2014 SCI FI HARD SCIENCE GROUP BUILD
    March 2014
Posted by Señormodeler on Thursday, November 27, 2014 6:36 PM
Oops. Will try that post again later.
    September 2006
Posted by NucMedTech on Friday, November 28, 2014 11:14 AM
Okay, yep, that's looking great. Will be the awesomeness once you are done. Now excuse me while i go and shut my jaw.
Most barriers to your successes are man made. And most often you are the man who made them. -Frank Tyger
    March 2014
Posted by Señormodeler on Friday, November 28, 2014 9:53 PM
Thanks, man.
    April 2006
Posted by waynec on Saturday, December 6, 2014 5:05 PM
SENORMODELER that FALCON is looking great.
apologies for not keeping up with this. life and a big slump happened. my Springs club quarterly contest  for MAR15 is "outside your comfort zone" so i will get going on T-2  stuff with lighting. have a comart gray scale paint kit which should make for some interesting panel effects
BISH IS DOING A STAR WARS GB. IT IS COMPATIBLE WITH THIS GB SO, IF YOU HAVE A CROSSOVER AND IT FITS HIS RULES, GO FOR IT.
i will do a stars wars armored walker thingie in an "unusual" paint scheme.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    August 2010
Posted by Beckyhead on Tuesday, December 9, 2014 9:00 PM
Hey folks, sorry about the long time away. Had to move back to the States, retire from the Army and all that good stuff. Anyhoo, now settled, and continuing the build. I've completed the X-Wing pilot, using oils, mostly...and this is the first time I have used oils and painted figures!
    April 2006
Posted by waynec on Tuesday, December 9, 2014 9:13 PM
Beckyhead
welcome back. looks good. oils are fun though i have only used them for washes.
    February 2014
Posted by silentbob33 on Tuesday, December 9, 2014 9:47 PM
Wow, that Rebel pilot looks pretty good!
On my bench: Academy 1/35 UH-60L Black Hawk
Posted by Gamera on Wednesday, December 10, 2014 7:27 AM
Wow, he does look pretty awesome!!!
    January 2014
Posted by Rob S. on Thursday, December 11, 2014 6:08 AM
Love that Rebel pilot!!
______________________________________________________________________________
On the Bench: Nothing on the go ATM
    August 2010
Posted by Beckyhead on Thursday, December 11, 2014 5:03 PM
Great quad guns! Can't wait to see the completed work....now,  don 't get cocky! :>)
    March 2014
Posted by Señormodeler on Sunday, December 14, 2014 9:41 AM
Beckyhead, that Rebel pilot looks incredible. Great work!
I have a tiny tiny update...
I've got the engine lights rigged up and all of the fiber optics threaded through the lower hull. I still have to wire up the headlights, which has been more challenging.
I also was finally able to assemble the cockpit. I'm not all that happy with the decals that came with the ParaGrafix PE set. The colors are off... they're more red than black and gray. But with the backlight that I have built into cockpit behind the back wall, it'll be hard to tell what color the console is.
Thanks for looking.
Posted by Gamera on Sunday, December 14, 2014 4:32 PM
SM: That looks awesome, amazing you can pack all those electronics in there!
    August 2010
Posted by Beckyhead on Sunday, December 14, 2014 6:09 PM
That is one awesome cockpit! Great work!
    March 2014
Posted by Señormodeler on Monday, December 15, 2014 11:38 PM
Thanks, Gamera. I'm mainly just following other examples that I found online. It's amazing how much you can put inside a model.
Thanks, Beckyhead. There are a lot of fidly pieces that barely that barely hange together. But finally managed to put it together and glue it all in place.
    August 2010
Posted by Beckyhead on Thursday, December 18, 2014 12:51 AM
Okay, finished the priming and most of the X-Wing cockpit. Future dipped the canopy, now just waiting for the primer to completely dry, then I will do a little sanding to smooth the finish. By the way, does anyone have a better method of smoothing out the primer?
One very cool thing about the "snap together-ness" is that you can temporarily assemble parts, prime them, then take them apart for individual work. Makes things easier.
    March 2014
Posted by Señormodeler on Thursday, December 18, 2014 9:13 AM
Looking great! I can't wait to work on an x-wing of my own.
What kind of primer did you use? Tamiya?
Posted by Gamera on Friday, December 19, 2014 11:42 AM
BH: Cool!
Sorry, I have no idea how to smooth out rough primer other than fine sanding or buffing.
    March 2014
Posted by Señormodeler on Friday, December 19, 2014 11:48 AM
I did some work on the falcon. Mainly focused on getting the LEDs installed for the headlights. Had to dremel away some plastic and then secure the LEDs with a bit of additional styrene and white glue.
What's interesting is that the headlight Photo Etch from Paragrafix is specific to the 5' model, not the 32". The headlights on the 5' model are off center, but on the 32" they are centered. ILM continued to use the 5' model here and there in episodes 5 & 6, but mostly used the 32". If you look closely at the scene when the falcon lands at Cloud City in ESB it is clearly the 5' model --- indicated by the headlights. In most other shots, the headlights are centered.
I'm thinking of my model as a hybrid between the two different models. There's battle damage on the 5' that isn't on the 32" just to the right of the jawbox on the topside that I really love. So I'm including that.
Thanks for looking.
    August 2010
Posted by Beckyhead on Friday, December 19, 2014 3:32 PM
An observation about painting my X-Wing. There is so much debate out there about what color the X-Wing should be. Is it Lt. Gray, gloss white over black, bluish gray, etc? It's too much, and this debate will go on forever!
What many SciFi modelers do not understand is that models were painted in such a way to look more realistic and effective on camera. It's photography thing. Photos that many folks see of ILM building models for principal/FX photography look different because those photos were taken under different lighting and other filming conditions in a blue-screen environment, and the end result is based on processing, composting, film type, etc. Actually, this can go for any model before the advent of CGI. An example would be TOS USS Enterprise at the Smithsonian; it has a greenish cast yet it appears grey to white on the show. Remember, Gene Roddenberry had the world of Star Trek reflect some aspects of the US Navy...which as very, very grey,
In conclusion, maybe we should attempt to paint our models based upon the story tellers intent of the finished film. That is, what where the things the story teller or SF artist was trying to describe. I say the X-Wing was colored like most modern fighters of today. Light grey, lots of different panel shades due to wear and tear, battle damage and weathering. The rebel alliance (or certain smugglers) didn't have facilities to make their space craft look shiny and pretty. Therefore, that is what I am going to do...and to heck with certain forums and sites (except present company, of course!) Ah, Freedom!
    February 2014
Posted by silentbob33 on Friday, December 19, 2014 5:51 PM
I agree with you Beckyhead. There's not really a way to prove what an X-Wing "really" looked like. I typically paint mine white with a few light grey panels here and there, with the odd yellow ones too. Then I weather the crap out of it using pastels to create streaks and carbon scoring, so that Luke would think they've seen a lot of action.
    August 2010
Posted by Beckyhead on Friday, December 19, 2014 6:36 PM
Agreed SilentBob, and ya know, I'm going to just "trust my feelings" on this one.
    August 2010
Posted by Beckyhead on Wednesday, December 31, 2014 6:59 PM
X-Wing update. I've done some partial priming after I completed assembly of the main components. This is the tough part, what to assemble so I can paint the X-Wing properly. The kit went together for the most-part OK, but there are some problems with gaps you see until AFTER priming and assembly. (Sigh!).
    August 2010
Posted by Beckyhead on Wednesday, December 31, 2014 7:00 PM
    August 2010
Posted by Beckyhead on Wednesday, December 31, 2014 7:32 PM
Got a lot of work done this week. I completed panel shading using Tamiya Flat Black and Flat White and painted the exhausts Dark Iron. When complete I temporarily attached the canopy, and painted the whole ship FS 16440 Model Master Gloss Gull Gray. I used Testors thinner, and used a series of light coats with enough to barely cover the painted panel lines. I panted the nose Tamiya Radome Tan
When the paint was dry, I began the weathering process on the front end. Instead of using the decals, I masked and painted the marking for a more realistic effect. I began bringing out panel lines and initial weathering using Vallejo Black Wash. Word of advice, use only on glossy surfaces otherwise you will have a lovely stain you can't get rid of when used on a matt surface. However, I really like this stuff, and it really brings out the panels and adds more character to the X-Wing. I masked the canopy with Bare Metal and painted over the base gray with Tamiya Sky Grey. After some initial weathering on the canopy, I removed the Bare Metal Foil, cleaned up the glass with turpentine, and polished the glass to a nice shine (The canopy was Future dipped before masking and painting, by the way!)
Also also finished the Artoo unit, polishing up the primer with a fine sanding stick, then applying Mr. Metal Color chrome silver by brush since it's such a small area. I let it dry, then buffed to give it a nice shine. I hand painted the blue squares on top of the Artoo unit since the decal was useless, then applied the remaining decals with the help of MicroSol/Set. I brushed over the unit with a couple coats of Future to seal in the decals and finish. The "instrument unit" behind Artoo was given a wash of black oil paint thinned heavily, the drybrushed to pop-out the details.
 photo 20141231_163654_zpskyzdxwbg.jpg Right now, I am debating if I should use the decals for the Red 5 markings or use Frisket. I will test the frisket idea on one of the wings and let you know how it goes!
    February 2014
Posted by silentbob33 on Wednesday, December 31, 2014 9:09 PM
Looks great so far! I really like the weathering
    April 2006
Posted by waynec on Wednesday, December 31, 2014 9:26 PM
silentbob33
 i agree. it's art and i like the colors and the weathering. of course i don't know much about scifi (except for STARGATE, BABYLON 5, FARSCAPE, FIREFLY/SERENITY,THE HONORVERSE, THE FIRST FORMIC WARS) which may have been why i was the lead scifi judge at the last local contest. i will be starting on my T-2 HKT this week. less lighting than AHK.
if you want an insane color discussion, go to ships and ask what color the gunport line was on CONSTITUTION.
    August 2010
Posted by Beckyhead on Saturday, January 3, 2015 12:34 AM
Thanks for the compliments so far! Update on the frisket use. SUCCESS! Better than I thought. I took the sticker sheet that came with the kit, taped it down, then taped a sheet of frisket over the top of that. I simply traced each "red 5" marking with a fresh X-Acto blade, and weeded out the bits that need exposure to paint.
For frisket film, I used  Grafix All-Purpose Masking Film, clear, .002 low tack. This stuff is awesome! I did not affect the underlying paintjob, and I had no bleed through. I got the stuff at Hobby Lobby...yes, that Hobby Lobby.
I'm finishing up the rest of the markings, adding the rest of the decals...and still deciding if I want to install the landing gear with the "s-foils" in non-attack position, or mound as if in flight with a nice wood base and brass rod supporting it....
Next steps:
Final painting, little weathering and dry-brushing and decals, gloss coat, oils, flat coat. Done.
    February 2014
Posted by silentbob33 on Saturday, January 3, 2015 7:12 AM
Looks better and better! I'll have to pick up some of that masking film the next time I'm at Hobby Lobby
    January 2014
Posted by Rob S. on Saturday, January 3, 2015 3:32 PM
That X Wing is looking absolutely spectacular..what a build!
    March 2010
Posted by mach71 on Sunday, January 4, 2015 9:19 AM
Nice job on the X-wing so far!
She is looking great.
