What The HECK is Wrong With My Airbrush????
    August 2005
Posted by Phil_H on Friday, June 27, 2014 6:10 AM
Just a thought. Have you tried a different air hose? It may be registering 20PSI at the gauge, but a blockage in the hose may deliver far less at the brush end.
    May 2014
Posted by SubarooMike on Friday, June 27, 2014 8:00 AM
I, unfortunately, don't know anyone with a compressor.  I will have to go out today and buy one to give it a try
    May 2014
Posted by SubarooMike on Friday, June 27, 2014 8:01 AM
I have turned the regulator up to where I know for sure its more then 20 psi and it still happens.  But I bought a new AB yesterday to try that came with a hose.  I will give that hose a try and I will report back.
    May 2014
Posted by SubarooMike on Friday, June 27, 2014 1:42 PM
Here is the latest picture. Definitely an improvement.   In the picture it's hard to tell, but there is still a lot fo over-spray-splatter.    I'm headed out now to go buy a new air compressor.
    May 2014
Posted by SubarooMike on Friday, June 27, 2014 4:38 PM
I bought a new compressor and that did not help.  I have no idea what to do now, lol. I put my airbrush away for one month, I go to use it again and things are all cattywompus.
    December 2004
Posted by panzerpilot on Friday, June 27, 2014 6:26 PM
Mineral oil or compressor oil got into the compressor cylinder and/or is now leaking into the air chamber?? Worn compressor cylinder "rings" perhaps?
-Tom
    March 2013
Posted by patrick206 on Friday, June 27, 2014 7:45 PM
I'm admittedly tech challenged, but here's a shot in the dark. Could a compressor mechanical or seal failure, as Tom stated above, allowed contamination into your air valve assembly?. I doubt it would take much to put the valve out of sorts, then contaminants could continue trans-locating forward into the rest of the brush. Maybe a good clean and inspection of the entire valve area could give some clues.
I can't imagine your frustration, (well actually I can,) but I wish you the best of luck getting this one sorted.
Patrick
    August 2005
Posted by Phil_H on Friday, June 27, 2014 8:19 PM
Ok, so a new airbrush and a new compressor deliver similar results.
The next thing to look at is your paint. What paint are you using, what thinner are you using and how much of it (thinner) are you using? How old is the paint? Perhaps it has started to thicken and your normal amount of thinner isn't enough? Paints vary in viscosity and there is no "golden" thinning ratio.
Also, I'm thinking that 20PSI may be a little high for a Badger 105. Try dialling it down to about 15 and adjust the paint to suit and see how that goes.
    May 2014
Posted by SubarooMike on Friday, June 27, 2014 8:46 PM
patrick206:  Since I was getting the same results with the new compressor, I have ruled it out... sigh lol
Paint:    Model Masters enamel interior gree thinned with mineral spirits.   Tamiya acrylic  ( various colors) thinned with their acrylic thinner.  All paint is only a few months old.  When I was first getting these results, I tired over-thinning.  It because almost too thin to paint with and yielded the same results.
 Tomorrow night or Sunday I'm going to clear my mind and go back at it with a different paint.
I just want to finish my models!
    December 2011
Posted by Chrisk-k on Friday, June 27, 2014 11:45 PM
Does the new compressor has a moisture trap?
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    August 2011
Posted by Blueline on Saturday, June 28, 2014 12:40 AM
I dont know where you live, but I bet that since your last session a month ago, the humidity has increased and you are getting moisture in the AB.
    May 2014
Posted by SubarooMike on Saturday, June 28, 2014 6:31 AM
The new compressor did not have a moisture trap,but I put my new moisture trap on it.    I live in Delaware. The humidity has been high outside, but inside it been  60-65%.  I'm not sure if that's high for painting or not.  But I do have that new moisture trap.
    August 2011
Posted by Blueline on Saturday, June 28, 2014 2:44 PM
Did the moisture trap help?
    December 2011
Posted by Chrisk-k on Saturday, June 28, 2014 3:41 PM
The moisture problem in airbrushing has more to do with the fact that condensation occurs when compressed air expands and cools than with the humidity.
    May 2014
Posted by SubarooMike on Saturday, June 28, 2014 10:13 PM
No, it did not help.  Am I suppose to be seeing moisture in the trap? I have no seen any.     I flew to a fly in today so tomorrow I will give the airbrush a try again.  I'm dying to finish up a few kits. If my airbrush is still out of whack, I have no idea how I will finish them
    August 2011
Posted by Blueline on Saturday, June 28, 2014 10:21 PM
From what I have read, there is nothing else to try.  You have a complete NEW setup: AB, compressor, and hose.  I'm at a loss for advice.  Hopefully others can help.  Good luck.
    August 2007
Posted by DUSTER on Sunday, June 29, 2014 1:25 AM
have you  tried adjusting the fluid control, very carefully/slowly  and the psi control very  slowly? - either one out of sync will cause unacceptable spray patterns.
I know its "coals to Newcastle" but here is a how to; maybe it will give you an idea you can use, in solving this.
  http://www.ehow.com/how_7836462_adjust-airbrush.html
Steve
    May 2014
Posted by SubarooMike on Sunday, June 29, 2014 10:02 PM
Isn't that for a single action AB?  I'm not sure I completely follow lol
    May 2014
Posted by SubarooMike on Sunday, June 29, 2014 10:03 PM
Should I be seeing moisture in my new moisture trap?
    August 2011
Posted by Blueline on Sunday, June 29, 2014 10:46 PM
The only time you should see moisture in the trap is when it has trapped a good amount of moisture. In other words, the lack of visible moisture means that there is little or no moisture in the air leaving the compressor or tank. The trap should be as close to the AB as possible, so that the air can cool and release the moisture. BTW, does your compressor have a tank?
    May 2014
Posted by SubarooMike on Monday, June 30, 2014 8:37 AM
Thanks for all that great information Blueline!    Yes, my compressor has a tank.  If you wanted to see what kind of compressor it is, you can look on this thread on page two.  I went ahead and posted of picture of it a few days ago.
    January 2013
Posted by BlackSheepTwoOneFour on Monday, June 30, 2014 8:42 AM
Hmmm... maybe you ran out of air in the tank? That is if your tank needs to be refilled.
    January 2013
Posted by BlackSheepTwoOneFour on Monday, June 30, 2014 8:44 AM
I went back and took a look at your compressor pic I don't know where your tank would be located. Inside? Maybe loose connections within your tank? I'm at a loss here as well.
    October 2012
Posted by Geezer on Monday, June 30, 2014 9:03 AM
About the only thing I've not seen you mention changing out are the connectors. I also am guessing that you have tried the new compressor, new airbrush, and new hose as a unit with the same results. That pretty much leaves the old connectors. I believe the quick disconnect may have O-rings in them. Perhaps one got damaged or perhaps some debris is stuck in one. Maybe connecting the hose directly to the compressor might work?
www.spamodeler.com/forum/index.php
Mediocraties - my favorite Greek model builder.
    August 2011
Posted by Blueline on Monday, June 30, 2014 11:59 AM
I didn't see a visible tank either. Have you drained the tank lately?
    May 2014
Posted by SubarooMike on Monday, June 30, 2014 12:55 PM
The tank is inside the plastic shell.  The tank is not empty.  It fills to 140 psi and when its falls below 100 or so it kicks back on and fills back up.    I drain the tank from the bottom when I am finished with it.  It lets any of the water out.    I will try replacing the connectors and try connecting the hose directly.   I don't plan on flying tonight so I will give airbrushing another try tonight and report back!
    May 2014
Posted by SubarooMike on Wednesday, July 2, 2014 5:57 PM
UPDATE!     Today I finally got around to trying my airbrush again.  I set up every as per usual -- including how I normally mix my paints. I am using my old airbrush with my usual compressor.  Everything basically flawlessly!  I had a tab bit of splatter for 30 seconds or so, and then is started spraying BEAUTIFULLY.   I am at a loss for words... LOL
    December 2011
Posted by Chrisk-k on Wednesday, July 2, 2014 6:28 PM
You don't like your new AB and new compressor?
    May 2014
Posted by SubarooMike on Wednesday, July 2, 2014 7:58 PM
The new airbrush was fine (Badger 105 -- same as what  I use now), and the compressor I was not a fan of.  Since I was able to rule out my compressor going south and my airbrush being bad, I went ahead and sold them to a friend
    August 2007
Posted by DUSTER on Wednesday, July 2, 2014 11:48 PM
Oh Good you fixed it (?)
I bet "one" of us helped you figure out the problem and you don't want to hurt the other guys feelings, by singling me    er   that person  out.
Seriously glad you got it fixed
Steve
