2015 Messerschmitt Bf 109 Group Build
    November 2008
Posted by plasticjunkie on Wednesday, September 9, 2015 9:57 AM
Have been plugging away at this so here are a few progress pictures.....
Got all the decals on and a combination of Flory and oil washes that still have to be tuned up here and there.
The next one I build will be different when it comes to the stacks. You have to either modify the stacks so they can be added after painting or do a lot of masking if done the Revell way. Masked the area and shot MM Burnt Iron Metalizer at 6 psi.
masking removed
Had some silvering under the wing crosses so no biggie there. Just used some post it notes to mask the crosses and shot some colors.
Got the tires assembled and painted. The tail gear broke off so it got pinned and now it actually swivels. I also flattened the tail wheel just a tad.
Did my home brew of oil and turp wash for the wells.
Did some streaks with oils for fluid stains. Letting things cure a bit then some Testors Flat Lacquer will be sprayed to kill the gloss. Some final assemblies and this G-6 will be done.
 GIFMaker.org_jy_Ayj_O
    December 2004
Posted by panzerpilot on Wednesday, September 9, 2015 10:04 AM
Fine work, PJ! Very, very nice. I really like the wheels. Great job on the mottling too! Looking forward to seeing it all done!
-Tom
    May 2013
Posted by Greg on Wednesday, September 9, 2015 11:40 AM
Gee that's looking good, Ernie.
Impressive work masking around those exhaust stack.
    June 2014
Posted by BrandonK on Wednesday, September 9, 2015 12:51 PM
Lookin' good there PJ.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Wednesday, September 9, 2015 1:55 PM
Lovely work there PJ, what did you think of the Flory wash. I am glad you posted this, it has reminded me I nee to do those fluid stain streaks. Which colour oil paint did you use for those.
    November 2008
Posted by plasticjunkie on Wednesday, September 9, 2015 2:10 PM
Thanks for the nice comments fellas.
Bish
I love using the Flory Washes. Simply outstanding! Great for bringing out recessed details and griming up certain areas. Easy to remove and control. They do stick well to flat paint so heads up on that.
For the fluid streaks I used burnt umber oil paint straight from the tube. The wheel well washes was a combination of burnt umber with a touch black to darken it just a tad.
Posted by Bish on Wednesday, September 9, 2015 3:01 PM
Glad you like them. When I post some pics I will be able to show well the difference between how they stick to gloss and a flatter surface. Thanks, I did think burnt umber, but wanted to check.
Posted by Bish on Wednesday, September 9, 2015 3:54 PM
Another short update.I got the decalson the otehr day. After i finished those, i realise dthat i really should have done some fading with the airbrush. This is the first time i have done a desert aircraft since i started serious weatheirng and in 72nd scale i would have done this with dry brushing. But with this larger scale, the fading would have been better with the air brush. So one lesson i have lkearmnt is to treat 32nd aircraft similar to 35th armour rather than smaller scale aircraft. I had also starte dthe exhaust staining when i took these.
And then some weathering. I was originally going to go for the lighter touch. But i found some info that this aircrfat was older than i had thought. Apparently it had crashed earlier in the year and then repaired before Marseille got hold of her.
For the weathering i used Flory Wash dark dirt top and bottom and then dry brushed the top.
One point on the Flory Wash. You can see that the bottom is cleane rthan the top.Despite the top getting a future coat is was less glss than the top. The flory wash sticks more to the flatter finish but just slids off the gloss. It can be removed from the flat finsih, but it does take some work, but its really hard to keep in on the gloss. So if you wnat a clener finish with it just in the panel lines,its best applied to glss. If you want a more grubby look, use it on a flat surface.
I'll do a little more to the underside once the flat clear coat is applied, hopefuly tomorrow.
And that all for now. Once i get the flat on, i can then add the clear window parts,which should be fun.
    November 2008
Posted by plasticjunkie on Wednesday, September 9, 2015 4:22 PM
Looking good Bish. The paint and washes look really good. You can still do the fading. Spray clear flat acrylic and when dry, do a filter of turp and yellow ochre oil paint. That's how I did it to my Ju87B Desert Snake for the Stuka GB. Just go light on the wash mix cuz yellow ochre is very strong.
Posted by Bish on Wednesday, September 9, 2015 4:31 PM
Thanks PJ. And good point, didn't think of that. Really need to get my armour head on. I will do that tomorrow.
    March 2012
Posted by mustang1989 on Wednesday, September 9, 2015 5:01 PM
Will comment on this more in depth when I get home. Time is short at work today.
 Forum | Modelers Social Club Forum (proboards.com)
    November 2007
Posted by moose421 on Wednesday, September 9, 2015 8:13 PM
Looking great PJ.  The oil streaks look awesome.  Keep up the great work.
Kim
    November 2008
Posted by plasticjunkie on Thursday, September 10, 2015 12:03 PM
Thanks Kim!
Posted by Bish on Thursday, September 10, 2015 4:25 PM
PJ, good call on the filter wash. Its turned out real nice.
    November 2008
Posted by plasticjunkie on Thursday, September 10, 2015 4:36 PM
Good to hear Bish.
    January 2015
Posted by BrandonD on Monday, September 14, 2015 1:56 AM
There is so much fantastic work going on here. Plastic Junkie and Bish, great, great job.
Everyone else is doing amaing work, too. In fact, you all inspired me to get back to my Bf-109 E7 Trop kit from Eduard that has been sitting around in my stash for a bit.
I decided to do this one with the front end opened up. I have the weekend edition kit, but bought the PE set for it, so it's closer to a Profipack.
Anyway, here is the cockpit before final assembly.
And here is the engine, firewall and cockpit installed in the fuselage.
I'm looking forward to gettingthis one painted up and weathered. I want to try out some new techniques on weathering, and this kit will be perfect for it, given the climate inwhich it served.
-BD-
    November 2008
Posted by plasticjunkie on Monday, September 14, 2015 6:45 AM
Here we go with another stunner in progress courtesy of BD! It's looking super!
I'm almost done with my G-6 and will be posting pictures soon.
    November 2003
Posted by tempestjohnny on Monday, September 14, 2015 11:43 AM
I'm starting to get the itch to build again. Will be removing the cob webs from by build bench soon
Posted by Bish on Monday, September 14, 2015 11:47 AM
Thnaks BD, and nice start. Looking forward to this. I am just about done, going to get a couple of pics before I stick it to the base and get pics of that. Should be posting final pics tonight. Johnny, hope to see you diving in, still got a few months.
Posted by Bish on Monday, September 14, 2015 3:43 PM
Well, i guess its time to call this done. My first 32nd scale aircrfat is almost 30 years of building models.
After the last thread i tok PJ's suggestion and did a filter wash with Yellow Orche oil. I did add a small dropofwhite and did the wash very thin and the result was just what i wanted, so thanks again PJ.
On the underside i re-did the flory wash with dark dirt and then another with sand.
Next upwas fitting the clear parts to the canopy. As you can see, the clear acotate has a paper backing with the outline of each piece. the instructions say that once cut, they should be soaked in water toremove the paper, but it came off easily enough without.
I cut two piece out at a time to avoid mixing them up, dipped them in future and after 30 mins drying fitted them. Most fitted no problem, but the centre pieces, which should have been fitted before the inner frame, needed some trimmng.
Once all fitted, the canopy was fitted along with the antena wire and that was it.
I added some MiG and AK pigments to the wheels legs and around the wheel wells.
Then it was just adding it to the base, fitting the propand adding the figure and its done.
And here, along with my otehr build for this GB, the 1/18th DB 605.
And finally, i wanted to do a comparison. For those who may have only built in one scale, or only made a small change, here you can see what a big jump this is for me. Apart from a few 48th kits early on, i have been building 72nd aircraft ever since i started modelling. But now my sole 72nd 109, a hase G-6, has a big brother.
And tehre you are. Thanksall for the support and making this yet anotehr great GB. Thanks to all those who gave tips and advice.
And a huge thanks to Mustang for yet anotehr great GB and the excuse to build twokits that both challenged me and were a rel joy to build, as well as adding somthing new to the collection.
I will leave which pic you add to the front page all toyou buddy.
O, almost forgot.You will have to excuse the differant colours in the terrain. I added some fresh celluclay after the model was added so this is still wet. Once it dries it will all match.
    December 2004
Posted by panzerpilot on Monday, September 14, 2015 4:56 PM
Fantastic, Bish! Nice base, figure, and weathering. Very well done. Yes
-Tom
    November 2008
Posted by plasticjunkie on Monday, September 14, 2015 5:32 PM
You nailed it Bish, great job overall! The base and figure adds tons to the build.
    November 2008
Posted by plasticjunkie on Monday, September 14, 2015 8:30 PM
Got the lights painted
and mounted
Made the canopy cable and spring along with the radio antenna insulators
Wheels got some MMP earth powders
tail tire was flatenned a bit
Some chipping was added and MMP black powder was applied for the exhaust stains.
More fluid streaks here and there, or as Bob Ross used to say, there and here.
 Finally completed this great kit. Hope you like it. All comments welcome.
    November 2008
Posted by plasticjunkie on Monday, September 14, 2015 10:35 PM
Forgot to add the pitot tube so now it's complete.
Just a short description about the plane and markings. This G-6 was flown by Hauptmann Karl Rammelt of II./JG 51 while based in Rumania in 1944. He flew 450 missions scoring 46 kills. He lived to the ripe old age of 94, passing away on May13, 2009.
    April 2005
Posted by Thunderbolt379 on Monday, September 14, 2015 11:33 PM
Bish and PJ -- awesome results both! You've really captured the feel of the aircraft and been much more adventurous with weathering than I have ever dreamed of being. W\ell done! M/TB379
http://worldinminiature.blogspot.com/
Posted by Bish on Tuesday, September 15, 2015 12:37 AM
Thanks guys. PJ, nice, real nice. I do really like that mottling.
    November 2008
Posted by plasticjunkie on Tuesday, September 15, 2015 7:20 AM
Tbolt
Tahnyou kindly sir.
Bish
Thanks buddy. Hey forgot to tell you  that Durham's Water Putty is great to create desert sand or regular terrain. I use that along with unscented crushed kitty litter for rocky areas or rubble. Don't know if you can get this product in your side of the pond.
Again great job on the figure, terrain and the Friedrick.
    March 2012
Posted by mustang1989 on Tuesday, September 15, 2015 7:48 AM
Was meaning to respond to this all about 3 hours ago but my computer/ internet connection was acting up and I couldn't see the pictures.
 Bish: I have to say that your skills never fail. I'm sure it's a bit uncomfortable building out of your comfort zone of the 72nd scale realm but you've managed to pull them all off magnificantly. I'd like to extend some gratitude to you for participating in this GB bud. Your contributions are a welcome addition to it.
 Ernie: Wow!!! All weathering and paint are drop dead gorgeous and if there's a fault I can't find it. Let me know which picture you want to use for the front page and thanks a million for being a welcome part of this GB as well.
Brandon: It's great to see you back on your E-7 again. I just love looking at 109's all opened up. It's lookin' to be an awesome finish.
    April 2006
Posted by jgeratic on Tuesday, September 15, 2015 10:18 AM
Bish, a very succesful forray into 1/32 scale.  Yes
Love the subtle varions of colour, particularly topside.  A great overall presentation with the base and figure as well.  One question on  the dark streak on the bottom fuselage - I need some enlightment on what would cause that?
PJ, an extremely fine example of the G-6.  Yes
Your attention to specific detailing is quite impressive and you should be proud of your handiwork.
regards,
Jack
Posted by Bish on Tuesday, September 15, 2015 1:03 PM
Thank a lot guys, much appreciated as always.
PJ, I have heard of that but have not been able to find it over here. But I think I came across something similar but did not pick any up, I will have to check it out again.
Joe, thanks buddy. It was not as bad as I thought and once I got going It just felt natural. But it certainly was nice to try something new.
Jack, thanks. And I will admit I took a risk with that. I did a search for streaking on 109's and found a few pics with the grime like that, but I think they were all models. I could not find any decent pics of the underside of 109 in service so after some thought I decided to risk it. It may well be totally wrong, and if so I will take that as a lesson learned.
That and I think I was getting a bit carried away with myself having such a big canvas to cover.Embarrassed
