MikeV wrote: |
They do not use the FS numbers on their paints like MM does, and that is what I meant. |
Yea I see what you mean. I've been doing so much armor that its been awhile since I did any other subjects. But I really do enjoy aircraft so I'm gonna run into this problem too.
MikeV wrote: |
I wouldn't spend the extra money on a cleaner like that when many household products clean just as well for much less money. Try mixing 1 part Simple Green cleaner, 1 part Windex with 2 parts filtered or distilled water and see how that does for you. It cleans most acrylics very well.
Thanks Mike for that tip. I'll give it a try next time and see how it does. X20A is rather expensive even though I usually buy the big bottle of it.
Phil_H wrote: |
Are you using X-20 or X-20A? X-20 is an enamel thinner, whereas X-20A is the acrylic thinner. If you are using the enamel thinner, that may explain things. |
I'm using X-20A. I've never seen any X-20 Tamiya enamel thinner so far.
Archangle571 wrote: |
I don't even think X-20 is available in the US since Tamiya didn't export their enamel line here. X-20A does have a distinctive smell though. but it goes away quick as well unlike the MM enamel thinner. with that said, i still have a good assortment of MM enamels really because of the color choices (for aircrafts). i always find Tamiya to be a little darker in shades and i suk at mixing colors. |
Yea thats true. I have a bunch of MM enamels too. I started out using them and doing aircraft. I guess the thing that even got me thinking about switching to acrylics was when I'd finish an aircraft and go to clear coat it. I couldn't find any dullcote at the time so I was shooting flat lacquer (I think it was flat lacquer). Man did that stuff smell aweful. I'd put a huge box fan right next to me and turn it on turbo mode and the stuff still stunk like crazy. I started thinking there has to be something comparable but less invasive. When I took the plunge and started doing some armor I picked up some Tamiya acrylics from my LHS and gave them a try. I thought they would have very little smell and would be a less toxic type of paint to spray. Well the paints seem to be that way but the thinner.... wow it stinks.
Btw I do wear a respirator. I picked a 3M one up from my local DIY store. It seemed like a decent one. This gets me wondering though. Are there any big differences between types of respirators or is there something specific that modelers should look for in a respirator? Mine covers my mouth and nose and has twin cartridge filters that are replaceable.
