(A)SW GBII - CLOSING
    March 2011
Posted by de havilland canada on Monday, November 28, 2011 10:02 PM
Big and beautiful Ken,nice work!!!!!
Here are more updates,had knee surgery last thursday so I have time on my hands......
http://i756.photobucket.com/albums/xx202/kermit77/ASWgb2/ASWgb2Badge.jpg
    October 2008
Posted by bsyamato on Tuesday, November 29, 2011 4:24 AM
de havilland canada
Ditto really a good giant!
Dehavilland wishing good healing about your surgery Yes
The Firefly comes perfect!! the paint is the same scheme as the gannet and more correct than mine Toast i wrong the grey
    March 2011
Posted by de havilland canada on Wednesday, November 30, 2011 9:19 PM
Thanks for well wishes Yamato.
Here are the latest ......I think done.The Firefly kinda frustrated me a bit.
These are not totally authentic RCN builds but I like them just fine and am pleased to have them both in my collection.
    July 2008
Posted by vetteman42 on Wednesday, November 30, 2011 11:45 PM
De havilland they may not be authentic RCN builds but they are darn close enough to my eye and are sweet well done builds YesYes Yes you should be proud to have them, I know I would be. Very very nice work indeed.
Randy So many to build.......So little time
    October 2008
Posted by bsyamato on Thursday, December 1, 2011 4:00 AM
really good finished firefly Dehavlland YesYes to me paint scheme seems correct.
Not noticed before the boa holes on the tracker engines back .
Imho just try to get more white light on the pictures or try some outdoor picture, the ones you posted are too yellowed.
    September 2008
Posted by maxfax on Thursday, December 1, 2011 8:05 AM
deHavilland- excellent work- they look great. I just love that main fuselage colour- what is it?
I'll have a pic up soon- been spending time replacing the welds and only a few rivets on the starboard side(the side with the cut outs for the interior), then adding the supports that can be seen through the flood holes. Slow, time consuming work, especially when I only do 30 min per day.
Rob
On the bench:  Revell 1/72 HCMS Snowberry
cb1
    December 2009
Posted by cb1 on Thursday, December 1, 2011 8:27 AM
That tracker is AWESOME!
great job!
    March 2011
Posted by de havilland canada on Monday, December 5, 2011 1:03 AM
Maxfax the fuse color is RAF Sky Type S,not correct for RCN but I jumped the gun so there it is ,hence my comment about not totally authentic(my bad)
Thanks for compliments all!
Yamato I will try to get them out in natural light if we get a sunny day soon!
Cheers
Martin
    September 2008
Posted by maxfax on Tuesday, December 13, 2011 9:31 PM
Hello everyone, if anyone is watching!
It has been awhile since my last update- but it has been slow going. I have added all the internal ribs with holes that can be seen from the flood/drainage holes. Added the saddle tank extension piece on the port side, and will add the starboard side soon. There will be further vertical supports added here, then I will re-attach the part of the hull above the slot(I had a knot in my stomach when I removed that part). I also added a small part of the saddle tank visible through the three drainage holes above the rear saddle tanks, including vertical supports. I had to rework the torpedo insert- I added some spare PE and rod to somewhat create part of the mechanism used to open the inner torpedo doors. The door itself is hidden when the outer torpedo door is open, so I did not create one. I also added a "roof" to the torpedo section.  Next is to add the saddle tank extension piece to the hull, then fit the three interior sections and glue the hull together. That will be the next update.
Rob
    July 2008
Posted by vetteman42 on Tuesday, December 13, 2011 9:55 PM
WOW Maxfax all that attention to detail is going to pay off BIG TIME in the end Bow Down Your sub looks like it will be going for sea trials one day, outstanding work !
    October 2008
Posted by bsyamato on Wednesday, December 14, 2011 4:06 AM
What the .. !!!! IndifferentIndifferentIndifferent
this is an high class detail touch YesYes
    September 2008
Posted by maxfax on Friday, January 6, 2012 2:27 PM
Finally got the hull together. I made part of the hull visible through the lower stern drainage slots out of a pie plate and the baffle out of stock styrene. I also added stock stryene to cover the spaces between the modules to simulate a pressure hull- hell. you can barely see it anyways through the slots. I will have some trouble placing the front deck- the hull halves are too far apart and I really have to squeeze the sides together. So much for dry fitting before I glued the halves together!. Up next- place the rest of the supports seen through the slots, glue to front deck down. glue the removed parts from above the main drainage slot and create supports visible through the slot, add some piping -mainly for the exhaust- again can hardly bee seen, then the rest of the deck.
Rob
    October 2008
Posted by bsyamato on Friday, January 6, 2012 4:15 PM
huge and fantastic YesYes
i suppose you finished your plastic sheets stock Cool
    September 2008
Posted by maxfax on Friday, January 6, 2012 8:20 PM
I have been eating up my extra stock, that is for sure. After I get the deck on, that should be it for any scratch work- it will just be assembly, and hopefully will progress quickly- I have too many things to build- although I may add an aftermarket deck gun....still thinking about it!
    October 2009
Posted by greentracker98 on Saturday, January 7, 2012 6:39 AM
Thanks for the encouraging words everyone. I haven't touched it recently, but i plan on picking it back up again today. There's not much left to do, maybe I can wrap it this weekend.
A.K.A. Ken                Making Modeling Great Again
    October 2009
Posted by greentracker98 on Saturday, January 7, 2012 6:45 AM
BTW what is everyones view of Lindberg's 1 72 scale Japanese Sub I 20 & I 53 ? I got all excited to think I could do a US, a German, and a Japanese WW2 sub; all in the same scale. I'm planning on the German sub anyway.Yea, i read a couple of reviews on the Lindberg kit.
    October 2008
Posted by bsyamato on Monday, January 9, 2012 4:30 PM
never see these kits Huh? but when think to lindberg kits i don't expect great things
my ridicolous update here Embarrassed
A red was used on another kit and take advantage to paint the relative seabat red parts .... enamels costs Whistling
not founf actually a correct color for the high visible red but i have the impression that another thinned layer on the same red (under color was white) can approach to the definitive acceptable color
heres the real from airliners.net
ps the red in my picture is not so glow from real , was a camera flash artifact Black Eye
    October 2009
Posted by greentracker98 on Friday, January 20, 2012 3:04 PM
I forgot one thing when doing the USS Cobia SS 245, the part lines. Since I have everything on the deck glued down (except for the conning tower) it makes it harder to sand down the putty. Here is the devolopment on this so far.
    October 2008
Posted by bsyamato on Monday, January 23, 2012 5:57 AM
Nice save on the deck Yes
    October 2008
Posted by bsyamato on Friday, January 27, 2012 9:11 AM
here i am!!
too few updats about seabat, i planned bad this project and comes really slow even withouth significant mods on
Main colors on
the yellow stripe on and started to paint gears and minor pieces. Also cleared some paint mistake on clear parts with a toothpick
Corrected also the paint on the nose... i extended too much the red area Whistling
    October 2008
Posted by bsyamato on Tuesday, January 31, 2012 7:22 PM
First clear layer on, after a strike of weathering shading
    October 2008
Posted by bsyamato on Friday, February 3, 2012 5:25 PM
more seabat updates
decals on , the sheet was poor but great quality
and panel lines washing, again to fix some other line
gears already painted, now remains rotors
    October 2008
Posted by bsyamato on Saturday, February 4, 2012 5:10 PM
final laps
fixed the broken main rotor (newbee mistake i performed Embarrassed )
painting rotors and matt layer on the copter
tomorrow will finally glue the gear and minor parts
    September 2008
Posted by maxfax on Monday, February 6, 2012 7:06 AM
Bsyamato: Nice work. Looks like you will be done this GB soon! I almost have the deck on the VIIc, lots of fiddling with the supports seen through the main drainage slot. Maybe another week or so I'll get a pic up.
    October 2008
Posted by bsyamato on Monday, February 6, 2012 9:12 AM
Thanx  Maxfax, the seabat was a little careless and it's time to finally bring out the workbench Cool
some update
Then... i lost the finished blades control disc of main rotor Bang Head unexpected scratchbuild needed
tail rotor will also receive metal rods to replace original parts.
painting some missed detail from italeri as external tubes with brass rods and the tail light scratched from clear sprue
Hope not need to replace other parts Tongue Tied
    June 2009
Posted by kermit on Monday, February 6, 2012 12:13 PM
Bsyamato,
Great work on your Seabat my friend and nice save Wink She looks gorgeous sofar and everytime i see her it makes me think about doing a helo model of my own... Maybe a chinook or AH64 in dutch markings... Stick out tongue
Maxfax,
Looking very much forward to your next update! I soooo want to build another 1/72 one myself now that i know they are in production again... I also read that by the end of the year revell is going to reissue the snowberry again too. Yay!! Yes
Guys,
I must apologize for not being active on the forum for ages now... I am currently enjoying a long vacation in the US and the place i am staying at only has dial up internet making a forum like FSM with all the pictures a very daunting task to update and follow.... I will be back in about two weeks Wink
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    October 2008
Posted by bsyamato on Tuesday, February 7, 2012 9:57 AM
Thanx Kermit, have a nice vacation there Toast
if you build a copter my opinion is about chinook Stick out tongue
more updates here
compass cutter work
first fitting test
and the two rotors fixed!
just waiting the CA glue dry and refine after
Metal rods painted and fixed on fuselage
this is the bottom pieces from the kit someone knows where's the correct position to glue it? i found few and not clear picurer of this helicopter for a correct fix
just to show seabat with rotors Big Smile
few pieces left to finish
    July 2008
Posted by vetteman42 on Tuesday, February 7, 2012 11:13 PM
Bsyamato your chopper is really looking great man. Your extra work you do on all that detail really pays off in the end result. Keep the pictures coming !!!!
Kermit ya came out of hibernation early !!!!!!!! Hope you are having a blast, we been missing you around here ya know.
    October 2008
Posted by bsyamato on Friday, February 10, 2012 6:38 PM
Thanx Vetterman Toast really happy to score another finished model before the end for my first GB of ever.
so... more updates and more wall head hitting Bang Head this afternoon painted and added other details included the rescue hook. This night returned on the workbench after billiards session i picked the seabat and the hook was not here where i glued it! the only scientific explain is an alien abduction Alien so tomorrow another scratched piece is needed Angry
then pictures with wheels , rescue hook lifter and other details painted
At the end glued also the bottom tubes. Some italian seabat shows more details added on the fuselage but not found clear pictures to perfect complete these pieces, so i leave the copter withouth for the moment.
I hope this weekend to finish the good copter Cool
I feel like want a third version in future of the 58 kits Stick out tongue
    July 2004
Posted by stikpusher on Saturday, February 11, 2012 4:29 PM
BSY, your Sikorsky is looking real good there!Stick out tongue Definitely some classic lines on that bird.
I realized that my work here had been sidelined for too long last weekend so I pulled out my two Type VII U-Boats. Everything was there for the VIIA, but I seem to have lost the directions and decals for the VIIC in last summers move. The instructions are no big deal, as I was able to download a new set from Revell Germany, but the decals...Hmm I emailed them early in the week about replacements but have not yet heard back from them. So based on the instructions I do have and off the information in this article http://www.artitec.nl/downloads/instructions/uboat/uboat_colours.pdf I began painting of my U-Boats earlier this week. On the VIIA, which I am planning on finishing as U-29, I am going with the early war scheme of Dunkelgrau 51 over Schiffsbodefarbe III Grau. The VIIC will be the U-81 and in a two tone camo scheme of Hellgrau 50/Dunkelgrau 53 over Schiffsbodenfarbe III Grau. In both cases I have airbrushed on only the lighter color using MM Acryls over Humbrol primer. On my days off this week I plan to mask off for the darker hull and deck color.
anyways a few pics...
the VIIA
the VIIC
and both boats,,, unfortuantely due to lighting any camerathe contrst between the colors does not appear as well as it does to the naked eye.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
