Animalistic GB-Official place
    July 2008
Posted by castelnuovo on Monday, August 1, 2022 9:41 PM
oortiz10
Man, adulting stinks! The past 3+ months have been craptacular, but I'm now happy to announce...
I'm jumping back in with my Revellogram Airacobra. I started with its front end. After deciding to keep all the panels closed, I built a couple of bulkheads and filled some of the nose with Liquid Gravity.
I also got the cockpit done, and since the armament up front wasn't going to be used, I filled that space with a bunch of pine derby car weights.
With the gun compartment and cockpit access doors glued closed, I'm considering scribing the rest of the kit. Getting the doors to fit cleanly resulted in some lost raised detail. I'm thinking a scribing will keep all the detail consistent, i.e. recessed.
Next I plan on tackling how to build up the kit while keeping the nose gear and exhaust stacks off until after painting. I think I have a few ideas...
Anyway, until then, comments, questions and criticisms are welcome. (As usual!)
Gotta admit, it feels good to mash some plastic again!
Cheers,
-O
Welcome back :-)
    May 2004
Posted by cbaltrin on Monday, August 1, 2022 11:19 PM
Welcome back oortiz10 -- P-39 is looking good.
On the Bench: Too Much
Posted by oortiz10 on Wednesday, August 3, 2022 4:05 PM
Hey gang, thanks for the "welcome back," it's great to be back! Today I have a little more of my Airacobra to share.
Revellogram's instructions have you install the nose gear, NLG doors and exhaust stacks before closing up the fuselage. Well, knowing me, I had to come up with a plan to add the gear leg and doors towards the end of the build to avoid breaking them off. With a bit of dry fiting, I was able to come up with a plan.
I decided to cut off some of the gear mounting "well" to allow the strut to be slid in after things go together. Leaving the forward and upper parts of the well allowed me to know when the part was far enough forward and still support the weight of the completed model. (Hopefully that makes sense.)
After solving that problem, I turned my attention to the exhaust stacks. The starboard side can be installed after paint, but the port side needed to be installed before the fuselage went together. So, to make painting and masking easier, I came up with a way to install the port exhausts after the completion of the major assembly and painting.
First, I shortened the length of the stack's backing so that it could fit through the slot in the fuselage. I also sanded the back of the stack's backing flat.
Then I used some small "spacers" and a strip of styrene to build a backing for the stack.
Now, I can simply drop the stack through the slot and glue it onto the backing once everything is closed up and painted without having to worry about masking.
Having figured out the assembly challenges, I turned my attention to rescribing the kit. It's not 100% accurate, but I'm sure it'll look OK under some paint and weathering. Here's my start with the completed fuselage.
As usual, comments, questions and criticisms are welcome. Thanks for looking!
-O
-It's Omar, but they call me "O".
    May 2004
Posted by cbaltrin on Wednesday, August 3, 2022 11:35 PM
Nice improvision on the P-39 oortiz. Old kits are definitely skill builders.
Now, for me  I have been building my own skills on this old Revell A-7 , making the canopy fit with the fuselage , and creating canopy masks...
    June 2019
Posted by Mach1 on Friday, August 5, 2022 7:46 PM
Fantastic work, all.
Here is my entry.
I decided to pick up some PE Zimmerit and indy link tracks. Both are intended for the Tamiya kit so this may or may not come back to bite me.
    July 2008
Posted by castelnuovo on Saturday, August 6, 2022 1:37 PM
Good work gentlemen. Always nice to see a good progres and a start of a new kit. Smile
Posted by oortiz10 on Sunday, August 7, 2022 6:21 PM
Hey animals, I'm back with a little progress to share...
Here is a mock-up of the major assemblies after the rescribing. Again, not completely accurate, but I think it looks pretty good.
Time to move on to the transparencies, then I can move on to paint!
-O
    July 2008
Posted by castelnuovo on Monday, August 8, 2022 1:04 AM
Nothing mocking about the mock-up Smile. Good work
    June 2019
Posted by Mach1 on Tuesday, August 9, 2022 8:00 PM
Good job on the rescribe, O. It looks the part, especially in the mock up you did.
    May 2004
Posted by cbaltrin on Wednesday, August 10, 2022 7:35 AM
Finally getting some painting done... Took about 15 revisions to get the canopy  masks right...
    April 2014
Posted by lostagain on Thursday, August 11, 2022 7:57 AM
cbaltrin, looking good there. Very nice work getting the canopy smoothed in so well.
Omar, really nice work on the rescibing. The nose gear had better be strong to hold up all those weights.
The Wineel is pretty much done, all that is left is to take some good photos.
    April 2014
Posted by lostagain on Saturday, August 13, 2022 7:21 AM
And here we are -  the finished photos.
Winjeel is a local Kulin nation indigenous word meaning young eagle. Winjeels can still be seen at airshows, even though they finished service in the 70s.
The RedRoo model was a great build and went together well, the exception being the fitting of the seats in the cockpit and the main undercarriage. The decals were very good and went down well.
    July 2008
Posted by castelnuovo on Saturday, August 13, 2022 9:53 AM
This looks soooo cool. Front page/gallery will be updated shortly.
    April 2014
Posted by lostagain on Sunday, August 14, 2022 10:24 PM
Thanks very much Castelnuovo, it was enjoyable for the most part...
And thanks very much for running this GB, it has been great sharing my build with the rest of the zoo!
    May 2004
Posted by cbaltrin on Monday, August 22, 2022 5:05 PM
Here is some progress on my Revell A-7. Trying Tamiya Laquers on this one. Added a little clear gloss to the gull grey to make it a bit more durable...
    July 2008
Posted by castelnuovo on Wednesday, August 24, 2022 4:59 PM
Looks good Yes
    July 2008
Posted by Est.1961 on Thursday, August 25, 2022 7:59 AM
lostagain
Really nice lostagain I'd say you found yourself, Sharp photos do it justice pleasure to look at. Smile
    May 2004
Posted by cbaltrin on Saturday, August 27, 2022 11:41 AM
Decaling the Revell A-7. These Printscale decals look great when on, but a bit fussy to work with. VERY THIN. Also, there are two decal sheets, one with data and one with unit mrkings. The 'data' sheet decals are thicker and take some time to release from the backing even with hot water; however, the other sheet with the unit markings release almost immediately. What really through me off is that all those little multi-colored arrow-heads on the rudder our individual decals -- a fact I did not know until I tried to slide them off the paper with my finger! I was quite relieved however that the big decal for the tail fit the Revell kit!
    July 2008
Posted by castelnuovo on Saturday, August 27, 2022 5:22 PM
Well, I just learned something new today: use egg box to hold the model. Oh, a great sharp looking plane there too Smile
    April 2014
Posted by lostagain on Sunday, August 28, 2022 6:57 AM
cbaltrin, fantastic work with those decals, they are looking great. All the arrowheads must have been a pain. That is a vey sharp looking paint job.
Thanks 1961, I am very happy with the result overall.
    May 2004
Posted by cbaltrin on Sunday, August 28, 2022 7:00 AM
Thank you castelnuovo & lostagain, I appreciate it!
    May 2004
Posted by cbaltrin on Sunday, August 28, 2022 3:55 PM
DARN! DARN! DARNY! DARN!!!
It slipped out of my clumsy hands while decaling. wing totally separated from fuselage .... Well, looks like this one will be a ceiling hangar in the boys room. I managed to snap the wing back on and it does not look that bad if you are half blind
Posted by oortiz10 on Sunday, August 28, 2022 10:23 PM
OH NO! cbaltrin, that's gotta be a gut punch! Your Corsair was lookin' sharp. Sorry to hear about the mishap.
As for me, I haven't had much time to work on my P-39, but the little time that I have dedicated has resulted in some progress.
First, I needed to use a small sliver of styrene to fill a gap at the back of the canopy. This is before I trimmed and shaped it.
One of the kit's gun covers went missing, so I made a couple of replacements using some shaped plastic.
Not perfect, but better than nothing. And I used some panel liner to check my scribing.
Then I was able to spray some white primer. It's Alclad's microfiller primer. After I shot the paint, I went back and attended to some rough spots with a piece of 0000 steel wool.
I don't know when my next update will be but stay tuned!
Thanks for looking. Of course, comments, questions, and criticisms are welcome.
Cheers!
-O
    May 2004
Posted by cbaltrin on Monday, August 29, 2022 7:41 AM
Your P-39 is looking reall good oortiz... As for the Corsair, yea, gut punch would pretty much sum things up Smile  But it's a good reminder of where this hobby fits in with the rest of life...
    July 2008
Posted by castelnuovo on Monday, August 29, 2022 11:54 PM
Nooooooooo Sad
    May 2004
Posted by cbaltrin on Wednesday, August 31, 2022 6:12 PM
Got the old 1975  Revell 1/72 A-7 Corsair knocked out finally. Markings: VA-192 Golden Dragons by Print Scale.  Not really happy with these photos so don't use them on the roster. Just wanted to post something. Will get better pictures in a few days.
    April 2014
Posted by lostagain on Friday, September 2, 2022 7:59 AM
cbaltrin, Oh no, that is a real bugger! How bad is that!
Okay not too bad, good recovery but frustrating none the less.
Omar, the Airocobra is looking good, nice work
    May 2004
Posted by cbaltrin on Friday, September 2, 2022 12:38 PM
castelnuovo,  Here are some better photos of the 1/72 Revell A-7 (yes, it's boxed just as an A-7... but I E-ified it best I could).  You can use 1st photo for the Roster.
Posted by keavdog on Friday, September 2, 2022 1:21 PM
Wow, that's the one you dropped?  Nice recovery - turned out great.  Big  fan of the A7
Thanks,
John
    May 2004
Posted by cbaltrin on Friday, September 2, 2022 10:32 PM
Thanks keavdog.  Yes,  not sure why folks call this little guy 'ugly'. Always loved this plane since wathing 'The Final Countdown'.  Nimitz, 412, I have an usafe hook indicator, over...
