Hi, All,
Seeing the inside of the 47-section again for the first time in 45 years brings back memories of how we did maintenance back then. Forgive me if I get a little wordy here - I just might forget all this soon
Every aircraft tech had two important tools - a pair of "cannon plug" pliers and a pair of safety wire pliers. The cannon plug pliers were used to loosen or tighten the knurled locking ring on a cannon-type connector (see below). The pliers shown in the next picture are my own pair that I've kept throughout my maintenance career.
![](http://i1175.photobucket.com/albums/r637/Striker8241/B-52D%20Model/cannonplugs_zps3642fbd5.jpg)
![](http://i1175.photobucket.com/albums/r637/Striker8241/B-52D%20Model/cannonplugpliarscirca68_zpse716ffcf.jpg)
Cannon connectors consisted of two parts - a keyed central plug that locked into the cannon receptacle on the unit and a rotating ring that engaged the receptacle and tightened the connector. These connectors were used on our wire cables that connected our ECM equipment to the aircraft systems.
Once the connector ring was tight, it had to be safety wired. There were holes drilled in the inserted part of the plug and in the rotating locking ring. You put a loop of steel safety wire through the stationary plug, clamped the two loose ends in the jaws of the safety wire pliers, and pulled on the central handle. The pliers spun and wound the handle, twisting the wire into tight twists. Then you inserted one of the loose ends through the hole in the rotating ring, again clamped the loose ends, and pulled to twist the wire tight. A picture of the safety wire pliers and an example of a safety wired connector are shown below.
![](http://i1175.photobucket.com/albums/r637/Striker8241/B-52D%20Model/Safety20Wire20Pliers-1_zpsf70f640e.jpg)
![](http://i1175.photobucket.com/albums/r637/Striker8241/B-52D%20Model/connectorssafetywired_zpse7e42d42.jpg)
