...............so I got to thinkin'....this
is aluminum you know. Why Alclad when all I have to do is
polish? I had to go backwards a step here but I think it's going to be worthwhile. I cut another fenderwell out, removed the protective coating with steel wool, sanded it down using the typical 3200grit -12000 grit sanding pads and polished it up.
I think I'm going to like this ALOT better:
Then I cleaned up the hood emblems, painted the low lying areas and shot a coat of gloss clear over each one.
