How do you model?
    January 2016
How do you model?
Posted by PanzerCommander on Thursday, January 7, 2016 9:20 PM
I'm curious about everyone models...do you focus on just one at a time, from start to finish...or do you have several builds going at once?
John McLaughlin
    August 2013
Posted by Jay Jay on Friday, January 8, 2016 9:51 AM
I usually do only 1 at a time but I've got 3 going now by necessity.
I started a 1/48 Kingfisher and am waiting on an AM cockpit for it to proceed with the build.
While waiting on a difficult base paint to dry on my F-86, I started a 1/72 easy build Osprey to pass the time.
GAF
    June 2012
Posted by GAF on Friday, January 8, 2016 10:01 AM
One at a time, but for some odd reason I have 3 ongoing, and a diorama I'm attempting to finish.  It does give me something to work on while the parts are drying, or the glue is setting.  No complaints so far.  I do worry that it gives me 4 times the chance to break things, however.  Big Smile
Gary
    July 2014
Posted by modelcrazy on Friday, January 8, 2016 10:05 AM
At least 2 or 3 at a time. I was 5, but finished one, so right now it's 4.
Steve
    May 2013
Posted by hogfanfs on Friday, January 8, 2016 10:11 AM
I have four in various stages of completion now. Like mentioned before, while paint is trying on one, glue can be drying on another.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    December 2015
Posted by Dash8 on Friday, January 8, 2016 11:29 AM
One model at a time, it always gets finished
even if turns out like a dogs breakfast.Travel
On the bench: Revell Euro Fighter 1/32
Ontario, CANADA
    September 2012
Posted by GMorrison on Friday, January 8, 2016 11:33 AM
Three or four. I believe in giving paint time to dry, minimum a week between coats. Dry to the touch, isn't dry. So it helps to have something else to do.
I model ships, which usually get a little tedious and deserve to be put aside from time to time.
Posted by Bish on Friday, January 8, 2016 11:40 AM
I have tried doing more than one at a time, but i just can't do it. So i stick to one at a time. Thoug i do have 2 on going at the minute, but one is just on hold waiting for some bits to finish it off.
    March 2013
Posted by patrick206 on Friday, January 8, 2016 2:44 PM
I'm 15 years retired, so my modeling time is not limited to an hour or so in the evenings. Therefore, I can easily and efficiently have multiple builds underway. That facilitates allowing for cement, paint and filler to completely cure, while continuing to move those builds along.
I agree with GM, there really is no way to get around sufficient drying time. Once I sprayed on a Tamiya primer coat, let it sit overnight and had a really magnified look at the primed surfaces, particulary in the fine surface details.
Then I checked again each day for several days, seeing how the engraved details appeared. I could visually measure a continuing evaporation of the primer for about 4 days, with the engraved details becoming more finely defined each day. After that last check the appearance didn't noticebly change, I felt the curing had been completed.
Also I use Don Stauffer's method for a drying box, that really made a big improvement in my overall painting efforts. Thanks, Don.
For decades I've been a consistent sprue washer before building, I know the kit production methods have changed and that's no longer considered essential, but out of habit I still do it. Before any painting begins, I always do an alcohol wipe of the surfaces, then a light tack rag swipe. I just about never experience any paint failures or lifting, if I do I feel sure I did something wrong, not the paints problem.
Patrick
Posted by Tojo72 on Friday, January 8, 2016 3:53 PM
One at a time,for me it's a hobby,not an assembly line.
    November 2004
Posted by Bronto on Friday, January 8, 2016 5:39 PM
I usually have 10-15 going at once.
fox
    January 2007
Posted by fox on Friday, January 8, 2016 10:49 PM
Usually 3 or 4.  I'm also retired and have to wait for the glue and paint to cure sooooooooo I work on more.  Get's a little crowded on the bench sometimes but I manage.
Jim  Captain
 Main WIP:
    November 2014
Posted by Nuckss on Friday, January 8, 2016 11:47 PM
i used to do just one at a time but for a number of years now I have several going at once. I like to do similar subjects at the same time for economies of scale in airbrushing. Right now I'm doing a couple of USN WWII aircraft with similar paint schemes. I will do a couple of early war german armour etc. Even if I don't have similar subjects to take advantage of spraying similar colours for a couple of models at the same time I like to multiple kits at once for the reasons cited by other posters regarding paint curing, glue curing etc. I build a variety of subjects: armour, aircraft, cars, fantasy, sci fi etc so I need a large number of paints. I think doing a couple of similar subjects at the same time probably saves some paint wasteage because if I buy a colour for a certain subject (say early war german panzer grey) and do a couple of models with it right away, it won't be sitting around for perhaps years until I get around to doing another early war german tank.
    April 2015
Posted by Wolfman_63 on Saturday, January 9, 2016 5:29 AM
I build one at a time. With all the other things (work, family, life, etc.) I have set aside a night during the week to work on models. Depending on whats going on, I can sometimes get some time in on the weekends as well. It is a relaxing hobby for me.
Website:
David's Scale Models - https://www.davidsscalemodels.com
    January 2007
Posted by the doog on Saturday, January 9, 2016 9:06 AM
One 'til done.
Every time I've tried to start or work on another, I always seem to lose parts somewhere.
Maybe my work space needs to be larger; I use an old aluminum office desk, about 7x 5 feet large. Not much room to have several builds spread out in any easy fashion. But then again, I don't like switching genres because I always wind up missing a step somewhere in the assembly-finishing process that I might not otherwise had I been fully concentrating on one model.
Posted by Don Stauffer on Saturday, January 9, 2016 9:30 AM
Usually two, but sometimes three, occasionally a single kit.  Main reason for multiple build is paint drying time.  Even with my dryer box, there are times I can't work on a model for several hours due to drying paint, and if I have the time for modeling, I hate to waste it by doing something else.
    November 2008
Posted by plasticjunkie on Saturday, January 9, 2016 4:12 PM
Ideally one at a time but lately I find myself working on multiples, 2 to 5 at a time. I rotate the builds so parts, paint or decals dry while I work on another. I don't consider it an assembly line but I find that I can get more done this way.
 GIFMaker.org_jy_Ayj_O
    January 2009
Posted by fermis on Saturday, January 9, 2016 5:24 PM
When I model...I do my little turn on the catwalk...yeah, the catwalk...I'm too sexy for my shirt!
Anyway...I used to be strictly one at a time. Nowadays though, anywhere from 3-10...and usually in "groups" of either the same or similar. As an example, I've got 2 Fougas going (Special Hobby and Heller)...those are off to the side right now in their respective boxes. At the momment, there's 3 Eduard FW-190s on the bench. When I'm ready to break out the Fouga's again, the 190's and their parts will go into their own boxes, so I don't get things mixed up.
It does get a little chaotic at times, but nothin just a couple minutes of organizing can't handle.
    June 2015
Posted by OldGoat on Saturday, January 9, 2016 5:59 PM
Retired a few years ago so I do whatever trips my trigger. I usually have two going at once. I sometimes stack up finished builds for painting due to weather conditions up here.
    August 2011
Posted by BashMonkey on Saturday, January 9, 2016 6:10 PM
Usually three or four in various states of incompeteness, once every couple years I finish one.
 ALL OF YOUR BASE ARE BELONG TO US!
    February 2010
Posted by Stage_Left on Saturday, January 9, 2016 8:06 PM
One at a time. I've got about 20 shelf queens though, so depending on how you look at it, I either do one project at a time or have several going at once.
Dave
Posted by tigerman on Saturday, January 9, 2016 8:58 PM
Usually one at a time, unless I become frustrated or burned-out on a subject. I like GB's because it does keep you focused on just that one build, unless the GB's time-length is too long.
 Eric
    September 2015
Posted by Aaronw on Saturday, January 9, 2016 10:28 PM
Multiple, I currently have a pile going. I like to start kits, but I'm not nearly as good about finishing them. What typically happens is I'll have them stacking up, years worth and then I'll get into a finishing mood and it will look like I am a model building machine cranking out 10 or 12 models in a short time. In reality that was just 4 or 5 years worth that finally got their turn.
I do a lot of extra stuff on some models which drags things out, resin, scratchbuilt, rigging (biplanes... I love biplanes, but I hate rigging). I might crank out a fairly straight forward out of the box kit in a month, but I'll drag out the more complicated ones for years. Get it out tinker a bit, then back in the box.
I've got a Lancia Stratos just about finished that I started back in 2007 or 2008. That thing has enough decals to choke a goat so I just get it out from time to time, put on decals until my eyes cross then back in the box it goes until the mood strikes again.
    June 2010
Posted by 5-high on Sunday, January 10, 2016 12:14 AM
I have two going ..ones in the hanger waiting for quick boosts exhaust stakes for my old  1/32 scale revell spitfire mk I. .and the current  other is a trumpeter p51 mustang lll. After these. .it's back to the trumpeter p 38.
Pete
    March 2012
Posted by mustang1989 on Monday, January 11, 2016 9:04 PM
I've tried the two at once approach and what a train wreck that was.. !!! I have to build one at a time to get the best results.
 Forum | Modelers Social Club Forum (proboards.com)
    January 2013
Posted by BlackSheepTwoOneFour on Monday, January 11, 2016 9:23 PM
One kit at a time.... whenever I have that time to do them.
    December 2013
Posted by chango on Tuesday, January 12, 2016 11:20 AM
I'm into 1/200 scale battleships currently; I had several going (mostly nowhere) at a time but I've had to pull back and discipline myself as I wasn't finishing anything. I put away the others and am only working on 1 until I finish now.
The way I see it, one at a time is the way to go. If I flit about on several different projects I get bogged down and just end up with a stash full of partly finished kits.
    April 2014
Posted by Sandbox on Tuesday, January 12, 2016 11:55 AM
I currently have two going at the same but I have 3 others that are assembled and have some paint on them.  I need a modeling buddy who likes to paint as I seem to falter at the painting and weathering stage.
    February 2014
Posted by silentbob33 on Tuesday, January 12, 2016 12:26 PM
I generally only build one kit at a time. I don't feel like I can concentrate on more than one kit. That being said, a friend of mine asked me to assemble a Warhammer 40k army so I'm also doing a little bit of that at the same time too.
On my bench: Academy 1/35 UH-60L Black Hawk
    April 2015
Posted by RudyOnWheels on Tuesday, January 12, 2016 12:28 PM
I seem to do about 3 at a time as of late, but I have completed 2 of the current 3, and the third only needs decals, front nose-glass, and antennas. So I started one new one the other day, and I am staring at a Dragon haalf-track with PE and individual-link tracks, but I am honestly kind of scared of it having never done indi-links or PE.
   Rudy
