MONOGRAM MAFIA II GB
    January 2010
Posted by CallSignOWL on Thursday, October 4, 2012 4:33 PM
I present my second completion, Don Hammer!
Revell's 1/72nd scale P-47  (date stampped 1999)
Now that I'm here, where am I??
    February 2010
Posted by 68GT on Thursday, October 4, 2012 5:59 PM
You wern't kidding Owl,
That Thunderbolt came out great!
Tags: 47
On Ed's bench, ???
    December 2006
Posted by Fly-n-hi on Thursday, October 4, 2012 6:07 PM
Nice work!
    July 2007
Posted by troublemaker66 on Thursday, October 4, 2012 6:36 PM
OWL....Nice P-47 !
Stik.....TBD is coming along nicely.
Len Pytlewski
    January 2010
Posted by CallSignOWL on Friday, October 5, 2012 9:44 AM
thanks guys! :)
    July 2008
Posted by vetteman42 on Saturday, October 6, 2012 12:41 PM
CallSignOwl love your P-47, but have to ask how you make such a small, tiny kit look so good and so much larger, I would swear its a 1/48 kit.
My Stuka will fit in Stick out tongue copyright is 1968.  So this one will be a simple OOB build, I need a relaxing build at this point. I have the pit in and the fuse closed up, and the wing is glued. Just need to clean up the seams, as you can see I have filler on already. Then its time to fit the canopy, I am going to close it on this build, and get the wing attached to the fuse.
I am going to try a winter camo for the Russian front on this one.
Randy So many to build.......So little time
    January 2010
Posted by CallSignOWL on Saturday, October 6, 2012 12:44 PM
vetteman42
Magic Wink
    December 2011
Posted by Big_Dog on Sunday, October 7, 2012 12:47 PM
Well I finally was able to return to the bench yesterday and got some good progress made on the P-40. I figured since the real things had the location of the British Roundels masked out in the camo job using the decals of those for that purpose would work. This is a progress hot after the dark green was completed. The first coat took about 3 hours or so to do to get the pattern right. I went by the profile drawings in "Colors and Markings of the AVG" for the most part and referred  to prototype pics for the tail since these varied greatly.
I am about to see if I can remove the decals like I hope and finish what touch up painting needs to be done during today's NASCAR race. I think I may not have soaked one of the decals quite enough and it has more glue on it that I desired, hopefully it will still release without too much fuss. I want to get this to the gloss coat stage today so I can get the weathering and such done before adding the canopy. The early P-40s had a fuel tank that was filled through a hole in the port side window and period pics show lots of streaking from spilled fuel under the glass so that needs to get done before I close that area up. I also have the stuff I need more or less for the dio base. I need to go back and see when I started this one as it may be over on time but I still want to finish it here.
    April 2005
Posted by taxtp on Sunday, October 7, 2012 5:57 PM
Really good looking Thunderbolt, Owl.
I'll be interested to see if the decal masking technique works well Big_Dog. I've always cut out circles of masking tape with my P-Cutter for that purpose, but maybe your way will save some time for the same result.
I've finally got a primer coat onto my 1/32 Mustang. This is a very basic little kit, and is also another attempt at the very first car kit I tried, back in the late seventies. I don't have the original kit any more, but as there are only four car kits that I built and didn't retain, I am going to go through the process of adding them to the collection once more. BTW, the original builds weren't of a standard that I would accept these days anyway.
Anyways, here is the first progress shot. I'll try the gloss white coat tonight if all is well.
Cheers
Tony
I'm just taking it one GB at a time.
    December 2011
Posted by Big_Dog on Monday, October 8, 2012 1:46 PM
Well I got caught back up last night on what all is going on and checked when I started the Ha-81 A3, which was mid March so it has gone over on time. Like I said I still am going to finish it here even if it may not count. As far as the decal masking experiment that was a great success, even better than masking tape for a brush painter like myself. The decals are thinner than masking tape so there is no raised "lip" for the paint to pile up against to create a thick spot at the mask line. The decal I was worried about did take a bit of work but nothing major. On this one the film wanted to peel up leaving the pigment behind. A bit of scrapping with a toothpick removed all but a few spots of pigment that I just touched up over with paint. For this technique I would recommend forcing yourself to wait until the decals almost float off the backing. For the side that I gave more time to it peeled up with no problem although I did have to exercise some care painting around this one as the decal wanted to lift. Also not only were the decals thinner for less of an "edge" they also conformed to the raised rivets MUCH better than masking tape and there was no creep under the decals.
@ Vetteman42  The sprint car turned out great. I have been watching that one since you started it and was wondering whatever happened with it. Shame it went over on time, as it is a very nice build. I need to find me some of those 1/48 Stukas; that is one of my girlfriends favorite planes and if I find one I will have to get her one too.
@ Owl  Killer job on that jug. Looking at it it just screams 1/48 scale, very well done.
@ Fly-n-hi  Looking forward to seeing how that F-20 turns out.
@ Stik  I have a soft spot for the early war Navy schemes, something about that blue gray with the red in the markings.
@ taxtp  Another one I am watching since I can't build car kits, to me, mine seem to look like car kits. Plus I am a gear head and a Ford guy ( I have a 1970 F100 with the 300 6 and a granny 4 speed.)
    April 2005
Posted by taxtp on Monday, October 8, 2012 3:10 PM
The Mustang has received it's coat of gloss white. I haven't bother ed to photograph it as itlooks just the same, or , at least, will photograph just the same.
Cheers
Tony
    July 2004
Posted by stikpusher on Monday, October 8, 2012 3:47 PM
I hear ya. I am working on some shims along for the mating surfaces of the inner upper wing halves to the fuselage. No gaps this time!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    July 2004
Posted by stikpusher on Monday, October 8, 2012 7:57 PM
Here is the shim on the most offending wing upper half, the right wing. Sanded down a bit.
Then placed on the lower wing/fuselage to show how it mates up for this photo...
and the left upper wing placed so that it is showing the much thinner gap in that side that will need a shim.
       - Plankton
LSM
    June 2008
Posted by Hans von Hammer on Tuesday, October 9, 2012 3:26 PM
vetteman42
Don Hammer will this one fit in for a second build ?
Hell yeah..
    June 2008
Posted by Hans von Hammer on Tuesday, October 9, 2012 3:33 PM
CallSignOWL
Shoot that one again, Owl! Just make sure the sun is behind you to light the Jug and the cars and the big tree (far trees are OK) are outta the frame!  I LOVE that pic otherwise!
Well done, especially for a Brail-Scale kit!
    June 2008
Posted by Hans von Hammer on Tuesday, October 9, 2012 3:36 PM
Good eye.. That's a detail that many folks overlook.. Kudos for mentioning that detail.. Proof that research pays off.
    June 2008
Posted by Hans von Hammer on Tuesday, October 9, 2012 3:38 PM
troublemaker66
Wait a minute...you skip out on us without so much as a "kiss my ***" and think you can just waltz right back in here and act like nuttin`s wrong.......
...`bout time ya showed up slacker.....
Slacker??? Why,  I oughtta...
    January 2012
Posted by Cdn Colin on Tuesday, October 9, 2012 5:32 PM
Here's the third of my hatrick.  I've got the cockpit put together, and this is the first time I've scuffed up the floorboards.  I'm doing it up as the P-400, 'cause I gotta put the shark mouth on it!
i47.photobucket.com/.../DSCF1146.jpg
i47.photobucket.com/.../DSCF1152.jpg
i47.photobucket.com/.../DSCF1149.jpg
I build 1/48 scale WW2 fighters.
Have fun.
    July 2004
Posted by stikpusher on Tuesday, October 9, 2012 6:44 PM
Minor progress so far today. I added the shim for the left upper wing last night and cleaned it up today. And then it was time for some Squadron White putty into a couple sink marks.
       - Plankton
LSM
    January 2010
Posted by CallSignOWL on Tuesday, October 9, 2012 6:54 PM
Hans von Hammer
CallSignOWL
That actually is the best angle. The other way is an even closer parking lot, a parking garage, a picknick table and a basketball court!! There arent many good places to get pics on campus....
    July 2004
Posted by stikpusher on Wednesday, October 10, 2012 12:21 AM
A bit more work before calling it a night at the bench for me tonite.
The real TBD had four little braces on the inner surface of the upper outer wing panel between teh two hinges that are visible in this photo that are not molded in the kit.
No worries, some strip styrene to the rescue. I guesstimated their size based off of a few photos in books, then made four triangular braces for each wing. a quick hole drilled with my pin vise for the lightening holes and cleaned out a bit with a twirled x-acto knife. Glue into place based off the same reference photos and done.
and then placed (I did not want to glue) for a test fitting on the build so far and some quick photos.
I also sanded the puttied up sink marks smooth
       - Plankton
LSM
    June 2008
Posted by Hans von Hammer on Wednesday, October 10, 2012 12:33 AM
Nuthin' wrong with the angle.. Good shot there..
Just talking about getting the light behind you... The other stuff can be taken out later, if needed..
Rough example..
    June 2008
Posted by Hans von Hammer on Wednesday, October 10, 2012 12:36 AM
Not a fan of folded wings, but "WOW!" Stikker... Out-freakin'-STANDING!
    July 2004
Posted by stikpusher on Wednesday, October 10, 2012 12:49 AM
Thanks boss. I think I first built this kit when it was newly released, and it is still one of my favorite Monogram kits to this day. Especially the folding wings part. But I do wish that I had found that LIFE photo a couple hours ago. Different angle and the best one I have yet seen of the wingfold detail. That's OK though, I still have another one of these beauties in my stash...
       - Plankton
LSM
    June 2008
Posted by Hans von Hammer on Wednesday, October 10, 2012 1:02 AM
Cdn Colin
Here's the third of my hatrick...  I'm doing it up as the P-400, 'cause I gotta put the shark mouth on it!
Just a little trivia..
My uncle, then Captain John Thompson, was the pilot of that P-400 depicted in the kit..
CPT John A. Thompson-67th Fighter Squadron, 347th Fighter Group. Cactus Air Force at Guadalcanal, 1942..
    June 2008
Posted by Hans von Hammer on Wednesday, October 10, 2012 1:05 AM
Yet another LIFE magazine photo I'm stealing from you, lol..
    January 2012
Posted by Cdn Colin on Wednesday, October 10, 2012 3:41 PM
In that case I'll try extra hard not to foul it up!  How many of these kits have you built over the years?
The whole Cactus Air Force stroy is fascinating, especially the ArmyAir Force's role in it.
Have fun.
    July 2004
Posted by stikpusher on Wednesday, October 10, 2012 8:12 PM
Colin, have you read the book The Cactus Air Force? I forget the authors name, but I do recall it being a very thorough account of the air battles during the Guadalcanal Campaign, including all the carrier battles and the Japanese views.
Today was a bit of progress on my TBD. Early on I got the upper inner wings glued on, which of course traps the folding outer wing panels in place. After the glue dried  I did the seam clean up on the leading edge. With all the associated needle file work in the corrugated area...Tongue Tied
Then it was time to begin painting the Mk.XIII Torpedo. I used Humbrol Brass for the body as color photos show this was a good choice
File:TBD T-5 VT-8 CV-8 15May42.jpg
And then I used Humbrol Oak for the "orange crate" wooden box around the fins. I will mask off and paint the warhead light gray after letting the Brass color dry overnite.
       - Plankton
LSM
    February 2011
Posted by Reasoned on Thursday, October 11, 2012 6:10 AM
Those wings look smooth in that pic.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    June 2008
Posted by Hans von Hammer on Saturday, October 13, 2012 6:32 AM
Cdn Colin
Uncle John stayed with me and my wife for a couple months last winter.. I picked his brain pretty much clean (figuring I may not have another chance..)... The stories he told of life and the conditions on Guadalcanal were mind-boggling..  And I've been in some real sh*t-holes around the world, believe me.. (He STILL hates rice to this day, lol..)
There's only so much one can out into words, spoken words anyway, and without the sights, sounds, and yes, smells of a combat zone, the words just don't tell the whole story... No civilian who spent his life in Ft Living Room can say honestly, "I know what ya mean."...  (And it's not the civilian's fault..)
Anyway, I managed to convince him to do an "Oral History" of life in the Cactus Air Force for the CAF's American Airpower Museum and sent it off to Midland, ricky-tick, lol..
I think I've built that P-400/P-39 at least ten times in my modeling lifetime, lol.. The last one was about two or three years ago..
Would't be right if'n I left John out of the shot, lol..
Another thing about John.. He's 5'11" tall.. The max-height of a pilot that a P-38/P-400 cockpit was designed to hold was 5'8', lol..  He spent some long, uncomfortable hours in that bird..
During the "Battle of Bloody Ridge", he flew several missions that day, providing CAS for the 800 Marines on the ground that were fighting against over 6000 Japs...  BTW, by then, September '44, the original squadron-strength of 14 Airacobras in the 67th was down to five flyable P-400s, due to the Japs constant shelling of Henderson, and only enough fuel for three that day...
Heck, rather than type, here's a story about the guy that flew that P-400 you're building..
http://www.ghspaulding.com/guadalcanal.htm
I didn't know about this stuff for years and years, until after I'd retired from the Army... He'd always say something like, "Yeah, I flew P-39s in the PTO" or, 'Yep, the 'Canal was a real headache. Them Marines really got hammered and we got shelled about every night"...  He did tell the tale of "Washing Machine Charlie" several times though, and always was funny about it..
