Well, it's been a few days since I posted, but I've got the top colors on. The masking still looks a little sharp on some edges (see port wing), but overall I'm happy with it. One of the reasons I chose this build is that it's an RAAF bird, and I hadn't done any Commonwealth planes yet. The other was that the camouflage had sharp demarcations, and not the blurred/feathered lines where the colors joined. I've got another Spitfire I want to try out the softer edges on, but this one I wanted to take it easier.
As you can see, I've got the ocean gray and dark green atop the medium sea gray. I'm happy with how it came out save for one spot on the starboard wing where I didn't hit it enough with the green blend coat, leaving too much of the lightened shade peeking through. This would be a problem if it wasn't covered by a roundel :D
A couple of side shots
And you can see the color scheme on the Eduard instructions. The gray on my plane is much more blue than the color drawing, but I think the bluer tint is actually more correct, and it will probably tone down a bit when I clear coat it anyway. (Also, the white balance in this photo is totally off, and I didn't take the time to fix it).
Now I get to basically mask the whole thing again to paint the leading edges of the wings and the cannon barrels white. I suppose I should do the fuselage band at that time, too.
-BD-
