Ju 87 Stuka GB
Posted by Bish on Saturday, September 6, 2014 5:19 PM
They look pretty good there  aj.
    May 2013
Posted by Greg on Saturday, September 6, 2014 5:28 PM
Gary, she's coming along nicely. Sorry to hear about the layoff. Things will get better.
AJD, paint job is looking good from here.
    October 2008
Posted by Rigidrider on Saturday, September 6, 2014 6:16 PM
Gary... Ditto what Greg said, ...Hang in there bro...
When Life Hands You A Bucket Of Lemons...
Make Lemonade!
Then Sell It Back At $2 Bucks A Glass...
    October 2006
Posted by Archangel Shooter on Saturday, September 6, 2014 7:21 PM
Gary...good luck on finding something new, hope it's soon and everything works out for you. I'm being jerked around by the AZ DOC, was suppose to start the academy Monday morning (after being out 4 years) only to be told Friday afternoon I'm on hold till ???????? I'm doing a slow steam over that one.
I normally don't prime my aircraft builds, just the 1/6th figures but I think I will with this bird. And I will give that Tamiya surface primer a shot.
Still puttering around on the bird, have just glued the lower wheel assemblies to the wing and letting it set. Sanded some of the seams.   I was planning on using the Master Model Brass machine gun set for the wing guns but since I wanted to glued the access panels in the closed position, there was just a tiny portion of the gun barrel extending from the wing gun ports so I figured it would be a waste of a good set and I used the kit parts instead.
Will try to post some pics later.
 Your image is loading...
 On the bench: So many hanger queens.
    October 2013
Posted by ajd3530 on Saturday, September 6, 2014 11:45 PM
Despite the airbrush/paint problems, I have had fun building this kit. So much that I migbt try another. Dies abyone have anything to say about the Airfix Ju 87-B kit?
    October 2006
Posted by Archangel Shooter on Sunday, September 7, 2014 8:30 AM
AJ...Not sure what scale you're looking into but if you're wondering about the Airfix 1/24th kit, that's the one I'm working on here and I give it 2 thumbs up. It does have a few minor seam problems here and there but it does go together better than their other earlier 24th scale kits.
Posted by Bish on Sunday, September 7, 2014 9:28 AM
aj, if its the 48th kit, I believe that's a good one. I know Eagle is due to start his soon, so it might be worth keeping an eye on that.
    November 2010
Posted by Eagle90 on Sunday, September 7, 2014 7:36 PM
ajd3530
AJ, like Bish said, I have the 1/48 Airfix 87-B kit (A05100).  Got it as a gift from a very good friend...and you know who you are!  Wink  Thank you again!
She looks to be a great kit!  I did the Mono 87 not too long ago and it was a great kit, and this one looks to be even better!  Much more detail!  Can't wait to start her!  If you are thinking about getting the kit, do it!  I'd be happy to send you some pics of the kit and all if that would help in any decision making you might have.  Just let me know.
Eagle90
    October 2013
Posted by ajd3530 on Monday, September 8, 2014 12:29 AM
Well eagle, I had the same problem with the Printscale decals as you had. They just fell to pieces the moment they touched water. I'm not happy about it at all. I was really looking forward to having a Bulgarian Stuka, to stand out from the norm. So those decals were trashed, and my kit is a 1983 boxing, so the already suspect Monogram decals are 31 years old, and worked marginal at best. So I'm having to piece together decals of the Monogram sheet, a Hobbycraft 109 sheet, and an Eagle Strike 190 sheet. Needless to say, the end result not be a depiction of an actual Stuka.
Posted by Bish on Monday, September 8, 2014 2:57 AM
That a downer about those decals, was looking forward to a Bulgarian bird. Were they a new set of decals.
    November 2010
Posted by Eagle90 on Monday, September 8, 2014 6:48 AM
Hey AJ,
I hear ya.  I had never seen decals crumble so quickly before.  Very odd.  Don't think I'll be getting any from them.  Maybe it was just a bad batch or something.
Eagle90
    November 2003
Posted by tempestjohnny on Monday, September 8, 2014 11:15 AM
Well my bench has been calling my name. Went in for the first time in months. Cleaned the cobwebs. Might try working on the 87 soon. Good to be back at it. John
Posted by Bish on Monday, September 8, 2014 11:16 AM
Good to se you back John.
    March 2010
Posted by Nathan T on Monday, September 8, 2014 1:12 PM
I'm in the same boat as you Commander John. Hit the bench maybe twice all summer. Work is slowing down finally and the Stuka is calling my name. I did order some resin radios from Quickboost. They are made for the Tamiya Storch kit but they are the same type used in the Ju 87D. I should be able to just cut them out and use them somehow. I also have a Phantom and Starfighter calling me too though, so competition between the 3 will be tough...
Posted by Bish on Monday, September 8, 2014 2:03 PM
Good to se you Nathan, those radios should fit in easily enough.
    May 2013
Posted by Greg on Monday, September 8, 2014 3:24 PM
John, good to see you back.
Nathan, you too, my man.
    October 2006
Posted by Archangel Shooter on Monday, September 8, 2014 6:45 PM
A few progress pics here, it's coming along.
Got the cockpit glued to the r/h fuselage, sure hate to close her up
With the inboard wing stubs glued on.
With the landing gear installed, the tail is not glued yet till after painting.
Test fit of the 500KG bomb and release. Thought I had a real problem with the release arm as it did not fit the bomb until I realized there were two arms and I installed the wrong one, easy fix.
How it sizes up with the Monogram JU-87.
Need to get cracking on the engine now and I think that will be fun to tackle.
GAF
    June 2012
Posted by GAF on Monday, September 8, 2014 11:15 PM
Wow! Now that's a nice cockpit!
Posted by Bish on Tuesday, September 9, 2014 2:39 AM
That is one sweet looking pit shooter. I imagine its quite easy to see in there even when its closed up.
    October 2006
Posted by Archangel Shooter on Tuesday, September 9, 2014 4:09 AM
The nice thing about this scale and kit is that I can easily continue to detail the cockpit after the fuselage is put together. Would like to see Trumpeter come out with a JU-87 Tank buster to add to their 24th scale line.
    March 2012
Posted by mustang1989 on Tuesday, September 9, 2014 4:13 AM
Now THAT would be AWESOME!!!!! I don't know where I'd put it but I'd have to find a spot for that!
Thats some good pit detail there Scott and that thing is  a beast up next to that 48th scale job. Whew!!
 Forum | Modelers Social Club Forum (proboards.com)
Posted by Bish on Tuesday, September 9, 2014 5:34 AM
I know Trump are on about a D, but I believe its a D-3. But would not take much to produce a G-1 or G-2 from that. Now I would snap that in in a heartbeat.
    May 2013
Posted by Greg on Tuesday, September 9, 2014 11:41 AM
Shooter, it has been a real pleasure watching that beautiful cockpit come together. It looks great.....and I hear you re almost hating to close it up. As Bish mentioned, it will be nice to still be able to see in there (and even work on it, as you mentioned) at this scale.
Thanks for the reference pic next to the 1/48th, was really curious how big this thing actually is!
I wonder, could you or somebody tell me what the tan box on the left side, just forward of the rear bulkhead was used for? Looks like storage of some sort. My Eduard PE set comes with a cover to close it off completely, which I'm not understanding and will probably go with the kit cover which looks more like yours.
First rate work, Shooter.
Posted by Bish on Tuesday, September 9, 2014 11:45 AM
Greg, my guess is that that box is for the used MG drums, would make sense to some where separate to store them rather than try and re attach to the mounts and then get confused as to which were full and which empty in a hurry. The one in shooters is the best I have seen, in 72nd its normally just a box, but from the looks of shooters, I would say its fabric. I might try and scratch one of those when I do an B.
    October 2006
Posted by Archangel Shooter on Tuesday, September 9, 2014 12:06 PM
As Bish said, the basket is a dump bin for the empty ammo cans and I imagine the gunner would also sweep up the lose brass and toss it in there too. From the couple pics I seen of it on the net, it does appear to be a cloth bag, the instruction sheet calls for it to be painted a linen color.
Getting ready now to paint the engine, the sheet calls for it to be blue grey guessing RLM 66 but I may go with a semi-gloss or metallic black.
Posted by Bish on Tuesday, September 9, 2014 12:11 PM
I don't recall seeing a pic of that, so until Greg mentioned it, I hadn't thought about it. Good info guys, thanks.
    May 2013
Posted by Greg on Tuesday, September 9, 2014 12:28 PM
Thanks for the info on the empties box!
Shooter, be aware your cockpit pics are going in my reference file, and it's not too often pics of a model get in there!
    April 2013
Posted by SchattenSpartan on Tuesday, September 9, 2014 7:34 PM
Scott: And I thought 1/32 is way too big already... That cockpit looks fantastic and at the size of the kit it shouldn't be too hard to get a nice view of all the details in there!
Ajd: That paintjob is looking fantastic!
    September 2013
Posted by Raven728 on Wednesday, September 10, 2014 7:55 PM
Well, I was finally able to get started on my Stuka tonight after finishing up my other GB plane, an F4U Corsair, last weekend. It was more of a symbolic start, as I just sprayed the interior (XF-22 RLM Grey), but it's a start nonetheless.
- Steve
    March 2012
Posted by mustang1989 on Wednesday, September 10, 2014 9:01 PM
I was gonna answer that about the tan box  but the boys in the neighborhood here have it covered! Another reason I really like this forum....lots of friendly help.
