F-16 Group Build
Posted by Anonymous on Wednesday, November 1, 2006 6:38 PM
Thanks guys!
Here are 3 more pics, hope to get some major work done this weekend...
Posted by Anonymous on Friday, November 3, 2006 7:07 AM
Hey guys, how can I darken and lighten my paint colors?? I want to do some pre shading, should I just use white and black??
By how much should I add to darken and lighten??
Thanks, Anthony.
    September 2006
Posted by ZzZGuy on Friday, November 3, 2006 4:28 PM
I have finally begun, but only a bit here and there, and i need good weather to prime some parts.
@  Anthony14, i myself would use a darker or lighter version of the basecoat/primer for the preshade as i would not want to change the color (green under blue for example)
Mongol General: Conan, What is best in life?
Conan: To crush your enemies, see them driven befor you, and hear the lamentations of the woman!
Posted by Anonymous on Friday, November 3, 2006 6:22 PM
i've used black and white,but have found better results using the two base colors in the camo sceme you have,,,use the darker color to darken the light and the lighter to lighten the dark,,,try some scrap,,,it just makes the highlights a little less obvious
Posted by Anonymous on Friday, November 3, 2006 6:35 PM
Thanks guys, I also ment to say post* shading...
    May 2003
Posted by kenny_conklin on Saturday, November 4, 2006 9:19 AM
looking great anthony . sorry havent been around in awhile been real busy have everything on hold which really stinks . going to try to get some more done today and hopefully some pics. hope you are all doing well.
"Rakkasans Lead the Way!"
    July 2013
Posted by IL2windhawk on Sunday, November 5, 2006 3:27 PM
I put down the primer layer today.  Overall I'm please with how it came out,
but as always, the primer shows the places that still need a bit of work.
  1/32 Revell Duo Discus
  1/32 Revell ASK-21
  1/48 Ardpol SZD-51 Junior
  1/48 Czech Models Grumman Goose
  1/144 FineMolds Millennium Falcon
Posted by Anonymous on Monday, November 6, 2006 6:52 AM
Looking good!
    July 2013
Posted by IL2windhawk on Monday, November 6, 2006 2:26 PM
Thanks, I can't wait to start applying some REAL paint!  But first I
have a bit more work to do.
I spent a LOT of time adding antennas, nav lights, bumps & bulges
that the kit was missing.  Those little bumps (such as on the sides
of the nose) were built-up from putty and superglue.  It's really hard
to make a perfect teardrop-shaped feature that small, and I fell well
short of perfection.  I'm hoping that some very thick brush-applied
paint will make it nice and round.
Also, I broke the rudder when I was bending the control surface!  I
thought that the seam wouldn't be noticeable, but it is indeed quite
apparent (even more than in this particular picture).  I will do what
I can with it, but this might end up being one of those flaws that just
gets stuck on the model.  Maybe the paint will make it less obvious.
Or I guess I could just cut it off and make a new rudder out of sheet
styrene. hmmm..... :)
  1/32 Revell ASK-21
Posted by Anonymous on Monday, November 6, 2006 6:14 PM
problems.........
i washed this kit good,primed it right,,,,now i have some areas on the lower rear that are lifting no matter what i do,,,i don't think stripping it is an option because the cockpit is installed(no wings,tail or stabs yet,,,,,any ideas?
Posted by Anonymous on Monday, November 6, 2006 7:06 PM
 lone wrote:
problems.........
Sand down that area and repaint it...
Wierd...
Posted by Anonymous on Monday, November 6, 2006 8:02 PM
that's what i started doing,and light,LIGHT coats to get the gloss white back over the grey,,,,i think it was a problem with the primer,so i'll skip that on the fix
i'm hopeing that will be the worst problem with this build,i had such high hopes for a great build,now i think it'll just be an average finish
Posted by Anonymous on Monday, November 6, 2006 8:51 PM
Think positive!
Good luck!
    July 2005
Posted by painklr on Wednesday, November 8, 2006 8:46 AM
I borrowed a camera from a friend and was able to get some better shots of my F-16.  Comments are appreciated.
Thanks,
Painklr
Posted by Anonymous on Wednesday, November 8, 2006 2:05 PM
that thing looks beautiful,,,,great job now just tell your friend that you lost the camera so that you can keep it,,,good looking pics
    August 2006
Posted by mr.chex on Wednesday, November 8, 2006 2:40 PM
Jaw drop.....Wow amazing
GO HUSKERS!!!! Projects 1/72 VF-102 F-14B "Diamond Backs" 1/72 German Mig-29 1/72 German RF-4 1/48 What If German F-16
    October 2005
Posted by MKopack on Wednesday, November 8, 2006 3:11 PM
Great job everyone. I'm having fun following everyone's progress on their own Vipers! MPH34 - at least in a small way your tigerstriped bird is mine as well, I spent quite a bit of time maintaining 87-0241 as a member of the Torrejon based 614th TFS, deployed to Doha, Qatar.
241 flew 45 missions to Kuwait and Iraq during the war after she was sent down from the 613th TFS 'Squids' as a replacement for one of the aircraft that we'd lost on 19 Jan '91. For more info I invite you to visit the Lucky Devils in the Gulf War at: http://www.lucky-devils.net
I worked Blocks 1, 5 10, some 15, and 30 with P&W and GE engines, so if there are any mechanical questions, please don't hesitate to ask.
Mike Kopack
F-16A/B/C/D P&W/GE Crew Chief and Phased Maint. 56TTW/63TFTS 1987-1989 401TFW/614TFS 1989-1991 3.7 million pounds of ordinance, 1303 sorties, 42 days. The 'Forgotten 1000'. Visit the Lucky Devils in the Gulf War at: http://www.lucky-devils.net
Posted by Anonymous on Wednesday, November 8, 2006 3:48 PM
Looks great!
Posted by Ishthe47guy on Wednesday, November 8, 2006 4:10 PM
Helloo.  How crazy do you have to be to join this GB?  I'm also a participant in the F-15 GB, since that's what I have on the bench.  I've bought a bunch of 1/48th F-16 decals in the last three weeks, mostly 2Bobs & Afterburner, but as of right now, I only have one measly kit, the Revellogram F-16ADF kit.  I'm waiting on 4 of the Hasegawa C kits to arrive.  Squadron is having a sale this month on the Academy 1/48th kit for $13. Might have to get me some of those.  Also, just ordered 4 Hasegawa F-16D kits from Roll models for $13 each, but I know I won't see those in my mailbox till early December.     I'm really undecided on what to do first.  I live in Dallas now, which is just next to Ft. Worth, home of the F-16.  Having said that, I could do an aircraft from one of the 2 ANG squadrons here in the state (Houston & San Antonio).  There is another Air Force Reserve  F-16 unit here in the metroplex, but decals don't exist for it yet.  I'm on an Adversary/Aggressor kick, so I could do one of those.  I managed to get some photos of the Viper East Demo team, so I could do both of those, providing I buy  two of the Hasegawa CJ kits.  I also managed to get up close & personal with the T-birds jet after they did a show here last month.  Not sure I want to mess with those large decals out of the gate. Lastly, but high in the running of my personal favorite schemes on an F-16, is the retro, red tailed Tuskegee Airmen, Air Force 50th Anniversary scheme on an 302nd C model from Luke AFB.
Given the time limit is February, I can reasonably expect to be able to finish only one model buy that deadline, considering my other projects.
Kenny C, we have some things in common.  I was born & raised in NYC (Brooklyn), & went to college in Queens (College of Aeronautics, across Grand Central from the Marine Air Terminal at La Guardia).  By your tag line, I can tell you were a "Flying Umbrella" while you were at Campbell, whereas I was just down the road with "Varsity", B-7-101 AVN as a CH-47 mechanic & crew chief from '93-‘96.
I hope to finish my current project by the end of Thanksgiving weekend.  I was planning on starting a A-4 Adversary, but I think I'll start on that lone F-16 kit I have in the stash with decals for the Houston unit, since they flew the ADF version.
Ish Out
Native New Yorker, like the F-14
    May 2003
Posted by kenny_conklin on Wednesday, November 8, 2006 5:29 PM
hey ish ,
 i was born in manhattan and raised in astoria queens. i work by that college everday so i know exactly where you are talking about. yup i was 101 but i was told rakkasan was japanese for "falling down umbrella" :) since they didnt know what to call paratroopers. and i see we were there at the same time you left after me though i was there from 93 to 95. it is always cool to meet someone from the area. good luck on the build talk to you soon
kenny
Posted by Anonymous on Wednesday, November 8, 2006 7:27 PM
Hey guys, I got my tail art all done, and dam! Does she look great! No pics, I want to keep the finished project a surprize Big Smile [:D]
I'll keep you posted!
    August 2006
Posted by mr.chex on Wednesday, November 8, 2006 7:29 PM
Mike  welcome aboard. Can wait to see your stuff.
I was ondering if since everybody seems really bussy if you guys want to push the deadline back another month or so?
-Grant
Posted by Anonymous on Wednesday, November 8, 2006 8:02 PM
i'll be ok with the same deadline,now that my paint disaster is fixed,i'm back on the move
here's a couple of progress shots
    May 2003
Posted by kenny_conklin on Wednesday, November 8, 2006 8:28 PM
i m fine with the dead line too :)
Posted by Anonymous on Wednesday, November 8, 2006 8:47 PM
You could move it if you want, I don't mind, when is the deadline??
    July 2013
Posted by IL2windhawk on Thursday, November 9, 2006 12:06 AM
I will probably finish the 1:72 bird in time, but I had already
accepted that the 1:48 project wouldn't be done in time,
since I haven't hardly started it at all yet.
I say leave the deadline where it is.  Those of us who finish
late finish late, no big deal :)  I'm sure everyone will check to
see the finished work anyhow.
good work above!  cool!
  1/32 Revell ASK-21
    August 2006
Posted by mr.chex on Thursday, November 9, 2006 5:06 PM
Thats fine with me i just thought i would ask. Just make sure you guys post pictures of all you Vipers when youre done.
Posted by Anonymous on Saturday, November 11, 2006 11:23 AM
Ok guys, not quite done, but 90% there. Just got the lower half to finish...
Any and all comments welcome!
    August 2006
Posted by mr.chex on Saturday, November 11, 2006 5:10 PM
B-E-A utiful
Posted by Anonymous on Saturday, November 11, 2006 5:15 PM
absolutley beautiful,the tail is a real eye catcher
