Complete - Tamiya 1/48 He-219 A-7 Uhu
    August 2013
Posted by Jay Jay on Tuesday, July 28, 2015 1:21 PM
Nicely done.  I hafta get one of these someday.
    February 2014
Posted by silentbob33 on Tuesday, July 28, 2015 2:42 PM
Thanks JJ. I noticed a bit of the seam on the top of the fuselage after I primed it, but it should be good now.  I highly recommend this kit.
On my bench: Academy 1/35 UH-60L Black Hawk
    March 2012
Posted by mustang1989 on Tuesday, July 28, 2015 8:31 PM
I love the fact that I've got one of these bad boys in my stash!!Cool  I'm definitely getting some motivation from this WIP. Great progress !!
 Forum | Modelers Social Club Forum (proboards.com)
    February 2014
Posted by silentbob33 on Tuesday, July 28, 2015 8:36 PM
Thanks Joe!  I've noticed a couple of small boo boos here and there, but they are all my own doing, and hopefully they won't be too noticeable.  I'm hoping to preshade panel lines tomorrow.  I can't wait to get some color on her.
    February 2014
Posted by silentbob33 on Tuesday, August 11, 2015 12:23 PM
Well, I was able to shoot the RLM 76 Lichtblau and it looked great.  I spent some time cutting masks for the camo out of a full-size sheet Tamiya included in the box to make all those splotches look good.  I started spraying the 75 Grauviolett on the wing, left side of the cockpit and vertical stabilizer, only to realize I have some major overspray and coverage issues that were not repairable.  So I'm going to respray the 75 and try a different way to mask the camo pattern.  If that doesn't work I think I may switch schemes to an overall 75 top with squiggles in 76.  I'll let you know after I get a chance to paint it again this weekend.  Argh.
    February 2014
Posted by silentbob33 on Monday, August 17, 2015 3:02 PM
This has been the most frustrating paint job I've ever done.  I'd spray, have some type of problem, try something else only to run into another problem.  I finally went back to my original idea of using the paper masks and not caring too much about getting soft edges to the camo.  It isn't perfect and may not be too accurate, but it's as good as I'm going to get it.  There are a few mistakes, but you'll only see them if you get real close and know where to look.  I'm going to let the paint dry and tomorrow I'll shoot a glosscoat on it and start getting ready for decals.
Posted by Bish on Monday, August 17, 2015 3:19 PM
I rather like the look of that Bob. I am still to do one of these schemes and am a little concerned about howit mght turn out. But one thing i am going to try is to mist a very thin coat of the light blue over the mottleing to lighten it and blend it in a bit.
    February 2014
Posted by silentbob33 on Monday, August 17, 2015 3:36 PM
Thanks Bish!  I highly recommend you plan out every part of a scheme like this and practice on something before you put paint on the model.  I thought about misting some more of the 76 on to tie things together more, but at this point I'm leaving things at "good enough."
Posted by Bish on Monday, August 17, 2015 4:00 PM
Ye, i am going to get it all planned out.I am hoping to start it next month after i finish my 109. I'll post a WiP, so we shall see how the misting works out.
    February 2014
Posted by silentbob33 on Monday, August 17, 2015 5:27 PM
I'll keep an eye out for that Bish
    February 2010
Posted by Stage_Left on Monday, August 17, 2015 7:33 PM
Looks real good from here silentbob! That scheme can't be easy to do no matter how blended the splotches are. That grauviolett pattern looks very tedious and I think you pulled it off well.
I ran across a thread/blog somewhere a few years ago where the author attempted his 219 scheme thus: he sprayed the entire plane grauviolett, then rolled dozens of tiny tape balls and stuck them over the whole upper half of the fuselage and on top of the wings. He then sprayed the entire plane lichtblau. When he removed the tape balls the grauviolett splotches looked convincing and appeared to have a soft edge, at least from the pics I saw. Anyway, I say a job well done on your efforts Yes
Dave
    February 2014
Posted by silentbob33 on Monday, August 17, 2015 8:01 PM
Thanks Dave, it was a bit tedious. I tried to do a different scheme when I messed up the first time and sprayed the top and sides grauviolette and then attempted to do a squiggle patter in lichtblau, but that looked even worse. I'm pretty happy with how it looks now, especially with all of the other problems I had.
    January 2014
Posted by Silver on Monday, August 17, 2015 9:38 PM
I am working on the same kit and thanks for the info.When finished it will be completely opened up for detail.
    August 2013
Posted by Jay Jay on Tuesday, August 18, 2015 8:26 AM
Well done on this tedious paint job.  Your efforts have ultimately paid off to a stunning build.
    February 2014
Posted by silentbob33 on Tuesday, August 18, 2015 8:44 AM
Thanks Jay Jay!  I think I'm going to do something with a much simpler paint job next just to give myself a break.
    August 2013
Posted by Jay Jay on Tuesday, August 18, 2015 8:58 AM
You're quite welcome SB,
I like you am going to do a much simpler build next myself, and on a better kit I might add.  Although my Monogram B-26 doesn't have a complicated paint job, the kit itself is giving me a real headache.  The fits are very bad and every kit part i install, I hafta fix, so it's taking me way too long to complete.
    March 2012
Posted by mustang1989 on Tuesday, August 18, 2015 9:03 AM
Quote: But one thing i am going to try is to mist a very thin coat of the light blue over the mottleing to lighten it and blend it in a bit.
This works really good and I've had great results with it.
Your bird looks totally awesome  SB!!!!
    February 2014
Posted by silentbob33 on Tuesday, August 18, 2015 9:08 AM
Thanks Joe!
    June 2014
Posted by BrandonK on Tuesday, August 18, 2015 9:29 AM
Man that looks good. Regardless of how it's done, it looks plenty hard. You really pulled off a smoken nice camo scheme there. Great work. That scheme scares the crud out of me to attempt.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    May 2013
Posted by Greg on Tuesday, August 18, 2015 9:30 AM
A+ from me on the paint job, Bob. Looks great.
I'd be afraid to even try it.
    February 2014
Posted by silentbob33 on Tuesday, August 18, 2015 9:38 AM
Thank you very much.  As I was getting it built up I kept going back and forth on how I was going to paint it.  I thought about misting some 76 over it to tie it together, but I figure with as much trouble I had with it I'm going to leave good enough alone.  I hope to get the glosscoat on today and decals on soon.
    April 2015
Posted by UKguyInUSA on Tuesday, August 18, 2015 11:25 AM
Great camo scheme, looks well cool! Cheers :) Martin
    January 2014
Posted by Silver on Tuesday, August 18, 2015 11:57 AM
If the Nationals would ever reach the north west the modeling world will get to see on display only the super highly detail 1/32 scale HE-219  Which I also have.
    June 2013
Posted by bvallot on Tuesday, August 18, 2015 12:54 PM
Silentbob, I know I saw you on the GB earlier, but while I'm here I'll add my 2 cents...I think it's just fine really.  The camo may be sharper than you're looking for but I think it's fantastic still.  Tedious isn't doing justice to the time I'm guessing it took to cut out all those tiny bits. =]  I'd say it probably borders more on masochism!  Can't wait to see the rest of her come together.  =]
On the bench:
Tamiya F4U-1  Kenneth Walsh
    January 2014
Posted by Silver on Tuesday, August 18, 2015 6:48 PM
Again .Your UHU is going to look good.Great camo pattern.
    February 2012
Posted by lawdog114 on Thursday, August 20, 2015 2:03 AM
Looks pretty darn good to me. I think the spots were field applied anyways so I would worry about. That does it, off to ebay to find one of these bsd boys...
    February 2014
Posted by silentbob33 on Thursday, August 20, 2015 7:55 AM
Thank you all very much.  There are not many decals for this, so I'm hoping to get those finished up by the end of the week.
cnq
    March 2013
Posted by cnq on Sunday, August 30, 2015 4:52 PM
The painting looks good. This is a difficult painting job. I had a hard time to do mine as well ( Revell 1/32 kit) and practiced a lot on card board. Here is mine which I built ~ 2 years ago. It's all done free hand airbrush.
Revell 1/32 Uhu
Posted by Bish on Sunday, August 30, 2015 5:02 PM
That's a cracking job on that camo cnq.
    April 2005
Posted by wing_nut on Monday, August 31, 2015 7:34 AM
I think the camo is outstanding.  i think your over spray plan is a solid one.  bringing down the contrast will give it an illusion of softness tat will look great.
And I'll wager it was a heck of a lot easier then this...
http://www.clubhyper.com/reference/mottleshl_1.htm
Marc
