Ship Trivia Quiz
    February 2016
Posted by alumni72 on Friday, January 23, 2009 6:27 PM
Coal to oil?
I was going to suggest WW1 and the Depression, but that wasn't technological.
    January 2005
Posted by bryan01 on Saturday, January 24, 2009 4:52 AM
Changing from coal to oil fuelling was a big improvement. So was the development of more efficient propellers.
But in the quest for speed those improvements were of relatively minor influence.
Bryan
    February 2006
Posted by RickF on Saturday, January 24, 2009 6:19 AM
Could it be the introduction of radar, enabling faster speeds further north through the ice, and at night?
Rick
    January 2005
Posted by bryan01 on Saturday, January 24, 2009 6:40 AM
No, I'm sorry, but you're not thinking in the right direction (is that proper English Confused [%-)]?).
Would the Kaiser Wilhelm der Grosse be capable of sailing at 31.5 knots if she had radar? Could more efficient propellers do that? Or oil fuelling instead of coal?
Think like an engineer!
Bryan
    February 2006
Posted by GeorgeW on Saturday, January 24, 2009 9:28 AM
Hmmn, so it's not the props, not the fuel type, although I understand that the Btu value of coal was of increasing interest as the coal powered steam engine advanced thro' the 20th century.
What's left - hull design, boiler efficiency perhaps, increased pressure capability, super heated steam - this ones making my brain hurt BryanWink [;)]
    January 2005
Posted by bryan01 on Saturday, January 24, 2009 10:08 AM
Banged Head [banghead]...all the things you mention are merely refinements of an existing design (except hull-design, I have to admit that's a pretty huge refinement). You're forgetting one crucial point here! But I'm not giving up yet Wink [;)]
Think about it this way: Despite being larger, heavier and less fuel efficient my wealthy neighbors' Mercedes-Benz S600 is much faster then my Ford Fiesta.
Why?
Bryan
    March 2004
Posted by subfixer on Saturday, January 24, 2009 10:54 AM
Turbines vs reciprocating engines.
I'm from the government and I'm here to help.
    January 2005
Posted by bryan01 on Saturday, January 24, 2009 11:42 AM
And what can a Turbine develop with far better fuel efficiency, less weight, much less vibration and by occupying far less space compared with a reciprocating engine?
Bryan
    February 2006
Posted by GeorgeW on Saturday, January 24, 2009 12:16 PM
More power, larger engines, but how would that relate to the original question regarding the reason for the lack of advancementConfused [%-)]
I think I'm losing the will to live, Bryan, we presumably can't see the wood for trees, so either an even bigger hint is required or you may have to put us out of our misery.
    April 2005
Posted by ddp59 on Saturday, January 24, 2009 1:05 PM
turbines produce more horepower per weight then a similar size reciprocating engine. in the nevada class battleships, the oklahoma has the reciprocating engine whereas the nevada has the turbine.
    March 2004
Posted by subfixer on Saturday, January 24, 2009 1:20 PM
Another thing is something termed " hull speed", a vessel's hull can only push so much water out of the way no matter how much power it has pushing it. A planing hull is slapping along on top of the water whereas a conventional hull is moving through it. And with that, I am pulling out of this question and will wait for the traditional questions to return to this thread. The quiz has become a bit too cryptic for me.
    January 2005
Posted by bryan01 on Saturday, January 24, 2009 2:24 PM
Ok then, I will put you out of your misery although by saying more power you actually answered the question (obviously without realizing it yourself). It is power that you need, and huge amounts of it! Faster ships required more power then engine manufacturers could actually develop.
Marine engine development did make giant leaps but because of the hydrodynamic properties of water the advancements that were made weren't very obvious. Why? How difficult can it be to increase the speed of a ship by one lousy knot!?
The answer is: very difficult. Let's take the Kaiser Wilhelm der Grosse as an example. Her two triple expansion reciprocating engines developed 31.000 shp powering two propellers. That power was sufficient to give her an average speed of 22.5 knots. If she however wanted to increase that average speed too let's say 23.5 knots then her engines would have to develop 25% more power to overcome the additional drag caused by the bow wave, something she was obviously not capable of. With the 33.000 shp engines of the Deutschland 1900 the limits of the reciprocating engine were reached. This ship suffered from severe vibrations.
The turbines of the Lusitania and Mauretania in 1907 developed 75.000 shp, enough to raise speed to about 25.5/26 knots. More power however also means more engines, more boilers, higher fuel consumption and the need for more propellers (4 instead of 2). All this resulted in a larger and therefore heavier ship which in turn caused even more drag.
And so a vicious circle developed: Bremen and Europa 1929, 100.000 shp, 28 knots. Rex 1933, 127.000 shp, 29 knots. Normandie 1937, 160.000 shp, 31.20 knots and it all more or less ended with the Queen Mary in 1938. To attain a speed of 31.69 knots she required a massive 200.000 shp! Only the continuous improvements in engine technology and especially power output could make this possible.
So, when I said: What was the cause of this disappointing achievement while other technologies seemed to make giant leaps? the right answer would have been that it wasn't a disappointing achievement at all, far from it actually! From 31.000 shp to 200.000 shp in 40 years, not to bad. Even today, 70 years after Queen Mary's record run, the large US carriers with 260.000 shp and unlimited fuel supply can't sail faster then +/-35 knots.
George, you're next.
Bryan
    February 2006
Posted by GeorgeW on Saturday, January 24, 2009 6:42 PM
Phew Bryan, not so much an answer more a dissertation, that one hurt!
Now a more straightforward one.
The years 1871 and 1879 must have been of great relief to sailors of the RN, why?
    February 2016
Posted by alumni72 on Saturday, January 24, 2009 8:52 PM
I'm guessing that in one of those years, the first heads were installed onboard ship.  Big Smile [:D]
    February 2006
Posted by GeorgeW on Sunday, January 25, 2009 2:13 AM
Nice link, but no.
    January 2005
Posted by bryan01 on Sunday, January 25, 2009 6:34 AM
1871: flogging in peacetime was suspended.
1879: flogging in wartime was suspended.
Bryan
    February 2006
Posted by GeorgeW on Sunday, January 25, 2009 8:34 AM
Once again you are correct Bryan, over to you.
    January 2005
Posted by bryan01 on Sunday, January 25, 2009 9:40 AM
Thank you George!
Next QUESTION:
How can a lipstick, a torch and a mirror be responsible for saving numerous lives at sea?
Bryan
    February 2016
Posted by alumni72 on Sunday, January 25, 2009 11:19 AM
For those of us in the US, a torch is a flashlight.
And I can't believe I didn't think of flogging - I'm reading Sharpe's Tiger at the moment. Sigh [sigh]
    March 2004
Posted by subfixer on Sunday, January 25, 2009 1:57 PM
Yeah, a flashlight in England is called a "torch", but bryan lives in the Netherlands. No telling what he is referring to, it's probably one of those mystery questions that will only be answered by George or woodburner.
It's obvious that a flashlight and a mirror would be signalling devices but as to lipstick? Maybe, if you melted it, you could use it as a dye marker, or, since it is made with fishscales, it could used as fish bait or a lure. Or to leave waterproof messages or whatever. I guess we should ask McGyver.
Anyway, what shade of lipstick? Survivors can't be choosers, you know.
    January 2005
Posted by bryan01 on Sunday, January 25, 2009 3:34 PM
You know Subfixer, you are quite funny! When I was a kid I loved watching McGyver, me and friends thought he was a real genius!
You're actually thinking in the right direction with your signaling devices. The lipstick, torch and mirror were used to demonstrate an invention. It was quickly adopted by all navies that needed it. And although the inventor was British your country's navy is actually the one that most benefited from this invention, and still does.
Bryan
    March 2007
Posted by searat12 on Sunday, January 25, 2009 4:45 PM
Hmmm!  My first thought was a strip-tease act, which of course has been of enormous benefit to every navy in the world (when in port!), but perhaps a signalling light for morse code would be a more appropriate answer?
    January 2003
Posted by davros on Sunday, January 25, 2009 5:18 PM
It sounds like the Mirror Landing Light system. First demonstrated with a handbag mirror and a line drawn with a lipstick. I remeber seeing a TV programme where the demonstration was re-enacted.
Here are the details... http://en.wikipedia.org/wiki/User:TrevBrum#Mirror_Sight_Concept.
    January 2005
Posted by bryan01 on Sunday, January 25, 2009 5:24 PM
Davros, You're the best! Well done.
You're next.
Bryan
    March 2004
Posted by subfixer on Sunday, January 25, 2009 5:31 PM
Where does the torch (flashlight) come into it?
    January 2005
Posted by bryan01 on Sunday, January 25, 2009 6:30 PM
Goodhart planned on using powerful lights (the torch) when his system was used on a real ship.
Stories differ whether or not a torch was available at the office of Cambell when he demonstrated the concept. Some say the lipstick was only used to draw a line on the mirror; others say the lipstick was used in the way described by the link Davros provided.
Either way, Davros answered the question correctly (with or without a torch).
Bryan
    January 2003
Posted by davros on Monday, January 26, 2009 1:46 PM
It's always a struggle to come up with a new question but here is mine. Although it's a two-parter it will probably be fairly easy.
 A submarine of this country's navy was the first to fire a torpedo whilst submerged. So; which country and what was the name of the submarine?
    March 2004
Posted by subfixer on Monday, January 26, 2009 2:35 PM
I believe that it was the Ottoman Empire's Abdulhamid.
File:Ottoman submarine Abdulhamid 1886.jpg
    January 2003
Posted by davros on Tuesday, January 27, 2009 4:28 PM
Actually; I was thinking of Turkey rather than the Ottoman Empire but as the two have become synonymous I will "pass the baton" on to you, subfixer.
    March 2004
Posted by subfixer on Tuesday, January 27, 2009 6:15 PM
Thank you, davros.
Here's one, please excuse my atrocious attempt at poetry.
I was the second of nine,
the first of my kind,
the shortest waterline.
The sea, I did grind.
But I, now, you won't find.
Once, I used fission to fulfill my mission,
Once, atoms I used, now, into atoms I'm fused.
Who was I?
(This shouldn't be too hard)
