Monogram Mafia III
    October 2004
Posted by ygmodeler4 on Sunday, July 27, 2014 12:07 AM
MV that car came out looking great...and Darrin your progress is looking great, I'm not so sure your signature holds true in this one I'm afraid I'd be way behind where you're at right now!
-Josiah
    October 2004
Posted by ygmodeler4 on Sunday, July 27, 2014 12:31 AM
While waiting for paint and putty to cure for the 106 and alpha jet I'm doing for the braille scale build...I decided to start on my MiG-21...
So forgive the long post for such a small update, but here's what I'm planning on this MiG. I previously build one of these in a tropical-esque digital camo (not done waiting to make low vis decals) and I wanted to build a sister plane except in a naval theme. I'm not sure if I'm going to do digital camo or not...but it is gonna be a cool scheme no matter what it is. I also want to make this one mean looking MiG. I believe I can do this with some extra what-if ordinance and the paint scheme. SO...here's where I'm at so far...
Just the basic cockpit...unlike every other jet aircraft I've built from Revell, the cockpit in all honesty sucks...oh well, I'm going to stick a pilot in it and not get bogged down because it's going to be hanging from my ceiling with the wheels up. In addiction since this is a short (yes 5 months is short for me) time frame on this build, I'm gonna focus on the exterior of the plane and leave the cockpit be.
Wings and tail fin together...this kit gives you the option of a long and short tail version...I am unaware of what the differences are and which versions use which (not that it matters too much since I'm throwing reality out the window) but I chose the longer version. I did this because I feel it beefs up the MiG so to speak. Like I said before I want this to be one mean MiG.
So, that's where I'm at right now, but here's some EXTRA stuff because I'm feeling adventurous in this post.
A couple days ago at work I had a lot of people needing arrows cut, so instead of throwing them in the trash, I took the cut pieces and brought them home in hopes of finding a use for them.
Well in case you can't see....there's three different sizes, both in thickness and in length. Here they are against the wing/hull of my "tropical" MiG for a size comparison...
That is the longest, and skinniest. IIRC it's a 500-arrow
That one is both medium length, medium thickness...400-arrow
And finally the shortest and thickest...350-arrow
Now obviously the 500-arrow is going to be to long for anything...but I figured the 400-arrow could be made into an anti-shipping or some other long missile, and the 350 arrows could be made into some sort of rocket/missile/guided bomb.
Here's some pictures next to the kit supplied atoll missiles, which I guess are cool, but they make this MiG look small and wimpy...
 Now, in conclusion, I don't want to make this MiG look overloaded, which is going to be hard, but I do want it to have some heftier armament by finally using my spare parts bin. Anyways, thanks for looking and all comments/ideas are welcome.
-Josiah
    July 2003
Posted by sidure on Sunday, July 27, 2014 2:12 AM
Hey Plasticjunkie, yes its the old monogram F-86. The pit and wheel wells look ok but things like the landing gear look like blobs  and everything is covered in a lot of flash. If the fit is ok I will do my best to make her look good
Steve
    April 2014
Posted by B_one fixer on Sunday, July 27, 2014 1:27 PM
You could use the arrows to make rocket pods
    October 2004
Posted by ygmodeler4 on Sunday, July 27, 2014 8:21 PM
B1...rocket pods...thats a good idea...do you think the shorter, 350-arrows would be better for that?
-Josiah
    April 2014
Posted by B_one fixer on Sunday, July 27, 2014 9:02 PM
Yeah the 350 arrows would be the best choice. I remember seeing a pic of some mig-21's performing a rocket attack. Looked pretty menacing !
    October 2004
Posted by ygmodeler4 on Monday, July 28, 2014 12:10 AM
Though it's purely coincidental, I've figured about 80% of the spare parts I'm using are from Revell kits..
I'm taking your advice B1...here's the progress on the rocket pods so far...I fear my scratch building skills are not quite there enough to make some russian looking rocket pods, so I'm settling for more of the american kind, the one with flat sides on each end of the pod. Here's the progress on that so far.
With regards to the actual plane...it's progressing quickly....I don't have to worry about the top seam as that will all be covered up by another part. I'll be working on the bottom seam to get that fixed up though.
There's also gonna be some strip styrene and putty added to blend this in...I had this in the spare parts bin and did some chopping and sanding to get it down to fit the curvature as best I can.
And one more picture...I plan on putting this cruise missile-esque ordinance on a center pylon where the fuel tank would be. Here's how I'm thinking it'll turn out though I might nix the guidance add on since it just seems too big to me.
-Josiah
    March 2005
Posted by TarnShip on Monday, July 28, 2014 6:11 PM
Josiah, another option for you to be able to get "more Russian looking rocket pods" would be to get the front end pieces from the pods carried by UK Phantoms. You could drill out each "slice" they have for a rocket hole and put tubing in there, cut off to a suitable length. I do not know if the number of rockets per pod will match up,,,,,,but, you would get the correct look, anyway.
Rex
almost gone
    April 2014
Posted by B_one fixer on Monday, July 28, 2014 7:25 PM
Here is my progress so far with the 2nd build, I got the pre-shading and first coat of paint down. I am waiting for some A/G weapons to arrive in the mail for this kit. It should help give her the proper look Big Smile
    January 2012
Posted by Cdn Colin on Thursday, July 31, 2014 8:12 AM
I have my fuselage together and wings on.  The port fuselage half had a significant warp to it (probably about 30 degrees).  I tried hot water to straighten it to little effect, and decided to cement the halves together in sections.  This worked well for the most part, but the wing fillet has an arched gap, and the back of the fillet is also turned.  I took pictures, but they didn't turn out.  My solution is to fill the gap and try to file the rear of the wing fillet to shape.
I build 1/48 scale WW2 fighters.
Have fun.
    May 2005
Posted by pyrman64 on Thursday, July 31, 2014 8:20 AM
Was having some "issues" with the dragster, so I decided to get on with the Expedition......
here's the interior floor still wet from the MM Fabric gray
here it's dry....
the tailgate has been hit with primer grey
the interior side panels with a coat of primer grey
Greg H
"There is many a boy here today who looks on war as all glory, but, boys, it is all hell." Gen. Wm T. Sherman (11 April 1880, Columbus, Ohio)
    May 2005
Posted by pyrman64 on Thursday, July 31, 2014 8:41 AM
Update:
here's a couple shots of the painted body (still need to add a few coats of gloss)
Greg H
    July 2004
Posted by stikpusher on Thursday, July 31, 2014 3:25 PM
MV, the photo of your Monte Carlo witht he box top has been added to the front page here. Very nicely done sir!
B-1, your making fast work of your second Eagle here as well! Wow! I wish that I still built at a more rapid pace....
PM, good progress on your project so far
Guys I have been so busy this week that I forgot to post my initial bit of work on my Gemini build here. So here is what I have done so far.
The color call outs seem to be based off of a NASA illustration and off of early/pre operational Gemini mock ups and equipment. So the first thing that I did was to go thru various image searches and find photos of actual mission equipment. After that I went thru the instruction sheet and annotated my own color call outs for use during construction.
Then I began cutting parts off of the sprues and gluing them together. The plastic itself is a tad on the soft side and not brittle at all so far. Mold seam and attachment stub clean up was quite easy with my needle files.
center console with control stick and release handle installed
overheard center console with lever installed
rear bulkhead attached to heat shield
and I have the front instrument panel and cabin sidewalls removed from the sprues but will not glue them in place until after painting is done in the next few days
with the sidewalls placed on the rear bulkhead
and finally the two Astronaut figures. I will not add their clear face shields until after painting
I know that painting all this will take longer than building it did. Seeing how I am now on vacation for the next few weeks, I should have plenty of time to get this one knocked out.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    July 2004
Posted by stikpusher on Thursday, July 31, 2014 8:02 PM
Well today I finally had some time to get in some un interrupted work at the bench here. So I started with the very mundane. Filling the seams on the Astronaut figures. Squadron white putty is seen here doing that task. I will let it dry overnite and sand it up tomorrow
Now as I said previously the instruction sheet color call outs appear to based off of a NASA illustrution and not off any of the preserved actual Gemini Spacecraft. So I am using this walk around of the National Air & Space Museum as my primary reference source.
http://www.cybermodeler.com/space/gemini/gemini_walk1.shtml
Now based upon those photos, I am gonna go with Light Gull Gray on the interior base color with the ejections seats (YES, Gemini had actual ejection seats rather than an escape tower type system as on Mercury and Apollo) in Dark Gull Gray.
the rear bulkhead and sidewalls
inner faces of the crew hatches
center console, instrument panel, and overhead console
and finally, just in case, I also got the areas of the nose cone, inner capsule surfaces, etc, that just might be visible when the capsule is all put together and the hatches are opened. And with that work went the last of my Gunze Aqueous semi gloss Light Gull Gray, which is sadly no longer available at any shops here in the USA
Tomorrow I will do detail painting, washes, etc. and get the Instrument panel decals on hopefully.
       - Plankton
LSM
    October 2004
Posted by ygmodeler4 on Friday, August 1, 2014 12:20 AM
Stik, here's a picture I took last week at the Air and Space Museum by Dulles Airport...hopefully this will help you some...I think it's a Gemini pod, I should've taken pictures of all the plaques, but I can't remember 100%.
EDIT: Just read your second post and those pictures are a lot better than mine. I think that is the one at the Air and Space in DC...but they are a lot better photos anyways...your build is looking good so far!!
-Josiah
    October 2004
Posted by ygmodeler4 on Friday, August 1, 2014 12:35 AM
Here's some other pictures of space stuff I took while I was there...Discovery is probably one of the biggest "attractions". I'm more into the airplanes and I've been there before but now that I'm older and can actually think, I stood there for awhile just looking at it... I still remember when the Columbia incident happened like it was yesterday (wasn't alive when the Challenger happened). Sobering and humbling stuff seeing something like that and realizing where it's been...had a similar experience with the Enola Gay. Anyways here's some pics hopefully you or someone else will find "inspiring" so to say.
-Josiah
    November 2010
Posted by Eagle90 on Friday, August 1, 2014 5:54 AM
Great pics Stik!  I am a huge advocate of the space program.  Have been since I was a kid.  Being raised in Florida and having grandparents living in Melbourne afforded me the luxury of visiting the Space Center FREQUENTLY!  Of course this was before they charged for everything at the museum.  Used to go there and just walk around the rocket garden and touch the rockets!   Lots of dreams there.  Anyway, it is inspiring to see the real deal up close.  I remember the Columbia incident too.  I was in college in my chem lab when another science prof ran in with a radio that was broadcasting what had just happened.  Very sad day.
Thanks for the great pics!
Eagle90
    October 2013
Posted by ajd3530 on Friday, August 1, 2014 9:13 AM
I am SO ready to get done with my two ongoing builds and start my P-39. It will be nice to take it easy with a sweet 'ol monogram kit.
    July 2004
Posted by stikpusher on Friday, August 1, 2014 11:30 AM
Josiah, thanks for those great photos! Perhaps Duke Maddog will take some inspiration from them as I just saw him win the Monogram 1/72 Shuttle kit at our IPMS fundraiser auction back in June. I remember going out to Edwards to see Columbia return from her 2nd mission there (a totally novel achievment at that time) and of other times seeing Enterprise on gound display there at the Open House air shows. As well as when I heard of the losses of Challenger and Columbia. Yesterday I tried a new route for my bike ride and this one took me by both the old Rockwell Seal Beach plant and McDonnel Douglas Huntington Beach plant (now both owned by Boeling) where many of the Apollo and later spacecraft were and are made. That is always inspiring to me to see where such greatness was made.
ajd, I know what you mean. That particular kit is a fun one. I can not remember how many of those that I have built over the years.
       - Plankton
LSM
    January 2011
Posted by Tal Afar Dave on Saturday, August 2, 2014 9:35 PM
Good pictures Josiah!  Like you, I spent most of my time walking around on the 'warbird' side of the hangar.  So many great planes, so little time to see them all.  Loved seeing the Vietnam War era planes; not to mention that massive Enola Gay!  Great museum, well worth the time to visit.  I only wish I could spell the name of the museum annex!!!
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    July 2004
Posted by stikpusher on Saturday, August 2, 2014 10:01 PM
So yesterday and today I have been working on detail painting and washes in the cockpit.
Cabin doors/hatches
Overhead & center consoles and Instrument Panel
cockpit rear bulkhead, ejection seats, and sidewalls
and finally, the Astronaut figures. The instructions would have you paint them in one of the earlier type suits used for Mercury and pre flight publicity photos. But the actual Gemini flights were flown in a white suits of a few types that eveolved during the course of the program
I am still working on them, but looking at the decal sheet, the decals have the nametapes for the Gemini 3 crew, Grissom and Young, so now I have to fine tune my (needs improvement) face painting skills for those two gentlemen...
seated in their seats...
then of course I had to do a test fit of all the major pieces...
and of course I really have to wonder if Jim Hesnon got  his inspiration from Gemini....
"....PIGS IN SPACE.....!!!"
Stay tuned for more...
       - Plankton
LSM
    May 2005
Posted by pyrman64 on Sunday, August 3, 2014 5:49 AM
Stik: looking good there, nice job on the figs - mine would have looked like the muppets!
B_one: nice F-15, always liked those since I was in high school and got a chance to tour Wright-Patt's tower as a flight of those were taking off.
Greg H
    May 2005
Posted by pyrman64 on Sunday, August 3, 2014 5:59 AM
Latest update:
I love the way the seats never go together right on snap kits
managed to get a bit of detail painting done....
I need to touch up a few spots
I gave the grills a wash of flat black
Greg H
    November 2008
Posted by plasticjunkie on Sunday, August 3, 2014 11:01 AM
Lots of great modeling going on. Everyone is doing a fantastic job on their projects.
As for me, I'm trying to keep my Voodoo as OOB as possible but sometimes I just can't help doing some modification. The side fuselage light has a molded bulb that was screaming to be replaced by a MV lens.
Unfortunately, I don't have the size I need in my goody box and 3 places I checked had #116 out of stock so I made my own from clear plastic.
I drilled out the bulb which left a hole on the cockpit side. I used a small thin plastic sheet piece cut to the correct shape and glued over the hole then painted with the matching cockpit grey color.
According to my references the light compartment is black so Floquil engine black was brushed on.The flat side of the lens was painted Floquil bright silver and when dry was attached with a dab of clear parts cement. The MV lens is a much better alternative but a clear panel will go over the light making it a bit less visible. I think it came out ok.
There's a scoop that is located up front and very visible to I deepened the openings a bit to give it more depth.
The nose cone was assembled and seams sanded and polished smooth, no filler used at all. All the probes were glued. I don't know if it will require weight to keep it from being a tail dragger.
Floquil engine black was brushed on the top cockpit sides. The canopy and windscreen will go on very soon to be used as masks from the exterior color.
I also went back and added a few smaller pieces of stretched sprue and Tenax to close up some of the seams on the weapons bay joins.
 GIFMaker.org_jy_Ayj_O
    April 2014
Posted by B_one fixer on Sunday, August 3, 2014 2:23 PM
Wow everybody's builds are looking sweet ! I have been busy building other kits for a bunch of upcoming shows our IPMS chapter has here. The big one being the Dec 7th show at the Arizona Memorial. Since I have never build anything WWII its a learning curve with lots of research for me.
But anywho here is where I am at with my second build. She is almost complete. I got the decaling done. Just down to weapons, weathering, and Wheels. I work on here in between the other builds I have going.
Had to straighten out the Lt. tail to even it out.
Started fixing up some weapons for the eagle. I still have to mask and paint the yellow lines on the ordinance. This is turning out to be tougher than I though.
1st wash applied.
    November 2003
Posted by mississippivol on Sunday, August 3, 2014 5:27 PM
Nice work, everyone!
    October 2013
Posted by ajd3530 on Monday, August 4, 2014 12:54 AM
P-39 question guys.. My Airacobra is going to be a D model of the 39th PS based at Selfridge in mid-late '41. Now I know one of the selling points of building Selfridge at its location was its proximity to Lake St. Clair, perfect for bombing practice. My question is two-fold.
1: by mid '41, had the USAAC conceded the P-39's horrible high altidude perfromance and be training Airacobra pilots for the fighter/bomber role?
2. If so, what color were practice bombs then? I've read they were yellow, and I've also read they were white with a 4 inch blue band?
    July 2004
Posted by stikpusher on Monday, August 4, 2014 1:26 AM
I cant say for certain about the role of the P-39 in 1941, but it was just entering service at that time. It had not been to war with the USAAF yet and its role as a fighter had yet to be proven or disproven. USAAF brass was not going to take too much faith in RAF results with US equipemnt, becuase they often held the opinion that US equipment was not emplyed properly by the RAF.
Yellow was the color of standard HE bombs in 1941, not practice bombs. Blue has been the color for practice ordnance in the US for decades, but I  can not say how far back that goes.
       - Plankton
LSM
    March 2005
Posted by TarnShip on Monday, August 4, 2014 12:44 PM
I have that same info, Stik,,,,,,with the Army Air Corps/Force using blue bodies with white letters and no stripe, just like that photo,,,,,and the USN using Black (yuck) , with no stripe and White lettering. The table is headed "1940's-late 1950's", so it covers US in WW II nicely.
There was a whole other set of "practice" bombs, those are the Drill Bombs used by the ground crew to teach loading and unloading, those are Olive Drab with Black stripes for the USAAF and Yellow for the USN, with Black "Drill (inert)" lettering.
Additional useless info from Rex,,,,,,those M 38 are 100 lb steel shell bombs filled with 80 lbs of sand, with a 3lb black powder charge,,,,,used from 1930's to the 1960's.
click, boring mode deactivated,,,,,,,,,or at least I sure hope so
Rex
almost gone
    October 2013
Posted by ajd3530 on Monday, August 4, 2014 4:55 PM
Well started on the P-39 interior. I hate to leave things undone, but I'm really considering not painting the gun bay. Not going to have the hatch open, so it will never see the light of day. Unless she crashes and burns off a book shelf or somerhing.
