I know, bad pun. Are there any good ones?
After finishing building the B-36 I decided to do the two airplanes that were planned to be carried it. I made up my mind I would do these fairly quickly, I just want them to show the history of them and the B-36. I actually saw a GRB-36D fly over once with an RF-84K attached. The only RF-84F in 1/72 is the Italeri kit except for the new resin kit which I was to cheap to buy, since I had the Italeri kit in the stash anyway. I'm a little skeptical about the shape in the cockpit and nose, but I can't really figure out why. The canopy seems a bit big and the nose a bit small, but it pretty much looks like an RF-84F. I sanded down the raised panel lines a bit, spent some time reshaping the intake areas and added the gun ports there. I also lowered the horizontal tail to the 23 degree anhedral to make it an RF-84K. I made the decals in Corel Draw and printed them on an ALPS and a color laser printer. There is only a silly seat in the cockpit but I left it as it was made. There is enough lipstick on this little porker already.The XF-85 Goblin is the MPM kit, which comes with some pe for the cockpit. It has no locating pins so a lot of eyeballing went into aligning all those tail elements and getting the wings on at nearly the right anhedral. It was not a bad build, the one fright was when the canopy cracked as I was cutting the excess off. The material was somewhat brittle and I should have used the dremel drum sander on it sooner. Luckily the crack was mostly in the canopy framing behind the windscreen. There was only one vac canopy in the kit. The kit decals were Propagteam which I have often had bad luck with so I put a coat of decal film on them before I used them and they were fine using Microsol and Microset. The paint on both of these is Floquil Old Silver with SNJ aluminum powder rubbed in. What a tiny little airplane. It was never actually carried in the B-36 and was very difficult to mate with the B-29 during testing. The wings folded up and it was to be carried entirely inside the B-36, while the RF-84K was mostly outside.
John
To see build logs for my models: http://goldeneramodel.com/mymodels/mymodels.html
Looks great John. Thanks for sharing..
Joe
That's is an amazing build! You've recreated history with such detail sir. My hats off to you.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world. Mrs. Toshi
That is really a nice 3-some there. I especially love that B36. Well done.
On the bench:
A lot !! And I mean A LOT!!
14 / 5 / 2
What a lovely little group! =]
Tamiya F4U-1 Kenneth Walsh
Very cool little friends!
Great builds John! Verrry nice B-36. I was just checkin' out the B-36 GB earlier today and saw this if I remember right.
Forum | Modelers Social Club Forum (proboards.com)
Thanks, guys!
Hey , John !
Was that Parasite fighter the source for the design of the weird Egg Plane ?
Almost certainly!
Cool Builds !
I was unaware that any parasite fighters were available in plastic or resin.
Great looking builds John. That's a neat idea.
Steve
