Ok, I got the main assembly done, painted the insides of the scoops and masked them, then added most of the small parts - cannon, PE hooks on the undercarriage, underwing lights, etc.
The horizontal stabilizers and the rudder are on, but not glued yet. I'm going to take them off after shooting the underside for ease of masking, since they fit so well that they won't need filling at the underwing seam (and hopefully not the upper side, either).
After applying the masks and shooting it black, I realized the hood seam was still visible, so it currently has a 1mm-wide strip of white going down the nose that will be sanded off tomorrow. I contrasted the photo a bit here so you can see it. It wasn't too bad, but it was definitely there, and I'd rather lose some rivets than have an extra seam, if that's the end result (fingers crossed that it isn't).
Now I hope I get the seam dialed this time, because it just looks weird in black. Can't wait to get it into the medium sea gray/dark green/ocean gray Gibbes' plane wore.
-BD-
