Tamiya USS ENTERPRISE HELP URGENT
    March 2007
Posted by armornut on Friday, March 31, 2023 9:31 AM
   I apologize also for sounding short with you. Please accept. I understand the language barrier.
     Ok so....unfortunatly you will probably have to basically back track and seperate all parts from where your build stands now down to where stuff was started to be places on the hull below the flight deck.
     Some parts may be safe where they are...example the E4 E5 type parts.....however anything that is placed around the outside of the hull which is interfering with placement of flight deck will need to be removed and re installed in proper location.
    It is ALOT of work, however given what you have completed so far you might be abke to salvage the mistake.
    Look CLOSELY at instructions, pay attention to more than just the part numbers. Look at the direction the drawing shows....which way is the bow drawn.. be sure that part goes where the arrow goes.
     Once again please accept my apology for sounding short, I have no excuse for that behavior. I will continue to try to help however it is difficult for me to " tell you what to do" when I cannot physically point at the part or error and explain how to fix.
    Please cintinue to ask for help and I will try to clarify my meaning to help you build that AWESOME model.
we're modelers it's what we do
    December 2019
Posted by michael151722 on Friday, March 31, 2023 9:31 AM
Last thing to add to it the manual says attaching to the port side of hull which means left side right?
Thank you
    December 2019
Posted by michael151722 on Friday, March 31, 2023 9:40 AM
armornut
No worries, it is not your fault at all, you have done nothing wrong and I greatly appreciate all the help you gave me. So I will be planning on back tracking everything this weekend except for E4&5 but after showing you those videos and manuals would you say that the A Pieces should be on the right side of the bow, but as I mentioned earlier wouldn't the same problem arise if I put it on the right.
Also manual seems to be indicating the pieces of A is on the port side of Hull which is left side, you could look at #6 so you could give me better advice
Again, Thank you so Much
    March 2007
Posted by armornut on Friday, March 31, 2023 9:41 AM
  Correct, "left short Port", right long Starboard. Forward " bow", back "aft" or stern.
    The link to your manual did not down load on my device however yes the " A" parts that attach to the hull under the flight deck are in the wrong positions, and probably should be swapped left to right, fore to aft. As said look closely at entire picture on manual, MAYBE you can just move a couple to the proper locations and things will fit.
   Wow you type fast LOLBig Smile, trying to keep up....you are on track to do as I suggested, I recommend continueing that way. When I get a chance....and more coffee...I will try to pull a manual up on my device and formulate more advice to help. I will also try to keep it as clear as I can so things don't get lost in translation.
    Please continue to study your manual and plan your corrections. Slow down, patience serves well in situations like this.
    December 2019
Posted by michael151722 on Friday, March 31, 2023 10:17 AM
armornut
https://postimg.cc/gallery/JHnJsrk
Lol I do type fast lol, but the question I have now once you take a look at the images as it says hull port side which means left side so I did attach on left side. Since I just want confirmation before taking things apart. And if you see my other pics the A pieces seem to be quite aligned with other pieces and it looks like perfect sense. As you see from the middle part of the ship it aligns really well with other pieces
Thank you
    March 2007
Posted by armornut on Friday, March 31, 2023 10:28 AM
 Whew ,I think we are on the same page now Smile.  YES part A2 should be removed from the Port bow and placed in location Aft Starboard side. This should allow your forward flight deck to seat properly. I also believe that relocation of any of the " E" part may not be neccessary.
    Lets work one issue at a time....first remove the part from Port bow and place it Aft starboard. Look closely at manual, it will become clear. DRY FIT!! Forward flight deck and lets see if that fixes the problem.
   Step 3 shows the bow, no A parts installed, a few steps later A2,A16,A17 are installed on Port side Aft of lower hull.
    September 2006
Posted by the Baron on Friday, March 31, 2023 12:03 PM
I have a tip to offer you for posting your photos.  Some show as links, others show the icon for a broken link.
I see that you use PostImage to host your photos.  I use it, too.  What you should do, to make it as fool-proof as possible, is to select the "Hotlink for forums":
Don't use the Insert tool, just paste that link right into the body of your post.  When you save the post, the forum's software will show the picture. My picture above is stored at PostImage, and that's what I did to show it here.
Here's one of your pics, posted using this method.
    December 2019
Posted by michael151722 on Friday, March 31, 2023 12:27 PM
armornut
Would you explain a little more simpler as I am trying wrap my head around it, so from all the pictures I sent, A2 is not supposed to be on the front of port side but the manual states "attaching hull parts to port side", I am a little confused here. As you said in Step 3: parts are installed on lower hull of port side so which is the side I am currently on. Or am I missing something?
Thank you
    December 2019
the Baron
Thank you so
Thank you that helped
Posted by CapnMac82 on Friday, March 31, 2023 1:00 PM
michael151722
You have hit upon my number one gripe about kit instructions:  Using precisions terminology (jargon) imprecisely.
Mixing directional words is a recipe for disaster.  Instructions ought never use both "right" and "starboard" for directions.
In English, "right" could mean "correct," or "to return to normal," even "an inalienable ability."  "Starboard" generally will neatly be Steurbord in German, Stuurboord in Dutch, even estribor in Spanish.
Sorry, it's a particular gripe of mine.  That, and dumping the technical writing off on people who have no idea what they are writing about (see writers of Pontos instructions).  My 24 years in the US Navy, and a lifetime submerged in precision terminology, does not help in the slightest (neither does being a bit of a polyglot).
Now, as to how to get long-cemented parts loose, you may want a product like this:  https://www.amazon.com/Tamiya-America-Photo-Etched-Craft-TAM74094/dp/B003JTGZY4
The removed bits may need shimming with thin cardstock plastic to replace the material lost to the teeth of the saw.
An alternative might be to use a scribing tool and lots, and lots, and lots of patinece to sever the mis-placed parts, by cutting around, and around, and around, in endless shallow cuts.
Now, Tamiya is a pretty customer-forward company, it might be, that if you ask them, they will send you replacement sprues of the offending parts.  That would allow you to just chop the offending parts off, and sand the hull smooth again, and replace with the correct parts.
There are many ways to get to the same end point.
    March 2007
Posted by armornut on Friday, March 31, 2023 7:38 PM
   Correct michael, A2 should NOT be on left front.
    December 2019
Posted by michael151722 on Friday, March 31, 2023 7:44 PM
armornut
Nvm I think I totally get what you mean after studying instructions, A2 is not suppose to be that in front on the left it should be grouped with the other A pieces and near the metal piece that goes underneath the ship but still on the left side.
Thank you
    March 2007
Posted by armornut on Friday, March 31, 2023 8:22 PM
  Your welcome, glad to help. Good luck and please post a finished pic. Thanks for your patience. Thst was a tough oneGeeked
    December 2019
Posted by michael151722 on Friday, March 31, 2023 8:25 PM
armornut
Will do, thank you so so much for your help? But what I said above is what u meant right? And will post pics but might take a week or so to finish it up first.
Thank you
    March 2007
Posted by armornut on Friday, March 31, 2023 8:29 PM
 Yessir, A2 from front left to right "starboard" back.
   Look from wide end to narrow end, that is aft to forward.
   Move A2 from side of left narrow end to right side wide end.
    December 2019
Posted by michael151722 on Friday, March 31, 2023 9:11 PM
armornut
Thank you, Appreciate all the help man
    March 2007
Posted by armornut on Friday, March 31, 2023 9:20 PM
Welcome.Smile
    December 2019
Posted by michael151722 on Saturday, April 1, 2023 3:32 PM
armornut
Welcome.Smile
Thank you looks great now
    March 2007
Posted by armornut on Saturday, April 1, 2023 3:50 PM
AWESOME!! Thank you for letting me know I was right.  I may have to bring my kit out of storage and start it.
     Looks great michael.
    December 2019
Posted by michael151722 on Saturday, April 1, 2023 7:53 PM
armornut
Its all Thanks to you, again Thank you so much appreciated all the help I got, have the American Pibber which still needs a little help might bug you againa bit later
    March 2007
Posted by armornut on Saturday, April 1, 2023 8:27 PM
   Well I should be around.Cowboy
    February 2006
Posted by Wilbur Wright on Sunday, April 2, 2023 11:30 PM
I built this great kit in the 1990's with the GMM photo etched radars etc.
If I remember correctly there were small screws to hold the deck to the hull?
I also remember having to wrestle with some large parts holding them strong while using (at the time Tenax 7R plastic welder) which works very fast in bonding parts.
Do not try to rush things is always good advice on a large project like this.
Though old, This is an incredible model of the Big E at that stage of its life.
    March 2007
Posted by armornut on Monday, April 3, 2023 9:06 AM
   A couple of interesting things about michaels build is that kit is the old square island. Rare as far as I know.
    The key to figuring out the issue was difficult, SMALL language barrier, hit and miss photos of instructions and build, MY TECH ISSUE not OP!  The glitch turned out to be a print error, there was a directional reference arrow that was labeled " Bow" when actually it was pointing aft. This lead the builder to believe a couple parts were to be incorrectly installed thus causing fit issues with the forward flight deck.
    Once those parts were correctly instalked in proper location, the OPs pix seemed to show a good fit. I asked that finushed photos be loaded so all of us can see that beast in all its glory.
    December 2019
Posted by michael151722 on Monday, April 3, 2023 10:02 AM
Wilbur Wright
Yeah I was thinking of adding them later but I still have some detailing to do so I won't screw things together just yet but finally figured out the problem was great!
    December 2019
Posted by michael151722 on Monday, April 3, 2023 10:10 AM
armornut
It fits snuggly under the E4&E5 now once it clicked it clicked, but I still have to sandpaper a bit to smooth out the edgess to makes sure they fitted properly. I am missing some parts in which I just ordered from Tamiya will have to wait 9 weeks for it to arrive so will work on other stuff before completing the final build, will definitely show pics when done. Started this during Covid in the Summer of 2020, and took me a while to build most of it, than after I hit that bottleneck and life got busy so I put it down till recently and thanks to you is finally closer to completion
    March 2007
Posted by armornut on Monday, April 3, 2023 10:30 AM
 Ah shucksEmbarrassed, like my signature line states...." we're modelers, it's what we do".
Posted by CapnMac82 on Friday, April 7, 2023 1:58 PM
michael151722
I served on a Mk II, so please start a thread for any questions.
    December 2015
Posted by templar1099 on Friday, April 7, 2023 5:25 PM
I may be late to the party here,but in following this thread intermittently the need to remove and relocate certain parts stuck out. Not knowing the exact parts and location I will say I've had great success with nail polish remover and patience,jiggling etc. Hop it helps.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
    December 2019
Posted by michael151722 on Friday, April 7, 2023 8:56 PM
CapnMac82
michael151722
Appreciated, will ask away my questions when I have, Thank you
    December 2019
Posted by michael151722 on Friday, April 7, 2023 8:57 PM
templar1099
Yeah will try the nail polisher thing
Thank you
