Conversion complete(this time for sure): USS Arizonas pre WWI
    April 2005
Posted by ddp59 on Wednesday, June 19, 2024 4:19 PM
Joe, how thick is the rods that makeup your cagemasts?
    June 2024
Posted by PaulTK on Wednesday, June 19, 2024 6:47 PM
You can see lots of B&W photos of the Arizona at NAVSOURCE.ORG.
My belief is that pre and post WWI, the Arizona was painted in a light gray paint scheme using Standard Navy Gray #5.    She was repainted in Measure 1 in the Spring of 1941, consisting of Dark Gray (5D) on the hull and superstructure upto the funnel tops.   Everything above the funnel tops was painted light gray (5L).
    January 2021
Posted by JoeSMG on Wednesday, June 19, 2024 7:23 PM
The short answer is too thick.
The longer answer: In blender .357mm but I think the actual printed width is likely closer to .5mm as I overexposed each layer by a second due to earlier print failures. You get a bit of bloom/swelling the longer you expose a layer.
I've made a version that is about half as thick and am kicking around the idea of sending it off to shapeways to see how/if they come out.
- Joe the SMG
    April 2005
Posted by ddp59 on Wednesday, June 19, 2024 7:51 PM
that is something to think about.
take a look at this link. http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=385456
    January 2021
Posted by JoeSMG on Wednesday, June 19, 2024 8:45 PM
I see that olderModeler is starting the same conversion I did, and you were showing him how you dealt with the concave stern issue, but I'm not sure what I was looking at. Were you sanding down to the top level of the tape?
Edit: Just looked again and enlarged the photos. I think I see what you did now. I was thinking of filling in the concave depression - you chose to sand down the edges of the depression making it less pronounced. Interesting.
Nice of that site host images for the posters. That’s a great idea!
Cool
- Joe the SMG
    April 2005
Posted by ddp59 on Wednesday, June 19, 2024 9:14 PM
i did not sand in the way you think except to roughen the surface of the plastic hull for better glue adhesion. look at my pictures closely as you should see part of the correction process that you are not seeing clearly & wonder why i did that a way.
    January 2021
Posted by JoeSMG on Wednesday, June 19, 2024 11:16 PM
I see now, I missed enlarging the last picture. I see what you did now, very clever. I'm sure there was some filling and more sanding after that last picture but it looks managable. I originally thought the white strips were just tape!
- Joe the SMG
    April 2005
Posted by ddp59 on Thursday, June 20, 2024 8:01 AM
that is just the 1st layer as the next 3-4 layers goes parallel to the keel. each layer is sanded & shaped before the next layer goes on. no putty involved at all.
    January 2021
Posted by JoeSMG on Friday, June 28, 2024 10:13 AM
ddp59
Dave has once again caused me to reconsider the status of this project, thank you Dave for your brutal honesty (You could work on your delivery though). That said, you've been right, so I'm grateful for the feedback. I still need to work on the rigging so this project won't truly be done until it's in place but it is done for now, no matter what issues Dave points out next!
- Joe the SMG
    April 2005
Posted by ddp59 on Saturday, June 29, 2024 3:08 PM
what are you talking about what i had said?
    October 2019
Posted by Tanker-Builder on Sunday, June 30, 2024 11:04 AM
Joe!
         Oh My Goodness! Whatta Beutimus model of the Arizona!
 Joe, there was an article in FSM some years back about cage masts. (Before Printers)I did two in Evergreen .005 thickness and one in the same in soldered wire. Being as how I was set up for working with wire from some client's ships it went well. I still liked the cleanliness of my plastic ones better!  T.B.         P.S.She looks Bigger in grey! See what Color can do for you?
    January 2021
Posted by JoeSMG on Sunday, June 30, 2024 1:43 PM
Thanks T.B. I'm happy with the look. The mast rods are still at least twice as thick as they should be but they're probably about as good as Revell would have done back in the day. (I know that's not a crazy high bar but I do take some comfort in reaching it) I mostly used the info from this site: usni.org/closer-look-cage-masts and feel my results are definitely in the ballpark when compared to the pictures shown.
I would have liked to have seen your masts made of wire. That would be a project to be proud of. I entertained the idea of trying that, but my secondary purpose for doing this conversion (or any of my 3D printed work really), was the hope that I could sell kits for it on ebay someday, after I retire... On that level this was a flop - way too many failed prints on both the deck and masts, I could never charge enough to break even.
I am looking forward to doing the wireless rigging, If I can pull that off it should look pretty cool. It is pretty intricate and I’ll do it last after the lower string work. But I need to take a break, the wife only has so much tolerance for time spent on my hobbies – especially ones that aren’t likely to show a profit!
- Joe the SMG
