Ships of the American Flag GB 2019 -2021
    August 2014
Posted by goldhammer on Tuesday, July 16, 2019 2:48 PM
If you can drill the brass out to accept a fiber optic, then let it extend out from the end of the barrel enough to anchor you cotton wool (or whatever) without sagging....you should get 360* effect if the smoke and flame is thin enough.Cool
    July 2014
Posted by modelcrazy on Tuesday, July 16, 2019 3:10 PM
Yeah, you might be able to drill a 1/700 16" barrel.
Steve
    June 2018
Posted by DRUMS01 on Tuesday, July 16, 2019 3:15 PM
Sorry for not being so active in any GB's as of late. I have been waiting for this GB though. I really like the diversity of kits that everyone is building. I may have more than one, time will tell.
I have been pulled into outside work around the house. I have also went a different tangent recently working more on some larger scale resin figures. My current project (90mm Achilles) should be done soon and then I can start building within this GB.
I am going to commit to build my 1/350 Banner Arizona. I believe I got everything and anything that was made to improve her (deck, barrels, some resin details, countless sheets of P.E., etc.).
Please add me to the list, THANKS!
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    August 2014
Posted by goldhammer on Tuesday, July 16, 2019 3:15 PM
I was thinking more of the fiber optic for the barrels on Bak's 1/700.  HF's 1/350 would be a possiblity to drill his 1/350 barrels.  On the 1/350's might get enough from an LED in the turret through the barrel to do the trick.
    September 2012
Posted by GMorrison on Tuesday, July 16, 2019 3:39 PM
At 1/700, a sixteen inch rifle barrel is about 0.035 inches outside diameter.
Another thing to try would be to use two of the barrels as your conductors. The big ball of fire would mount on the ends, and you might drill a hole in the end of each just enough to get a piece of brass wire in there.
    May 2013
Posted by hogfanfs on Tuesday, July 16, 2019 3:52 PM
I just took a look at my 1/350 barrels, they have enough meat to cut a hole through them, 1/700 may be a lot more of a challenge.
But, do you all think having sound with the fire lighting effect would be cool?
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    July 2014
Posted by Bakster on Tuesday, July 16, 2019 3:58 PM
goldhammer
Great discussion guys. From my experience with fiber optic, I have my doubts it will work well for this. The reason I say that is that I don't think it will produce enough light. Along with that, the light does not radiate out like leds or incandescent bulbs; it is extremely directional.
Here is the thing... in my case and at this scale, it'll probably be easier to fit micro wires into the gun barrels, and then hang an LED outside of them within the plume. I'd probably try cutting a trench, lay the wires in, then seal them up with CA or something. Then reshape the barrels so they are round again. Past experience showed me it is really difficult to keep micro drills going straight. Having just viewed GMs post, that is a pretty good idea too about the wires. Using two barrels, I could make the trenches smaller to accommodate only one wire per. That is a very good idea.
    July 2014
Posted by Bakster on Tuesday, July 16, 2019 4:02 PM
GMorrison
Reading this again, this sounds even better than how I first interpreted Bills message. If I get metal guns, yes, they could work as conductors. That is a very interesting idea! I think it could work!
    September 2012
Posted by GMorrison on Tuesday, July 16, 2019 4:03 PM
Or use the brass barrel itself as the wire.
    July 2014
Posted by Bakster on Tuesday, July 16, 2019 4:21 PM
GMorrison
Correct sir, I misinterpreted your message the first time. This is a very novel idea. Yes It'd have to be tested. The more I think about this though, the less certain I am about it. The metal barrels have an electrical resistance to them. Will that resistance be great enough to shut down the LED, and or, reduce its light output. Also-- resistors are used to limit the current on one side of the LED. If the resistance of the barrel is high enough, it will be like putting a resistor on both sides of the LED. That is not a good thing. This is definitley worth some thought.
    July 2014
Posted by modelcrazy on Tuesday, July 16, 2019 4:37 PM
I never thought of the barrel as a conductor, I'm not sure the resistance would be high enough on a 1/700 barrel to make much diffrence but I could be wrong. The trench idea with single wires is a great idea as well, and you're right Bakster, the LED's need to radiate 360 deg for the proper effect.
Drums, buddy, I saw your post amongst the discussion and I'll get you down. Welcome aboard Yes
Steve
    September 2012
Posted by GMorrison on Tuesday, July 16, 2019 4:39 PM
A model railroad trick, like a signal light tower. You can also use the tube as one leg and an insulated wire inside it as the other.
    July 2014
Posted by Bakster on Tuesday, July 16, 2019 4:42 PM
You guys are great. This is gonna be another fantastic GB.
    July 2014
Posted by modelcrazy on Tuesday, July 16, 2019 4:42 PM
After adding Drums, I just realized the number of entrants Surprise
If there is this many for a American GB, imagine how many for the Greman next year.
Steve
    July 2014
Posted by Bakster on Tuesday, July 16, 2019 4:45 PM
GMorrison
Lol. That is another very good and possible solution! I like how your mind works, Bill.
    August 2014
Posted by goldhammer on Tuesday, July 16, 2019 4:49 PM
modelcrazy
Only have 2 in the pile....Dragon's Scharnhorst and the Graf Z carrier.  Hmmmmm.
    August 2014
Posted by goldhammer on Tuesday, July 16, 2019 4:57 PM
In 1/700, for the 360* effect, was why I was thinking the fiber optic.  Can put the LED in the hull, wiring out the base mount or in the foam board in a water scene. Might have to dip the optic in CA to get stiff enough to stay straight, paint the outside until you get to the blast effect area. If the end is held right close to the LED should get a subtle effect, rather than and overpowering one from the LED in the smoke/flame.  More appropiate for the scale I think.
Good ideas coming on it for someone to try in both 1/700 and 1/350.
    May 2013
Posted by hogfanfs on Tuesday, July 16, 2019 5:34 PM
goldhammer
And this is where I was thinking of trying the side glow fiber, check it out here
Have the fiber extend past the barrel a couple mm. But, I'm not sure a 2mm diameter piece will be small enough to run through the barrel (1/350). But, it's worth testing.
 Bruce
    August 2014
Posted by goldhammer on Tuesday, July 16, 2019 5:47 PM
Those little foot tall FO christmas trees have fine tubes in them, under 2mm, if they would give off enough side light,  possibly if the tip end is painted.
    July 2014
Posted by Bakster on Tuesday, July 16, 2019 6:26 PM
hogfanfs
goldhammer
Hey Bruce, I hate to be a negative nelly but I had just tried the side glow fiber optic on my X1 build, and I was very disappointed with the stuff. It barely produces a glow. In fact,  in my opinion, it is marginally better than the regular stuff.
I tell ya what though. If you have not ordered any yet, I can send you a sample via snail mail to keep, no charge. You can play around with it and see how it works for you. If interested, shoot me a PM with your mailing address. I’ll be happy to send you some. I might even have the size you want.
    May 2013
Posted by hogfanfs on Tuesday, July 16, 2019 7:10 PM
Bakster
Thank you for the offer, Bakster, but, I already ordered the combo pack. Granted it wasn't due to this tread, I was looking to test for a couple other projects, and ordered it this morning. Well, now I will be a a lot more skeptical when I test it. Thank you for your advice on this side glow.
 Bruce
    July 2014
Posted by Bakster on Tuesday, July 16, 2019 8:05 PM
hogfanfs
Hey Bruce, don’t lose faith. I bought the product through another source. Maybe I received poor quality stuff and maybe yours will work better for you than it did for me.
    August 2014
Posted by goldhammer on Tuesday, July 16, 2019 8:14 PM
The 2mm stuff is going to be just under 0.079 inch in diameter. Might just as well call it 0.08 to fit it through a drilled barrel.
If you figure a 20" diameter muzzle 16" bore and 2" wall..... that is 0.057 diameter.
Don't know what actual wall thickness is at muzzle is though.
    July 2014
Posted by Bakster on Tuesday, July 16, 2019 11:50 PM
GMorrison
Bill, I measured the guns and your .035 OD looks right. At the narrowest point I measure them at 1/32, or .031, and they expand as you move back. I didn’t mic it, eyeballed it with a ruler, so your .035 is right in there.
I did a few practice cuts on scrap and I am pretty confident that trenching is out of the picture. I think they’d fall apart in the process. Drilling is out too. We are talking about a part near 1mm in diameter.
However, I may have hit on a better solution with less unknowns. I found that K&S Engineering sells brass tubing as small as 1 mm OD. 1mm = .0394 inches. We are talking thousands of an inch difference, doubtful it would be noticed. I can fabricate the barrels from that. And I checked to see if wire will make it through them, and it certainly should. I will need to use magnet wire, about 30 to 32 awg. It is unclear if I can run two wires through a barrel, doubtful, but we already established other methods to get around that.
Long story short, this looks doable.
Sorry Admiral if I am jumping the gun on all this. You guys lit a fire in me, or should I say, you lit a fire on my USS Wi. KABOOM!
    July 2014
Posted by modelcrazy on Wednesday, July 17, 2019 8:53 AM
No problem Capt, I encourage discussion amoungst my staff.
Steve
    July 2014
Posted by Bakster on Wednesday, July 17, 2019 9:35 AM
modelcrazy
Thanks, Admiral. Yes
    September 2012
Posted by GMorrison on Wednesday, July 17, 2019 9:43 AM
I'm currently building a 1/700 model of USS Juneau, CL(AA) 52. As an anti-aircraft ship, her primary armament is 16 5" guns in eight dual mounts. The plastic barrels scale about 18" in diameter, and because of the unsually high barrel count, a brass set would add up.
I was looking for 0.010" wire that comes in straight pieces, but it's so thin it's hard to see so I settled on 0.020".
    August 2014
Posted by goldhammer on Wednesday, July 17, 2019 10:15 AM
The deck hardware just arrived....the 4"/50 is a work of art in it's own right. The 20's are beauties as well. but have to cut off the shields and see about straightening a couple of the barrels.
The 5"/51 isn't bad either, but the 4" knocks it out of the park.
Will get some pics today and get them up.
    August 2015
Posted by crown r n7 on Wednesday, July 17, 2019 10:17 AM
I’m ready for this GB !
 Nick.
    July 2014
Posted by Bakster on Wednesday, July 17, 2019 11:28 AM
GMorrison
Yup. Sometimes settling is the best option.
