Viet Nam War Aircraft Group Build
    July 2014
Posted by modelcrazy on Monday, March 23, 2020 10:11 PM
NICE JOB on the HUD Stick!!!!
A-7, loaded with fuel, Mk 82s and napalm, ready to launch.
Pic # one on the wall if you please sir.
Steve
    July 2004
Posted by stikpusher on Monday, March 23, 2020 10:34 PM
Thanks MC. Your SLUF turned out great!!! That looks super! Yes
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2009
Posted by JacknewbIII on Monday, March 23, 2020 10:50 PM
Very nicely done on that A-7 MC!
    May 2004
Posted by cbaltrin on Monday, March 23, 2020 10:58 PM
Nice A-7 MC! Like the napalm cans!
On the Bench: Too Much
Posted by jeaton01 on Monday, March 23, 2020 11:50 PM
That's a well done A-7, Steven, congratulations.  And you are on the wall.
John
Posted by keavdog on Tuesday, March 24, 2020 10:08 AM
Great work on the A7.  Cant get enough of that bird.
Thanks,
John
    July 2004
Posted by stikpusher on Tuesday, March 24, 2020 7:17 PM
Area under windscreen painted up
And seam clean up finished on the Rockeyes and sway braces added
Just a few more things to do, then painting can start
       - Plankton
LSM
    July 2014
Posted by modelcrazy on Wednesday, March 25, 2020 9:12 AM
Excelent Stick Yes
Thanks guys.
Steve
    August 2015
Posted by crown r n7 on Sunday, March 29, 2020 9:02 AM
fantastic work fellas . Im in with a monogram A-37 got me some new paint to try.
 Nick.
    July 2004
Posted by stikpusher on Sunday, March 29, 2020 9:35 AM
Thank you Steve, it’s getting there.
Nick, what new paints do you have?
       - Plankton
LSM
    August 2015
Posted by crown r n7 on Sunday, March 29, 2020 10:23 AM
BTW this is proof that postimage works after mantiance..
this is the kit for this GB.
the pic is out of focus sorry.. this would be a good GB experimental builds good or bad you dont succeed until you fail and try again..
 Nick.
Posted by jeaton01 on Sunday, March 29, 2020 1:07 PM
Your entry is added to the first page, Nick.
John
    July 2004
Posted by stikpusher on Sunday, March 29, 2020 4:54 PM
Nick, I’m in the same boat with you on Postimage after maintenance... but damn if I didn't go into alert mode thinking that I had been hacked on there...
So my last updates for Thursday were delayed due to the shenanigans on Postimage. Thank goodness that they passed and my BP returned to normal.
Anyways, a few bits of small progress were done...
First up, I filed slots in the pylons for Stations 3 & 6 to accepts the sway braces on the Rockeyes
Then I trimmed and filed down the sway braces that I added for the Aero 5-1A launchers for the Shrikes that will go on Stations 2 & 7
I also filed slots into those pylons, which I should have done before I glued them onto the wings to make that task far easier.... It I did not take any photos of them at that point... and then I glued the launchers onto their pylons. Positioning is all best estimate based off of less than ideal reference photos...
and I also drilled out the bores for the 20mm guns using my pin vise and some micro bits
No work done Friday due to errands, but yesterday I did add the gunsight lens
And this morning, since he is something of a weapons specialist, Klaus inspected...
Klaus approves
More tomorrow... I now have to dip the canopy, mask it, glue it in place, and get ready for main painting...
       - Plankton
LSM
    February 2014
Posted by silentbob33 on Sunday, March 29, 2020 5:46 PM
Nice work on the A-7s guys!
I finally got some paint sprayed.  Have a few touch ups to do here and there but overall I'm pretty happy.
On my bench: Academy 1/35 UH-60L Black Hawk
    May 2004
Posted by cbaltrin on Sunday, March 29, 2020 9:24 PM
Look'n good SB!
    July 2004
Posted by stikpusher on Monday, March 30, 2020 5:10 PM
Thanks SB, your Tweet is looking pretty sharp too!
Today was lots of little things getting to the point where I can start painting in the next few days.
First up, I had to modify the upper main gear doors. The kit part has them molded as a single piece, when in reality it has a separate narrow section over the main gear strut, and a wider main section, so I measured and cut
then glued the narrow section in place.... as well as the main gear lower doors and the nose gear doors
I’m leaving off the remaining upper doors, like the inboard pylons to ease painting in that area a bit.
Now this kit also has an ECM bullet antenna molded at the base of the rudder (circled area), but the A-7B did not have this feature, so I removed it
I also began painting the ordnance
and I dipped the canopy in Future
I’ll let the canopy dry and cure overnight, then mask and install it tomorrow... main paining to begin the day after....
       - Plankton
LSM
Posted by oortiz10 on Monday, March 30, 2020 7:24 PM
Hey FSM,
Well, it seems that my district is not planning on resuming classes until May 5, at the earliest. I'd like to get in on this GB with a Hasegawa Skyhawk.
I think I can get this one done in a month. I'll post more pictures as I make progress.
Cheers!
-O
-It's Omar, but they call me "O".
Posted by jeaton01 on Monday, March 30, 2020 8:06 PM
Welcome, Omar. You are added along with your A-4E.
John
Posted by jeaton01 on Monday, March 30, 2020 8:07 PM
Nice progress, Carlos.  Those are odd looking wheel hubs.
John
    July 2004
Posted by stikpusher on Monday, March 30, 2020 9:12 PM
Thanks John. The wheels go over those. The do give a nice solid mounting point.
       - Plankton
LSM
    October 2009
Posted by Gregbbear on Tuesday, March 31, 2020 10:50 AM
Hello, sorry I haven't posted in awhile, work has been crazy.  This is my proof of life photo.  I have got her on her wheels.  I realized after painting, that the kit instructions were inaccurate, as these birds flew with the big center drop tank, not the two wing tanks. So, I am in the process of building the center tank.
I am digging all the A-7 action.  An awesome aircraft for certain.
Cheers,
Greg
- yat yas!
    May 2004
Posted by cbaltrin on Tuesday, March 31, 2020 12:29 PM
Boy I love me a big grey and white F-4. Looking good Greg!
Posted by oortiz10 on Tuesday, March 31, 2020 3:25 PM
Hey gang,
I'm thinking about working on a couple of other projects alongside the Skyhawk. I found a couple of unfinished SR-71s at a garage sale.
It seems that all the parts are there to complete them...
...but they're started but in bad shape. There's an -A and a -B that need some love. I'm going to try to restore the -A for this GB.
My focus will be the Skyhawk, but I'll try to interject with the Blackbird when I can.
-O
    August 2015
Posted by crown r n7 on Tuesday, March 31, 2020 4:55 PM
wow awesome stuff fellas.
what is done with this mongram puzzel.
 Nick.
    August 2015
Posted by crown r n7 on Tuesday, March 31, 2020 4:56 PM
 Nick.
    July 2004
Posted by stikpusher on Tuesday, March 31, 2020 6:03 PM
Oh, there are a couple of Tweets in progress here! Nice!
Greg, your Phantom looks great! But I might suggest another type of Sidewinder. Those look like Air Force J models and not Navy/Marine Corps D/G type.
Today’s progress update...
Canopy masked off with Tamiya tape, then installed. For the windscreen I am trying Humbrol Clearfix, which I accidentally picked up instead of their Liquid Poly on one of my last visits to Brookhurst Hobbies... must pay better attention to what I pick up... the hood I am attaching temporarily with Testors clear glue, as I am going to pose that open once completed
I had attached the landing light to the gear door yesterday. Today I foiled it up and masked off the lens
and lastly, another coat of white onto the Shrikes and Rockeyes
Tomorrow, set the airbrush up and time for primer...
       - Plankton
LSM
    July 2004
Posted by stikpusher on Wednesday, April 1, 2020 6:29 PM
Today’s update:
I finally set up my compressor and did some airbrushing! Woohoo!
I primed white in the intake using Tamiya White Liquid Surface Primer. That should give a nice vivid white in there
I airbrushed on a coat of Humbrol Enamel Flat Black on the canopy for the framing interior color
and lastly a coat of Tamiya Gray Liquid Surface Primer overall after masking off the intake and the exhaust.
 I’ll let that dry overnight, then tomorrow start on white for the control surfaces and undersides.
       - Plankton
LSM
Posted by keavdog on Wednesday, April 1, 2020 10:58 PM
May not make the finish line.  The F-4J will sit with the F6F-5 (not for this build) as I've run out of  CO2...  I'll check here in town to see if they local gas co is open but...
Thanks,
John
    July 2004
Posted by stikpusher on Thursday, April 2, 2020 10:02 PM
You do not have a compressor John?
Today’s update- more airbrushing!
First up, I decided to try a marble base coat of Tamiya Flat White on the lower surfaces and flying surfaces topsides.
then I lightly airbrushed on multiple coats of very thinned (2 parts thinner 1 part paint) Tamiya Gloss White over the base coat
not too bad...
       - Plankton
LSM
Posted by keavdog on Thursday, April 2, 2020 10:07 PM
That looks great Stik - may try that myself.  I had a compressor years ago but after converting to CO2 I never replaced it.  Called the local gas co here in town and no answer so I figure they are closed.  Amazon to the rescue.  I ordered a compressor with a small tank - I'll never give up on CO2 but there's no way I'm going weeks without painting!
Thanks,
John
