the biggest problem I have had ,,and have seen with acrylics..is either over-thinning or improper thinner concoctions
chipping/lifting is 90% ...improper thinning..temperature/humidity have minimal effect on acrylic paint(it's mostly water !)
the only difference between brands is ,some are more resilient to overthinning or improper thinning.
when you mix an acrylic down to a runny liquid suspension of pigment ...it's bonding property's have been all but eliminated on most cases....the correct thinner and ratio within the paints capabilitys will solve most issues.
