Airfix Group Build 2011-2012
    October 2010
Posted by Casper the Chihuahua on Wednesday, August 31, 2011 6:48 PM
Picked up the Airfix Sea Harrier yesterday, Gods it's a monster!
Note the pot of Tamiya paint to demonstrate scale.
Cheers
On the bench: A-4F 1/32 Hasegawa
Just deployed: F6F-5N Hellcat Nightfighter 1/48 Eduard
Up next: A6-E Intruder 1/48 Revell
    March 2010
Posted by Scorpiomikey on Wednesday, August 31, 2011 7:40 PM
Shes certainly a monster, i expect step by step WIP photos from you on this one, i wanna see exactly how it all goes together lol.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    October 2010
Posted by Casper the Chihuahua on Wednesday, August 31, 2011 7:43 PM
Of course, I've got the Flightpath set in the post, ordered it last Saturday. Mind you I possibly won't be getting onto this bird until early to mid-2012
Cheers
    March 2010
Posted by Scorpiomikey on Wednesday, August 31, 2011 9:35 PM
AND GO!
Day 1. 20 participants vie for the top spot.
How many more will join?
How many will complete their builds.
stick around and find out. 12 exciting months of
AIRFIX
AIRFIX
AIRFIX
My signature
    April 2011
Posted by Jafa on Thursday, September 1, 2011 4:53 AM
How about  first edition (1396?) Hurricane, I have the opportunity to buy the kit, but doubt I would make it up it's almost as old as me
Kia Kaha
Posted by VanceCrozier on Thursday, September 1, 2011 6:52 AM
http://i1093.photobucket.com/albums/i438/smcintyre11/Harrier%20FRS1/849c0472.jpg
Cheers
in 1/24th?!?! Wow, that's a beast!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    March 2010
Posted by Scorpiomikey on Thursday, September 1, 2011 3:38 PM
Jafa
Kia Kaha
Shouldn't stop you making it, as far as im concerned every kit deserves to be built. Age and rarity doesn't matter. If you that worried about it, make resin castings or vacform moulds from it.
My signature
    October 2008
Posted by bsyamato on Thursday, September 1, 2011 5:12 PM
no one start? Hmm
i start! Stick out tongue
the previous glued piece
and now continue:
The rotor head repair, i drilled the center of two pieces and put a metal wire with ca
glued , sanded and bended the blade ,the poor instruction report a wrong thing
the rotor hub need to be cut in the upper section, the last section is too tiny to fit in the hole and the rotor will too high without the cut
Dimension measuring, the scout is really little but the ka-18 is actually the smallest kit i have
don't want to put too many mods on the scout but at least some work is needed on poor detail; for now added the rotor head command arms and placed some piece at the rotor base, picked references from prime portal, here a picture of real rotor  .
that's all for the start .
Posted by VanceCrozier on Friday, September 2, 2011 6:58 AM
bsyamato
http://i405.photobucket.com/albums/pp139/bsyamato/modellismo/scout%20airfix%2072/100_7975.jpg
And bsyamato is on the job! Nice work on the rotor head. Yes
(I wish I had a bench I could only use for modeling & have looking like that whenever I wanted! The wife wouldn't be too happy finding the kitchen table looking like that!!Embarrassed)
    October 2008
Posted by bsyamato on Friday, September 2, 2011 6:53 PM
VanceCrozier
 bsyamato:
At least i have lots of rooms in my house but as you see my workbench is a large mess Surprise it's a room already filled of old things and tools left on the earth by my beloved father. I use the kitchen just on decals stage.
Some news on the scout, i'll try to not add too many pieces on this helo but some pieces is needed.
Structures added on the rotor base, and cutted all the glasses ,the original fitting was impossible without leave a millimeter between clear parts and the exterior of fuselage.
unfortunately clear parts are litter than frames and a filling with some clear will needed after.
A test fitting of main parts shows as the canopy don't fit so good fit in horrible way on the kit
if not save the original with some sanding (or not airfixing the kit by a good catapult lauch on the first wall i see) a new heatformed canopy will needed.
that's all for this
    April 2011
Posted by Jafa on Friday, September 2, 2011 11:15 PM
so I started looking closely at this little Spit and the first thing I noted was the over sized rivets around the engine cowlings, these will need some serious "adjustments"
The second thing is the "crop circles" on the underside of the wings, any one know what theses are supposed to be? they appear too symetrical to be merely flash/ejector pins.
 I will take to the Spitfire GB to ask as well
Thanks guys
Jafa
    April 2010
Posted by Theuns on Saturday, September 3, 2011 1:30 AM
Hey Jafa.
Those rings are actually supost to represent the round inspection covers that were located to be able to inspect and maintain the inside of the wings.Theu are as usual (like the massive rivets, that is actuallt supose to be camlock screws) way overdone.
Airfix 1/72 Spitfire Mk9
You can just see them on my 1/72 Airfix Mk9. On the new tooling atleast they are scribed.You might lightly sand them justto take the worst "look" off, weathering will show them off then again.
Theuns
    June 2008
Posted by lewbud on Saturday, September 3, 2011 11:21 AM
Work has commenced on the classic Mk.Ia.  The wings are together, and the cockpit area has been primed.  Will shoot it with some b.i.g. when I get home from work tonight.  Did a trial fit of the fuselage to the wings and it looks like there will be some interesting fit problems.  If I wanted easy, I'd build a Tamiya kit.  For those of you building the classic kit, cut off the locating pins in the wings.  It will make your life easier.  Pics later.
Buddy- Those who say there are no stupid questions have never worked in customer service.
    April 2011
Posted by Jafa on Saturday, September 3, 2011 6:04 PM
Yup work has commenced on mine also, and I reached the same decision for the wings, one is pretty good, the other needs the main locator pin removed (or the gun ports become an interesting shape).
I hope to get some colour in the cockpit today, once i decide what colour it should be.
I have also removed the locator ridges on the fuselage/wing joint as they were pushing the wing out of alignment. still going to have some fun filling to do.
    April 2011
Posted by Jafa on Saturday, September 3, 2011 6:14 PM
Scorpiomikey
After a wee bit of interest in the feeler thread im posting a proper GB here with all the rules.
Lets get into it.
1. Must be an airfix kit. Can be from any time period, any tooling, as long as its branded airfix. (you can even paint up the original airfix combs if you really want, lol)
2. If you have a kit that is branded differently but is deffinatly an airfix tooling, if you can prove this i will accept it.
3. Start Date will be sept 1st 2011. This gives enough time for people to prepare.
4. End date will be Sept 1st 2012. Plenty of time to work through the more complicated kits.
5. When signing up please post Kit name and scale.
6. It can be OOB or as much AM or scratchbuilding as you desire.
Ill have a badge up before the start date.
Off we go people.
Enjoy yourselves.
Thanks to VanceCrozier we have a badge. If anyone has any special size requests feel free to ask him.
http://i1012.photobucket.com/albums/af250/VanceCrozier/GroupBuildBadges/airfix-GB_logo_250px.jpg
Same rules as always, save the badge to your own personal image hosting account before putting it in your signature. A completed entry is required before you may take the badge.
Well its Fathers day and the kids decided on a simple solution.....
So expect a few more Airfix kits to added to my build list if I may....
    October 2008
Posted by bsyamato on Sunday, September 4, 2011 4:40 AM
Jafa
 Scorpiomikey:
Lets get into it.
Off we go people.
Enjoy yourselves.
http://i1016.photobucket.com/albums/af289/Pinetree_fella/Avenger%20Build/AirfixGroupbuild.jpg
please add the bv 141 at least Stick out tongue
    June 2008
Posted by lewbud on Sunday, September 4, 2011 10:29 AM
Got all the scoops on the bottoms of the wings.  Beginning to see a pattern, looks like all the guide pins are going to go as removing them seems to make life simpler.  Jafa, I was thinking about doing that on my fuselage.  I found that removing the one on the starboard side and leaving the port side alone, everything fit a little better.  Still going to need some shimming though.  Good thing is you can drop the seat and floor into the cockpit from the bottom after the fuselage is glued together.  Does anyone here know if the insides of the canopy frames were black or interior green?
    June 2008
Posted by lewbud on Sunday, September 4, 2011 11:15 AM
For those interested in the history of Airfix's first model here's an interesting link.
http://www.sworld.com.au/steven/models/spitfire/
Cockpit is now interior green, fuselage will be together once the paint dries.
    October 2008
Posted by bsyamato on Sunday, September 4, 2011 12:32 PM
nice link lewbub!
some new work on the scout:
Sanded the clear parts with fuselage after filled gaps with humbrol gloss clear
works on the seats and ip total replace, also losed original holes, the cloche's hole (even if on helicopter are not a cloche) is in wrong plae, also added tail rotor pedals and other things
i hope clear parts allows to see something when finished all Surprise
    June 2008
Posted by lewbud on Sunday, September 4, 2011 2:16 PM
Here's some pics of the Mk.I under construction.  Having so much fun, I've busted out the Mk.IX as well.  The Mk.I will stay in Airfix's fictional scheme while the Mk.IX will be Johnnie Johnson's aircraft.
    April 2011
Posted by Jafa on Sunday, September 4, 2011 2:49 PM
What colour/paint did you use for interior green? I havn't build a RAF aircraft in nearly 40 years so need some input please...
Thanks
Jafa
    June 2008
Posted by lewbud on Sunday, September 4, 2011 3:29 PM
Jafa,
I used Model Master British Interior Green.
Posted by VanceCrozier on Sunday, September 4, 2011 5:22 PM
bsyamato
 Jafa:
 Scorpiomikey:
Lets get into it.
Off we go people.
Enjoy yourselves.
Those kids obviously deserve a later bedtime my friend!! That Bv141 is on my wish list as well, I need one to sit beside my Fw189 - a pair of flying eyeballs!!
Posted by traveller on Sunday, September 4, 2011 7:23 PM
Finally all my AM parts are in, should make a start in the next day or soDevil
    April 2011
Posted by Jafa on Sunday, September 4, 2011 7:35 PM
The BV141 is a nostalgia trip for me, had one about 40 years ago as a model, so keen to redo it, it is definitely on the sooner rather than later list.
The Hurricane wasn't on my wish list but the boy child (22 yr old) added it as he knew I was building a BoB Dio around the control tower and spitfire. But the Hurri comes with Irish Air Corps markings so thats going to be the scheme I run with for that.
The two Bedfords are going to get some special treatment with the QLD getting a Milicast conversion to a Bofors tractor, the QLT might stay as a "drooper" but may get some radical surgery and become a half track (depends on whether I can find a universal carrier at a reasonable price.)
    March 2010
Posted by Scorpiomikey on Sunday, September 4, 2011 7:52 PM
So do you want me to add those builds to the list?
Hope all you dads had a great fathers day, and all those with dads made an effort.
Me and my partner cooked my dad Chicken Cabonara for dinner, then apple pie and custard for desert.
My signature
    June 2008
Posted by lewbud on Sunday, September 4, 2011 8:54 PM
Well, she's starting to look like a Spit.  Still got some prep to do, but she should be ready for primer soon.
    April 2011
Posted by Jafa on Sunday, September 4, 2011 8:57 PM
Please add
Irish Hurricane
BV141
and the control tower,
The rest might be later in the year as time and inclination permits.
Cheers
Jafa
    March 2010
Posted by Scorpiomikey on Sunday, September 4, 2011 10:24 PM
Sorted.
That scout looks fairly typical of airfix. Ends up more filler than plastic lol.
That really is a first edition spit, blue plastic and all.
My signature
    August 2005
Posted by Phil_H on Sunday, September 4, 2011 11:16 PM
Scorpiomikey
Actually, it's the 1979 tooling. There was a special "50th Anniversary" version of this kit issued in blue plastic in 2003, the original 1953 moulds being long gone.
