Assaulting the Hinterland**First Diorama**
    April 2007
Posted by Gamewarden5 on Saturday, November 22, 2008 8:35 PM
Recently Completed diomara.
The water is created using a technique from Kenny Loup "Gator" on modelshipwrights.com. The water is sculpted latex caulk and the bulllet strikes are paintbrush bristles coated with clear silicone caulk.
The barbwire fence is wire that I collected from 81MM mortar ammo crates. It is the wire that seals the can.
Visit http://www.ecpmod.com/ for a tutorial on how to create the water.
Member: IPMS region 12 Eastern Carolina Plastic Modelers On the Bench: 1/72 Revell of Germany ATF Dingo 1/87th Lindbergh Tug Boat Life is full of choices, make one. Train easy, fight hard and die or Train hard, fight easy and live. Heroes stand on the shoulders of men greater than themselves.
    November 2008
Posted by Gnet on Saturday, November 22, 2008 8:58 PM
How do we access the images? it sounds compelling....
    April 2007
Posted by Gamewarden5 on Saturday, November 22, 2008 9:06 PM
I am going to have to move them to another server b/c tripod will not let me host them apparently.
I will repost soon
    April 2007
Posted by Gamewarden5 on Saturday, November 22, 2008 9:27 PM
I moved all of the photos to photobucket and they should be working now.
Brian
    June 2008
Posted by Hans von Hammer on Saturday, November 22, 2008 10:13 PM
First one??? Wow... Well done, if that's the case.. Love the water, and the shore-line looks real enough as well, along with the bullet-splashes... Nice touch.  Water's a tough medium to model and you did it first time out.. Also, using the wire from the mortar cans is an excellent use of available materials... Learning how to "see miniature" in everyday objects is something that wil serve you over and over again... Not to mention that it'll save you some coin..Wink [;)] Outstanding..
Few tips for the next one.  Don't place the objects in the dio parallel or perpendicular to the base edges.  A slight angle, even 10 degrees or so, will give you a much better "snapshot" effect.  Also, placing the boat at an angle to shore would help too...  Moving on... Don't be afraid to start "Frankensteining" your figures.  Using them straight outta the box is ok, but will limit your story possibilities... You'll want, as you gain experience, to make the figures fit your story, rather than make a story to fit the figures...
Bottom line is keep 'em coming.  Keep that first one forever and use it to look back at as you grow as a diorama-builder... You're off to a good start...
Posted by senojrn on Saturday, November 22, 2008 11:27 PM
Gamewarden-GREAT JOB! Very nice dio and it's very well done! And welcome to the forum!
    April 2007
Posted by Gamewarden5 on Sunday, November 23, 2008 6:04 AM
Hans,
Thanks for the sage advice and the comments on the qualities. I will absorb and adopt all advice given to me.
Thanks again.
Brian
    June 2006
Posted by SteveM on Sunday, November 23, 2008 9:05 AM
WOW, Brian! Great work on this. Nice action, and the water looks excellent. Yeah, if this is your first dio, hats off. You got real talent, and there will be no stopping you.
Thumbs Up [tup] Thumbs Up [tup]
Steve
Steve M.
On the workbench: ginormous Kharkov dio
mmc
    February 2007
Posted by mmc on Sunday, November 23, 2008 11:48 AM
First of all a bigSign - Welcome [#welcome]
Very nice first dio, to add to what has already been said the water is amazing. Look forward to seeing more of your work.
Mark
    October 2007
Posted by panzerguy on Sunday, November 23, 2008 5:17 PM
  Very nice Brian. What a great beginningMake a Toast [#toast]
"Happiness is a belt fed weapon"
    April 2007
Posted by Gamewarden5 on Sunday, November 23, 2008 6:27 PM
Thank you all very much for your kind words and enthusiastic response. I will get planning on the next dio.
    January 2007
Posted by the doog on Monday, November 24, 2008 5:35 PM
A nice job, Brian--a very inventive and creative dio, on a theme that I haven't seen before.
Agreed, about the figures--they look adequate enough for the scene, but some repositioning of the poses would help your realism a bit (the first "running man" is going to run right into the first guy in the boat there and send them both overboard!). Still, the dio as a whole is very nicely done, and a work to be proud of!
    September 2006
Posted by RBaer on Monday, November 24, 2008 6:23 PM
Looks great, especially for a first effort. I really like the water.
Apprentice rivet counter.
    November 2007
Posted by Lufttiger on Tuesday, November 25, 2008 10:13 AM
Yes very well done water, i like it alot, and only your first one. Good Job!
www.lufttiger.com
