted by philo426 on Sunday, June 10, 2012 12:01 PM
see below
    March 2005
I decided to forego ordering a resin casting kit and instead construct a second turret.I cut out the strip,drew the index lines for the rivets and cut the cannon holes.I then drilled the rivet holes with a micro-drill chucked in my Dremel.I readied the form which consists of 2 styrene discs joined by a length of tubing.I dipped the strip in boiling water several times until it fit on the form.To achieve the final shape i affixed the strip to the form with a doubled hair scrunchy.I put it in the boiling water for 10 seconds and rolled it on the cutting board until the sides met in the back.i trimmed and installed the rivets,cut out and installed the turret top,primered and painted it.I am pleased with the results of my nocturnal  modeling session last night.
    March 2005
Posted by philo426 on Monday, June 11, 2012 9:35 PM
Installed the cannon into the turrete.I made a simple 3 piece gun platform and used a round stone in myDdremel to carve a trench for the barrels.The guns were installed from the front with epoxy.
    May 2009
Posted by Brizio on Tuesday, June 12, 2012 8:17 AM
Fantastic!
    March 2005
Posted by philo426 on Tuesday, June 12, 2012 8:47 AM
Thanks! It is going well so far!
