Thanks for the compliments, everyone, I appreciate them.
There isn't an "in depth" article per se, but I'm happy to share with you how I did the MARPAT. Believe it or not, this is the third time I've attempted the digital scheme on a model. I think this one turned out the best, by far. The materials required are masking tape, a sharp #11 blade, a straight edge, and time.
First, I lay down the base coat/lightest color and let it cure. Then I take a strip of tape, stick it to my cutting pad and start slicing rectangles and squares of different sizes. The key, I've found, is keeping the tape bits all aligned along the long axis of the model, otherwise you get more of a splinter effect than the grid-like digital look. Once I have enough tape on the kit, I spray the next color, and let its just lather, rinse, repeat for each successive color. Depending on drying/curing time, I've done the whole thing in a couple of days from start to finish. Once the last color is on and dry, start peeling off the tape and you'll have MARPAT in no time.
You could also take the tape off between each color/layer and see how that works. I might go that route on the next MARPAT project I come up with.
I was still picking bits of tape off this one up until the final flat coat went on, they had blended in so well...
A day in the Corps is like a day on the farm; every meal is a banquet, every paycheck a fortune, every formation a parade...
The Marine Corps is a department of the Navy? Yeah...The Men's Department.
