QUOTE: Originally posted by MikeV
Alright, where's our resident chemical experts?
I'm not an expert (minor in chemistry a long time ago).
I could look up the numbers (I apologize that I don't have them right now) but yes most thinners are flammable. Anyone ever use acetone to clean the airbrush? It works very well but is also combustable like gasoline. Lacquer thinner is probably pretty close to gasoline.
I actually called testors and requested the MSDS's for some of thier paints and thinners awhile back. They sent them right out. All companies are required to do this by law. The combustibility (if thats a word) info is in these.
QUOTE: Originally posted by Tankmaster7
She gets nervous enough about CA. (being a chemist she knows what it can do to you. Post back if you want a detailed description of the nasty things)
Yes CA is bad but I read a post in here a while back from a doctor that clearly stated that CA is commonly used for closing up stuff in surgery. That doesn't mean it's safe because doctors use it but apparently this practice has been around for a while.
EDIT: Acetone isn't more combustable than gas. I looked up some numbers here they are. Note, numbers vary and are dependent on manufacturer. You need to see the specific MSDS for your product to see exact values.
"Lies, Damn Lies, and statistics" - Mark Twain
material=========NFPA class======flash point========ignition point
gasoline ===========???=========== -40 =============== 280
acetone ============ 1B ========== -19 ================ 465
lacquer thinner ======???=========== -4 ================ 1
naptha ============???=========== 10 ================ 233-270
(main ingredient in most lacquer thinners)
ethanol ============ 1B ========== 9-12 =============== 365
ipa ================ 1B ========== 12 ================= 398
all temps in C
Painting is dangerous no matter how you look at it.
