ARMOR - Pz IV Group Build
Posted by Anonymous on Tuesday, June 15, 2004 7:58 AM
wildwilliam is there a template for the sponsons on the IV D??? This is the model I am building for this build and would like to fill them in if possible.
    December 2009
Posted by wildwilliam on Tuesday, June 15, 2004 9:56 AM
feldgrau,
not that i know of.
i simply mocked up the top & bottom parts of the hull and looked it over.
then i cut paper patterns to fit.
i used some strip styrene along the sides of the upper portions for support
on the edges.
then i cut the piece from styrene sheet to match the pattern.
it needed a bit of sanding and fudging to get it in,
but once it is in and primed, it looks ok.
not perfect, but at least you cant 'see thru' the tank anymore!
it looks like my pictures of this 'fix' are on my home PC, but if you want to see them, i can try to post them after work today.
the holes in the lower hull, i covered from the back w/ scraps of styrene sheet,
and then filled from the outside w/ strips wedged in.
then i puttied them flat & snaded them out.
i recal they 'sunk' a bit afterwards, but it was not too noticeable.
(much better than a hole!)
Posted by Anonymous on Tuesday, June 15, 2004 11:22 AM
Foster... Screw THAT!!! Have fun pal... Big Smile [:D]
    January 2003
Posted by wipw on Tuesday, June 15, 2004 11:32 AM
Robert, are you doing one of the DML kits? I assume so with the indies and all. I, like the others, don't envy you. And at 10 minutes per link and 300 links, I figure that at 50 hours, not 22. Sorry!!
Best of luck to you.
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
Posted by Anonymous on Tuesday, June 15, 2004 11:44 AM
No way in Censored [censored] do I envy either. What can ya say Dragon indies are welll bad for buisness. I too feellazy and unwoarth of the title of model builder. Cause if it dont show dont worrie.
Posted by Anonymous on Tuesday, June 15, 2004 11:49 AM
Well after thinking about it I got real excited to do the Brummbar so I think I will have to bow out of the group build. I hope yall have fun and good luck.
    July 2003
Posted by Foster7155 on Tuesday, June 15, 2004 1:16 PM
Building the Dragon PzKpfw IV Ausf G "Kursk" (#9020) OOTB.
Well, I've actually got a bit of an "assembly line" system going and I think it's down to a shade over 5 minutes per link. So that's better. Spent about 4 hours working on them yesterday and have maybe 1/4 done.
Thanks for the comments everyone,
Robert Foster
Pensacola Modeleers
    December 2003
Posted by spector822002 on Tuesday, June 15, 2004 1:40 PM
I was at the LHS yesterday and felt that panzer4 tamiya tugging at my pantlegs for a home , I may go get it this weekend ,it looks pretty darn cool ! HMMMMMMMMMMMMM!
Posted by Anonymous on Tuesday, June 15, 2004 2:18 PM
Unless I aquire another kit... (not likely) I will be building the Italeri Pz IV H. Since I can't ever seem to leave well enough alone. I would suspect that i'll rebuild the skirt armor w/ styrene and replace the kit tracks with some DML nikes. One of my Italeri kits had a messed up mantlet out of the box. I hope the other is ok... I'd like to make this into a halfway quick build......wishful thinking...
I will be in San Antonio all weekend so I probably won't get much done for a week or two....Disapprove [V]
    October 2003
Posted by rebelreenactor on Tuesday, June 15, 2004 5:33 PM
I will be going to hobby town sometime this week so i will be pickiing up one of the tamiya kits, Wich of the 3 do you guys recommend? The D, H, or J?
John
Posted by tigerman on Tuesday, June 15, 2004 5:37 PM
John, I'd go with the J. The H wasn't a bad build, but the J seems to be newer and have more detail. The D is pretty old and from what I heard, needs some help.
 Eric
    October 2003
Posted by rebelreenactor on Tuesday, June 15, 2004 5:40 PM
thanks, I shoot for the J. I just hope they have it in stock!
John
Posted by renarts on Tuesday, June 15, 2004 5:40 PM
I'll be doing Tamiya's Ausf D. An oldy but goldy. Picked it up at a show last year for $20. The guy threw in a sheet of PE so I think I got a deal.
Posted by Anonymous on Tuesday, June 15, 2004 6:58 PM
wildwilliam Like I said before, its up to you what you build.
Foster you are a MADMAN!!! nice looking tracks though, I am sure the effort will show in the final product.
RedButcher sorry to see you leaving us.
Posted by Anonymous on Tuesday, June 15, 2004 7:16 PM
Thanks for the tip wildwilliam. I picked up some extra styrene to night to fill them in so I will just wing it. I cant imagine its that hard to do.
Foster,, I highly recomend you go see an eye doctor when your done,, because just looking at the indys I have for my Acadamy Tiger 1 let me tell you what,,you have one heck of a job ahead of you, and if you dont go blind after that, man I dont know. It is truly amazing what the dark side will make us armor guys do.
Renarts,,, You wont be alone doing the D. I for one will be doing it as well.
Posted by RAF120 on Tuesday, June 15, 2004 7:24 PM
If it's not to much trouble, when you guys post an update could you remind me what kit your working on. I know your working on a panzer IV but if you could add somewere who's kit it is and what Ausf it is ie. Tamiya Ausf D. ( I hope I'm not the only one who has trouble remembering what everone is building )
Trevor Where am I going and why am I in this handbasket?
Posted by tigerman on Tuesday, June 15, 2004 8:00 PM
One warning John, the Tamiya J doesn't come with any schurzen for the hull, just on the turret.
 Eric
Posted by renarts on Tuesday, June 15, 2004 8:11 PM
Cool feldgrau,
I like the idea of two (or more)builders, same vehicle and the result of each individual build style. Should be fun.
Good luck to all.
    December 2009
Posted by wildwilliam on Tuesday, June 15, 2004 9:54 PM
Trevor,
i will be finishing up a Tamiya IV Ausf. D that has been languishing on the bench.
if time and my parole allows, i might do an H after.
Rich,
i am putting these in so you can see my crude fix.
there are pics for
a) supports b) styrene patch c) patch in place d) a look at the piece w/ the halves together, and e) the inside of the bottom showing the various backing pieces for closing the holes.
bear in mind, the IV-D was my first armor kit when i started it last September.
i have finished 2 since.
the pics are small, so i don't feel bad about doing so many.
probably beating a dead horse, since it is a pretty easy fix.
Posted by Anonymous on Tuesday, June 15, 2004 11:05 PM
Thanks for the pics will. I hadn't thought about doing one big piece, I was going to tr and make them just cover the areas on the sides. But a whole piece works just as well.
We will now take a break from our current forum and say yeehaa my beloved Pistons just squashed the Lakers. Exscuse me while I go and do cartwheels in the bedroom....................... whoo whooo................
ok I'm back,,,,, Renarts this will be the second time I have done this model the first time was about 20 years ago. I think I have a pic of it. Maybe I will scan it and give you all a good laugh. No painting,,, no weathering,,, but actually it turned out pretty good considoring.
    October 2003
Posted by rebelreenactor on Tuesday, June 15, 2004 11:17 PM
Thanks for the heads up Tiger Man
John
    October 2003
Posted by rebelreenactor on Tuesday, June 15, 2004 11:21 PM
Edog, Is it ok if i build this For the D-Day GB too? Its fine if it is not, i already got somthing for that.
John
Posted by Anonymous on Tuesday, June 15, 2004 11:33 PM
Okay, I finished my 1st PIV, type H. It is 1/72 Scale Italeri, and the kit was frustrating, but I have two so the next one should turn out okay. I am also wondering how I post pictures since I have absolutely no idea...
Anyway, 1 down too many more left...
    July 2003
Posted by Foster7155 on Wednesday, June 16, 2004 1:28 AM
Hey Will,
Nice job on the corrections to your build. I've gotten so used to things like that on the older Tamiya kits that I'm really not disappointed...I expect it.
Keep up the good work,
Robert Foster
Pensacola Modeleers
Posted by Anonymous on Wednesday, June 16, 2004 1:41 AM
Rebelreenactor I don’t mind at all and I don’t think anyone in this group build would either. I think I posted something concerning this issue in the guidelines already. Anyway, go ahead and build across both threads if you want.
Wildwilliam and anyone else doing the Tamiya Pz IV D, I think you guys may want to look at the dampers for the suspension. The ones in this kit are molded onto the side of the lower hull next too the suspension assemblies. They are not very well detailed and it just so happens that the dampers that are on this kit didn’t hit production until August of 1943 on the Pz IV H! The dragon Pzs F1, F2, G and the newer Tamiya H kits all have attempted to mold the correct dampers and have done a fairly good job at it. I was actually planning on fabricating new ones and making resin castings. I don’t know when I will get around to is, but I would be more than happy to send a set to anyone who wants them.
Wildwilliam, your build looks great so far.
Rolgan, you are moving fast, good work!! To post pics, you need to first find a site to upload to. A lot of the FSM forum members use Ron’s site. A thread about how to upload your pics is here:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=10017
Once you have your pics uploaded to a website, you can post them in the forum. To do this, right click the picture that is posted on the web, and click properties. The address of the picture will be shown. Copy this address into your post. Highlight the address in your post and hit the insert picture button on the post menu that you see when you are writing your reply to a thread. I am sure that there are also plenty of threads on the forum on how to post pictures. Good luck
    December 2009
Posted by wildwilliam on Wednesday, June 16, 2004 6:44 AM
Feldgrau,
just seemed to be the simplest way at the time!
w/ one piece, the edge supports are adequate.
if you go w. multiple pieces, then you might end up w/ a problem
trying to brace the inside edge. i am sure it could be done.
edog,,
i appreciate the heads up on the suspension, but the kit is much farther along than those old pics indicate. i will have to put up a few to show where i am now.
but the kit really just needs the drive sprokets, idlers mounted and the tracks put on. and the crew. and a touch of mud or something.
so i will not be chiseling the suspension off of this kit!
i would like to build another someday, in Afrika Corps scheme & configuration,
so if you do make pieces, i would be very interested.
but that would be a ways off.
i would be happy to have them, and also would cheerfully pay postage & materials, plus
rolgan,
check out also my post in this thread:
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=20935
there is a link to a site reviewing free hosts, and a link to a free site
(no registration) that i have used as well.
there are disadvantages to this (can't set up a gallery there, for one)
but it is fast and easy to get pics up and then link them here.
just shout if you need more help. it's pretty easy once you do it once or twice.
Foster - thanks!
how goes the links?
Posted by Anonymous on Wednesday, June 16, 2004 8:03 AM
Will,,, I have been looking at my copy of Pz IV in action and have decided to do mine in the Afrika corps Scheme. My question is and I hope one of you can answer is did the D's that made it to Africa have the aplicue (spelling????) armor on the front??? I am going to add it if it did.
Edog,,, How hard would it be to fasion the dampers outta styrene???? How soon will you have a couple made?? Currently I am doing the D for this build and the J for the D-Day build so I will be doing a PZ IV assembly line.
Posted by Anonymous on Wednesday, June 16, 2004 9:37 AM
Here's the photo of my 1st Pz IV! I haven't tried to take "good" pictures as I have a lot to build. Anyway, let me know what you think.
    December 2009
Posted by wildwilliam on Wednesday, June 16, 2004 10:04 AM
rolgan,
looking good!
feldgrau,
i will check my references when i get home.
are you building the Tamiya kit?
because their D has instructions for the Afrika Corps tank and says whether to use or not.
so i am not sure if you have a different kit, or if you don't believe them.
but i will check my instructions and my references when i get home.
sadly, that will be about 6 hours!
Posted by Anonymous on Wednesday, June 16, 2004 10:12 AM
wildwilliam...... I am doing the Tamiya D and the instructions dont say one way or another about the added armor. Now I may have over looked it in the instructions but I dont remember seeing anything and that is why I asked. Like I said I saw it in the Reference book I have and was going to add it if it was applicable.
Rolgan ..... great looking H you got there.
