Moebius Seaview 1:350 scale WIP
    July 2014
Posted by Bakster on Tuesday, October 24, 2017 9:10 AM
steve5
has an almost tranquil effect about it
30 seconds.
Forward drift?
Yes.
Okay.
Contact light.
Okay. Engine Stop.
We copy you down, Seaview.
Houston, Tranquility Base here.  The Seaview has landed.
That’s one small step for scale modeling, one… giant leap… for toilet paper.
Yes
    May 2013
Posted by Greg on Tuesday, October 24, 2017 10:29 AM
Steve, I don't understand a single thing you are doing with the base, but it sure is looking good and so are your water samples. 1G it is then.
Your cartoons ain't bad, either. Smile
Actually, I'm very impressed with the cartoons. Plus they are actually funny. Yes
    July 2013
Posted by steve5 on Tuesday, October 24, 2017 6:19 PM
your not headed for the sea of tranquility are you , Whistling
    July 2012
Posted by littletimmy on Tuesday, October 24, 2017 6:30 PM
That's not just any brand of toilet paper..........
That's John Wayne toilet paper.......... Pilgrim !!!
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    July 2014
Posted by Bakster on Tuesday, October 24, 2017 7:07 PM
steve5
Um... maybe. You never know where the crew of the Seaview might turn up.
Huh?
    July 2014
Posted by Bakster on Tuesday, October 24, 2017 7:08 PM
littletimmy
Thats right... and don't forget it. Lol.
    July 2014
Posted by Bakster on Tuesday, October 24, 2017 7:09 PM
Greg
Thanks Greg!
    July 2012
Posted by littletimmy on Tuesday, October 24, 2017 7:26 PM
Bakster
Bakster wrote the following post 12 minutes ago: littletimmy That's not just any brand of toilet paper.......... That's John Wayne toilet paper.......... Pilgrim !!!   Thats right... and don't forget it. Lol.
I always keep a roll of John Wayne T.P. by the computer..... it's an XP so you never know when it's going to crap out on you.
    July 2014
Posted by Bakster on Tuesday, October 24, 2017 9:03 PM
LT...you are a hoot! LOL. Thats a good one.
Posted by CapnMac82 on Wednesday, October 25, 2017 8:33 PM
Bakster
If you ever want to share your perceptions of what you had seen
It being St Crispin's Day, it seems mete and just for an old man to roll up his sleeves and show his scars, and remember, with advantage, feats done in earlier days . . .
Once you stand out int othe blue water, well away from theland and the haze that lurks exer over it to be of no more substance than yesterday's clouds, then it becomes abundantly clear that the sky and the sea are coupled.  Each a mirror to the other; both being both action and reaction, one to the other; sometimes one and the same.
It's the stuff of both superlatives, and of generalities.
Off Hampton Roads and trudging across the Gulf Stream under a sky of lead wool over ocean the color of molten solder--to have the skies clear, and the ocean don its deep blue visage again.
Or being under sail, south of Trinidad, in the silence that only the middle of the night knows.  On a sea of pure black ink, under a cloudless ebon sky.  The wind and the sea but a whisper, the sea as invisible as the sky, only the glimmering reflections to hols the hull up in the void littered with stars beyond measure, an endless, infinite sky.
Scariest sea though, would startle most.  For is was a perfect turquise hue, with only the merest hint of motion upon it; the reflections giving way to glass transparency.  ¿Que come est de meido?
Ah, the throbbing rumble to the engineering plant churning out horespower; blowers at full gulping the air,  The buzz around the bridge with every sensor manned; every scanning device working..  The hum of people urgently to task.
Tha cause being the anthracite sky astern, shot through with colors nearly unimaginable; greens, aquas, corals, even ochers and the like.  A living mass of sky come ravenous; lit with lightning botrh blue-white actinc and golden incandescant.
For such things are part and parcel to that dread heat engine, the tropical storm, well formed and afoot.  The sure, steady, salt tinged steel, normally so sturdy and unyeilding made frail and weak in the face of energy so rawly displayed.  Cubic kilometers of sky in their hundreds coupled to that circulation, climbing ever higher into the sky until it dares the stratosphere itself.
O we but mere mortal Men, sure in our Hubris, only to be reminded how fragile we really are, how feeble our Works are to the might of Nature itself.
    July 2014
Posted by Bakster on Thursday, October 26, 2017 8:58 AM
Very poetic Capn!  Thanks for sharing!
Posted by CapnMac82 on Friday, October 27, 2017 7:47 PM
Had taken a tipple to the brave Tudor king and his ilk who took his rightful claim to the French.
So, more  posey than not.   And an improvement over "ocean the color of used thinner and a sky of wadded up paper towels after a good airbrush cleaning."
    July 2014
Posted by Bakster on Saturday, October 28, 2017 3:15 PM
CapnMac82
Indeed!
    July 2014
Posted by Bakster on Saturday, October 28, 2017 3:52 PM
A little progress to show you today.
Below:
Here is how the bow is looking. I think that this is as far as I will go with the gel. It all looks pretty nasty, I know. But, I hope to pull it all together. "Hope!"
Below:
The base color commences. I brushed it on verses AB. At this point, there was no need to go with ABing it. I must say, it was kind of nice to slap the paint on with a brush.
I see that I need to make the coverage at the bow more symetrical.
One other thing reared its ugly head. The seams between each row of TP tend to show at some points. Some areas are worse than others. I had gelled up those areas prior to paint, but they still show some. The final coatings might elimnate that. That is a big maybe. I'll have to ponder that. I will probably add more gel where needed, and then repaint those areas.
Next up:
Aside from the seam issue... I need to sort out the bow. I need to paint and blend that area in a way that light will show through some. Then, I can apply the Tamiya Clear Blue over the entire seascape. After that--I can progress to the foam and such.
Btw... I tested the sub again with the light on while in the base, and it looked pretty darn cool. Maybe all of this futzing around the bow will be worth the effort. I sure hope so. It added a ton of work to accomplish this one little thing.
More to come...
    July 2013
Posted by steve5 on Saturday, October 28, 2017 4:06 PM
can't wait to see the finished product steve , this is really looking so cool .
    July 2014
Posted by Bakster on Saturday, October 28, 2017 4:58 PM
steve5
Thanks, Steve.
Posted by CapnMac82 on Sunday, October 29, 2017 2:46 AM
Can't wait, either--this is such a cool build
    April 2016
Posted by Hodakamax on Sunday, October 29, 2017 8:36 AM
I'm still here checking the progress!
Max
    July 2014
Posted by Bakster on Sunday, October 29, 2017 9:25 PM
CapnMac82
Thanks, Capn. I appreciate the encouragement!
Update: I decided that the seams need further repair. So, since my last post, I spent maybe three hours working on that. It is dang painstaking because the gel shrinks, a LOT! It requires coat after coat. I even resorted to using white glue. But, that stuff shrinks down too! There might be something better suited to use, but I have no clue what that that is. Sigh.
Anyway, I think that I have it now. I need to let that dry for a few days and then I can lay another coat of paint. Maybe, if I am lucky, just on the areas that I worked on. If not, it won't be the worst thing in the world. And while that dries, I have plenty of other things to work on.
BTW, Capn. I bet that at night the star canopy is really something to behold when you are at sea. There is very little light polution once you get away from land. Do you concur?
Star gazing is something that I love to do when the opportunity presents itself. Not much of that around here! There is too much light pollution. The closest I came to a dark sky was up north, and, what a sight to behold.
    July 2014
Posted by Bakster on Sunday, October 29, 2017 9:31 PM
Hodakamax
Max
I am glad you are still with me, Max. This is slow going, I know. I'd love to finish this by Christmas. That is my goal. The way it's going though...I'd really have to push hard to get there. We'll see. Maybe a model fairy will show up one night and finish it for me. Cough!
    July 2014
Posted by Bakster on Sunday, October 29, 2017 9:52 PM
Lastly, and as the weekend draws to an end... Here is something for you guys to chew on. I found this image of what is supposed to be one of the TV show props. I tried to find the backstory on this. All I could find was that this guy bought the prop and restored it. Kind of cool to see it in good lighting, and, up close.
    July 2012
Posted by littletimmy on Sunday, October 29, 2017 10:25 PM
That is cool ! Wonder if you could put a motor in it and "freak" people out at the beach?
Speaking of stargazing.....
This is a TRUE story. I'm not trying to be funny, but it is.
About 3 year's ago we were living in Winnemucca NV. We had property 35 miles from town and 10 miles from the "Dirt" county road, so NOBODY near us ( exept 2 neighbor's a mile away. Next closest neibor was 17 miles away.)   The "goat path" that went by our place had maybe 2 car's a day going by. (The local Rancher's patroling there cattle)
So I'm out one night around 10:00 PM and the RIVER of star's is amazing ! Well as I'm taking in the splender of the sky's I notice what I thought were taillight's about 4 or 5 miles up the road from me. I thought it strange that the rancher would be out so late. ( maybe hunting cyote's)  AS I"M WATCHING... THE TAILLIGHTS GO STRAIGHT UP!!!!!And disappear into the night.
Now a lot of people in this type of situation would be thinking.......what was that.....did I just see a spaceship?????????
But me?????? My brain TOLD ME: Just pay the check and GET OUT!!!!!
To this day I have NO IDEA what I saw.
    July 2010
Posted by docidle on Sunday, October 29, 2017 10:37 PM
I really love the way you are working this Steve! Sorry, about not checking in lately, just catching up now......hopefully. This is some outstanding work sir!
Steve
    July 2014
Posted by Bakster on Monday, October 30, 2017 8:36 AM
docidle
Steve
Hey Steve, thank you my friend. It is good to hear from you Sir. I hope all is well in your neck of the woods!!!
    July 2014
Posted by Bakster on Monday, October 30, 2017 9:08 AM
littletimmy
That would be fun for sure!
BTW... That is a great story/experience that you shared. I am not surprised to hear this, and, I fully believe that you had seen something odd. I believe because I have seen something as well. And, clearly, it was not a conventional aircraft that we Joe Public know about. I wish more people would talk about their stories. Most keep these experiences to themselves for fear of ridicule. I'd tip my hat, if I had a hat, for sharing that.
    July 2014
Posted by Bakster on Tuesday, October 31, 2017 9:44 PM
Nav Lights
There are a few things on the exterior of the sub that I want to dress up some. One of those things is the navigation lights. There is nothing wrong with the molded lights as they come. Actually, I think they are pretty clean looking. What IS wrong though, is my trying to paint those, without lobotomizing them. I am sure with a little careful masking I could do it, but, I feel, that I have a better way.
1. I heated a needle and pressed the tip into those plastic lights as dead center as I could. This created starter holes for my drill.
2. I drilled the plastic out.
3. I cut and shaped short pieces of Evergreen rod styrene to be used as the new lights. I used .025" size.
By doing it this way... I can paint the skin of the boat, and then, insert the rods after. Of course, the fabricated lights will already have been painted while off the model. Also, I won't glue the sail to the hull until after paint. This will allow me to glue the rods from the backside, and within the sail assembly. There will be no unsightly glue marks by doing them from the front.
I should be able to get a really nice and clean look to them.
Below: I will try shaping the lights to have a dome to them. In this quick mockup they look a little too pointy. A side note: I need to remember to fix that divot on the leading edge of the sail.
This is just one of the things that I am working on. I am also working out a process to mask the missile covers. This is all leading me to getting paint on the beast.
    July 2012
Posted by littletimmy on Tuesday, October 31, 2017 10:31 PM
You have come this far, what's to keep you from wiring LED's for the light's?
The holes are already there.......
Or did I just complicate thing's?
 Sorry.        I'll go back to reading the comic's.
    July 2014
Posted by Bakster on Tuesday, October 31, 2017 11:06 PM
Tim, it's a great idea but they don't make leds that small. This is seriously small. Remember, the hole is .025. That is with a zero in front of it. Lol. Otherwise, trust me, I would have. It is doable on the larger cousin of this kit though.
I wish!
    July 2014
Posted by Bakster on Tuesday, October 31, 2017 11:11 PM
I just thought of something. One strand of fibre optic for each hole might work. This is a whole other learning curve.
    July 2013
Posted by steve5 on Wednesday, November 1, 2017 12:32 AM
it would look good with light's steve , can't you shave fiber optic's .
