Japanese Group Build V
    October 2005
Posted by deattilio on Wednesday, January 6, 2016 10:03 PM
Finally got a little time on my build.  Only accomplished the initial cuts so far.  Wingtips from the Hasegawa Zero are being grafted onto the wings of the Academy AT-6.  I also cut out the tail from the Zero to attach to the Texan.  Next cuts will be for the canopy mounting.
Tags: 1/72 , Zero , Texan
WIP:
Trying to get my hobby stuff sorted - just moved and still unpacking.
"Gator, Green Catskill....Charlie On Time"
    October 2008
Posted by bsyamato on Thursday, January 7, 2016 5:32 AM
So cute the little Claude :) and he seems relly surface detailed!
Good updates about the Ki-45 Freddie Yes
From GB IV update here the works about the rufe:
Put some dirty paint on it  and re-fixed side floats after broke them in the matt final layers Bang Head also glued engine, cowling and antenna support
Other day i noticed theres more little strange pieces on sprues so i remember about exhausts and pitot
wiring the antenna with fishing wire
the pitot fixed too
Just the paint scratchin before to finish the Rufe.
Instead, to complete the Kate i'm waiting for custom decals to put in the tail Embarrassed
Other wips asap
Posted by Gamera on Thursday, January 7, 2016 11:03 AM
Deattilo: Neat, looking forward to seeing all the kitbashing you're doing here to bring together the two kits.
Bsyamato: Looking good! In the States we have a term- 'toolbox parts' for when you find extra pieces at the end of project and you throw them in the toolbox, I don't know if there's an Italian term for the same thing or not. Still glad you found the exhausts and pitot tube there.
    October 2008
Posted by bsyamato on Thursday, January 7, 2016 12:38 PM
Correct, theres lots of unused parts in this kit shared with "normal" zero: a complete set of landing gears an three blades for propeller.. all will put in the spare box but... the exhaust and the pitot i just forget to setup before Whistling
    July 2014
Posted by modelcrazy on Thursday, January 7, 2016 9:25 PM
Here is an update for the Rufe. I’m at the point of painting as soon as the glue dries. I tried the Worn Effects on the props. The front face of the prop blades are aluminum and the rear face is flat black. This gave me the perfect opportunity to try the effects out on a test surface. I really liked the result and am excited to try it on the rest of the build.
The base is Styrofoam that I shaved and sanded at an angle to simulate a beach. I applied my favorite substance, Acrylic Gel, for a glue, because it has texture and when dry is similar white glue. I then poured some Oregon sand on the gel to simulate beach sand. Later I will AB sand color on the sand since the Oregon sand is darker than South Pacific sand. This will also allow me to spray a darker sand color to simulate wet sand where the waves have wet the beach.
Next I will start adding resin to the base in stages. We will see how this works.
Steve
Steve
Posted by Gamera on Thursday, January 7, 2016 11:07 PM
Ohhhhhh, very nice beach there Steve!
If it's not too much trouble I'd love a close-up of the prop. I've tried the Worn Effects produce on different stuff but not props yet, sounds like you've got a really good idea there. Idea
    October 2015
Posted by Brian Miller on Friday, January 8, 2016 6:32 AM
looks great bsyamato!
Posted by Gamera on Friday, January 8, 2016 8:04 AM
Brian: For some reason the photos still aren't posting but I can click on the links to see them. That's some really nice work there- I love the water.
    July 2014
Posted by modelcrazy on Friday, January 8, 2016 8:53 AM
Gam,
Here is the prop you requested.
Steve
Posted by Gamera on Friday, January 8, 2016 10:30 AM
Thanks Steve, cool! I've been 'chipping' the leading edge of prop blades by drybrushing with silver but I'm going to have to give that a try.
    June 2014
Posted by BrandonK on Friday, January 8, 2016 1:23 PM
I'm making progress on the Raiden. I have the cockpit done. Not much too it actually, typical old Tamiya generic pit. I've closed the fuselage up and now the lower wing is drying. Here is where I stand now.
Thanks for looking.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Gamera on Friday, January 8, 2016 2:40 PM
Looks pretty good to me Brandon, I'm guessing the instrument panel is a decal?
    July 2014
Posted by modelcrazy on Friday, January 8, 2016 7:55 PM
I completed the beach and painted the sand. I then taped some poster board around the edge to prepare for a resin pour
I made my first resin pour, and now I know what not to do.
First off, I used a few drops of blue water color to try to tint the “water”. It was like mixing water and oil, just slower. I finally was able to mix it by using the paint mixer. The turquoise color I wanted didn’t materialize, more of a light blue. Not bad but not what I was looking for.
Second, I was hoping the resin would harden fast enough so that running a sealer around the poster board would not be necessary. I apparently did not put enough hardener in the mix for it to harden fast enough and I had leaks. In fact, most of it leaked out. Oh well, this may actually work to my advantage
Ok, lessons learned....so far.
1. Seal the edges. I'm now using white glue.
2. Put in more hardener.
3. Put in a few drops of turquoise if you want turquoise.
Also, I painted the Rufe silver, air brushed the Worn Effects and am ready for the exterior colors.
Steve
Steve
    June 2014
Posted by BrandonK on Friday, January 8, 2016 8:06 PM
Gamera, ya it's a decal. Pretty simple and plain pit, nothing to write home about. If I do another I will get a resin pit, the kit is nice enough otherwise to deserve one.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    October 2008
Posted by bsyamato on Saturday, January 9, 2016 9:23 AM
This morning unfrized the peggy too, to complete the grey bottom parts, just my usual mix of grey 147 and interior green 78 humbrol. more layers to come
At the next :)
Posted by Gamera on Saturday, January 9, 2016 10:02 PM
Steve: Awesome, you're making great progress there! My only real experience with resin like that was the 'water' stuff sold by Woodland Scenics. And it went the same way as yours in bleeding out and running everywhere before it set up.
Bsyamato: Very cool, looking forward to more updates on her!
    August 2005
Posted by fjs3 on Saturday, January 9, 2016 10:26 PM
BrandonK
Thanks for looking.
BK
Looking great Brandon!!
"I'm gonna build all these models one kit at a time!
    October 2005
Posted by deattilio on Sunday, January 10, 2016 1:59 PM
I think I am done with all the major cuts, next will be grafting this Frankenstein together.  I have minor trimming, shimming and filling to do here and there but overall I am pleased with the cuts/fits thus far.
WIP:
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 2:02 PM
New progress on the Rufe and beach. I sprayed the Worn Effects, let that dry then sprayed the IJN Grey, let that dry for about a day and a half. This morning I masked and sprayed the green and applied the decals. Interestingly, after pulling off the mask, some of the gray peeled off, which is just fine and adds to the effect. This was probably due to the Worn Effects. The cowl was not glued on yet but it did work on its weathering..
The beach is turning out very well in my opinion. I mixed up another layer of resin and mixed in some turquoise, maybe a little too much, but it is at depth so again this should work to my favor.
Steve
Steve
    October 2015
Posted by ModelMan68 on Sunday, January 10, 2016 5:04 PM
Steve,
Your build is coming out beautifully....great work on the beach and water. And the plane is looking great. Can't wait too see it when you finish.
Jeff
a.k.a.  ModelMan68
ON THE BENCH:  Spending Time With Family and Friends Big Smile
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 6:03 PM
Here's another update. I believe I’m done with the Rufe once I finish the canopy.
I was able to pour quite a few more layers of resin and just about ready to install the build. In fact, once this last layer sets up enough I will set the Rufe on the surface so it sinks into the last layer a bit.
Steve
Steve
    July 2014
Posted by modelcrazy on Sunday, January 10, 2016 7:02 PM
OK guys I put the Rufe on the “water” and OMG! I am soooo pleased with this. This is actually looking like water! I will give this a few days to dry before I apply the last few layers. I will blow some waves in the last layer for some small surf. Oh boy, I can’t wait!
Steve
Steve
Posted by Gamera on Monday, January 11, 2016 8:03 AM
Hey Steve, the Rufe does look good and I love the water and beach!
Deattilio: Neat, though at this point she does sorta looks like a Zero and sorta like a Texan. Looking forward to seeing more come together!
    May 2013
Posted by hogfanfs on Monday, January 11, 2016 8:17 AM
@BrandonK,
That cockpit does not look bad at all! Great job!
@deattilio,
The Zero/Texan is really looking the part! Looking forward to seeing paint on it!
@Steve,
We need to change your name to Wizard of water! That beach looks outstanding!
@bsyamato,
The Peggy is coming along great! What scale is that kit?
@Freddie,
The Nick is looking great too! Great job on the cockpit and engines!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    October 2015
Posted by Brian Miller on Monday, January 11, 2016 7:34 PM
its getting a little farther along
    October 2015
Posted by Brian Miller on Monday, January 11, 2016 8:19 PM
Hey modelcrazy. How did the AK Interactive work out? It looks awesome, but I'm curious how easy it was to apply.
    July 2014
Posted by modelcrazy on Monday, January 11, 2016 8:41 PM
Brian Miller
You just airbrush it on, couldn't be easer Wink
Steve
Posted by Gamera on Tuesday, January 12, 2016 7:39 AM
Brian: Glad to see you got the photo posting issue cleared up there, it used to easier till they changed the forum about five or so years ago.
Love how she's coming so far and neat look on the 'ocean', the wake looks perfect.
    January 2016
Posted by Tony C on Tuesday, January 12, 2016 9:40 AM
1/48 hasegawa Val
    January 2016
Posted by Tony C on Tuesday, January 12, 2016 10:07 AM
Looks real good
