1/72 B-52D with Big Belly Mod, Operation Arc Light
    April 2012
Posted by Striker8241 on Thursday, October 11, 2012 8:52 PM
NOTE: Information in brackets [ ] has been copied from a previous thread into this post without responses and comments, so some disconnects in the dialog may be apparent.
[Here is my APS-104 nav radar antenna that will go into the chin. Since the plane will be part of a diorama, the chin radome will be shown removed while the radar is being worked on. Unfortunately, I only found one picture of the antenna and that from the back. I had to guess at the feedhorn assembly.
I'm just about to button up. I finished up the nav antenna compartment (chin radome), such as it is, with a sprinkling of equipment to simulate much more that would be in there; unfortunately, I don't have any good pictures of this compartment, probably because the equipment in those days was classified or sensitive. I'll wait to install the antenna until I put on the final fuselage details.
I added the upper port and starboard cooling vents in the 47 Section but will have to wait on adding the lower 6 until after the fuselage is closed and I start on the ECM antennas.
[Below is a picture of the turret on a real aircraft and my model of the B-52D gun turret with the right-side cover removed for maintenance. I remember watching the MMS troops working on these guns. They would be up to their elbows in oil and grease in the blazing hot sun. Those guys had the hardest job of all, even worse than ECM, and we worked really hard. A lot of MMS troops eventually deleloped liver or kidny problems or cancer from working with the gun grease remover. No other shop had more to do or worked harder than MMS.
[Below is a picture of an actual B52D tail gunner's compartment (courtesy of G. Holmes) and my model with a few details added - my details are only suggestive, not accurate.
I've had to work in this compartment many times. It's very narrow and confined, with cables, hoses and cords hanging down that make it even more crowded. The seat folds down so you can get in and out. There's a hatch that opens to the outside at the right rear of the compartment and another hatch just past that one that opens inside into the 47-section where we had our jamming transmitters and chaff dispensers.
Tags: B-52D , fuselage
    April 2012
Posted by Striker8241 on Tuesday, October 16, 2012 9:33 AM
56-612 is finally buttoned up! I will be adding the cockpit and tail gunner canopies next once I get them painted. I've also started re-scribing the vertical stabilizer. A lot of errors there in the panel lines - I don't intend to be fanatical about them but I do want the majority of the lines to be reasonably accurate. The kit also left off what is most likely an antenna cover near the top that I'm adding on either side.
Cheers,
Russ
Tags: B-52D , tail
Posted by rossjr on Tuesday, October 16, 2012 11:04 AM
I apologize if this has been asked and answered already.  I read through all the posts and didn't see this but who's kit are you building?  Things are looking great!
    April 2012
Posted by Striker8241 on Tuesday, October 16, 2012 11:24 AM
rossjr
No apologies necessary, my friend. In fact, my thanks to you for pointing this out. I didn't realize I left off the model description in the introduction. I will correct it.
The model is Monogram's 1/72 B-52D, kit #5709.
Thanks for stopping by, and for the good words Big Smile
Russ
Posted by Gamera on Friday, October 19, 2012 11:31 AM
She's coming along great Russ, please keep up the good work!
    April 2012
Posted by Striker8241 on Friday, October 19, 2012 12:49 PM
Thanks, Gam!
    April 2012
Posted by Striker8241 on Tuesday, October 23, 2012 9:02 AM
For a change of pace, I've started on the wings. The trailing edges of the real wings on the B-52 are very thin compared to the overall wing dimensions and the kit's edges are pretty thick, so it requires a lot of sanding to get them even close. One note: if you've ever been around a fully-loaded and fueled buff with the flaps fully extended, the corners of the flaps are about at eye level and very sharp and pointed. Definitely a safety hazard but oddly enough, I never saw any safety cushions for them. You just had to be careful walking around them.
Since I plan to have bomb loading in progress, the flaps have to be in full up position for ground equipment clearance. That requires a lot of work to get the trailing edges of the flaps to match up with the wings - the kit flaps were obviously not intended to be fully retracted in the model. Sadly, the model's flap assemblies don't look anything like the real flaps. I had to fill notches in the back edges that do not exist on the real flaps. The picture below shows progress on the wings.
Updated 7/9/19
Also, I wanted to show the ailerons "cocked" as they often were. To do that, I had to cut them out - a very frustrating task since the top edges don't exactly match up with the bottom edges.
I discovered that it would be best to cut the ailerons out from the bottom of the wing, as shown in the photo below, using the sides of the bottom part of the aileron as guides. The cut-out ailerons should look like mine in the picture above, only a lot cleaner.
To show the ailerons cocked on the model, glue one pointing up and one pointing down.  The photo below shows the left wing with the mounted aileron in the down position; if flying, this would indicate the plane was making a right turn. Now, if you're really picky, you'll want to have the controls in the cockpit turned to the corresponding position - to the right in this case Smile.
Cheers,
Russ
Tags: B-52D , wings
    April 2012
Posted by Striker8241 on Wednesday, October 24, 2012 1:21 PM
Hello, All,
I've finally completed the bomb lift trailer (again). I had to rebuild the end unit to make it larger so it could accomodate the trailer. Unfortunately, I lost the numbers in the process, but hope to find some more soon. The images below show a bomb clip transporter before and after it's moved into the lift trailer.
Cheers,
Russ
[ NOTE: The wheels on the transporter here are too small and were later replaced with correct size wheels. Also, the transporter itself was upgraded, as shown below.]
Upgraded Transporter
Tags: B-52D , bomb , lift , trailer
    November 2010
Posted by Son Of Medicine Man on Wednesday, October 24, 2012 7:04 PM
Striker8241
Hello, All,
I've finally completed the bomb lift trailer (again). I had to rebuild the end unit to make it larger so it could accomodate the trailer. Unfortunately, I lost the numbers in the process, but hope to find some more soon. The images below show the bomb trailer before and after it's moved into the lift trailer.
Cheers,
Russ
Nice work Russ!  Your attention to detail is amazing!  Yes  Yes
Ken
    April 2012
Posted by Striker8241 on Wednesday, October 24, 2012 7:19 PM
Thanks, Ken! Big Smile   There's a color mismatch between the two - I want the colors more like the lift trailer so I'll touch up the bomb trailer later. Hopefully I can also find slightly larger wheels so I can make the trailer look more like the real ones.
Thanks again, bud, for the good words!
Russ
    February 2010
Posted by Bockscar on Wednesday, October 24, 2012 8:27 PM
Striker8241
Bockscar
Russ:
What did you use to saw that flap out?...and what did you fill it with? -Thanks
Dom
Hi, Dom,
I assume you mean the aileron since I didn't do any cutting on the flaps. I used a sharp #11 blade and a flexible straight edge and just kept cutting until I was through. Check the alignment of the edges of the aileron top and bottom with the flap openings - mine was off a bit on the bottom of the left wing and I had to cut at a slight angle. The pieces are so thick that I didn't need to use any fill.
Russ
Thanks Russ:
After what you mentioned about flap assemblies not being very accurately detailed, I wasn't sure what I was looking at there, I haven't been around enough BUFFS to know. That sounds like a good cutting strategy, I'm guessing it kept the cut gap to a minimum tolerance.
Err, I do know what those spoilers look like though....that one would be hard for Monogram to mess up....Tx again
Flaps down, yeh, pretty close to the ground:
So Russ, is that gap in the flaps for the engine blast, is that where the aileron you've cut is positioned?
Dom
"God does not subtract from our time on earth
the hours we spend modeling."
 Russ: Thought I should post those BUFF snaps here.
That lift assembly looks great!Yes
Dom
    April 2012
Posted by Striker8241 on Wednesday, October 24, 2012 8:50 PM
Bockscar
Hey Dom,
That bird is riding pretty high. Likely it's not been refueled or bombed up. With a full fuel load + bombs, the wings will be much closer to the ground and the inner flap corners (on either sides of the ailerons) will be right about head level.
Bockscar
Yup.. Remember though - the D-models were the last to use ailerons [Correction - the F models were actually the last with ailerons]. Your pictues are of G or H models.
The ailerons are pretty well outlined on the model, including the two trim tabs at the bottom. Just check that the aileron edges match up top and bottom.
And thanks for the good words on the lift trailer Big Smile.
Cheers,
Russ
    February 2010
Posted by Bockscar on Wednesday, October 24, 2012 9:00 PM
Russ,
thanks for that reminder,
I'll have to go back and find a D-model to have a closer look.
You brought up a good point, I remember hearing someone on a show on
the Military Channel say the BUFF had no ailerons, only spoilers.
I wish I could have heard the conversations a Boeing about
getting rid of that feature!Smile
In the meantime, here she is, flaps up:
Dom
    April 2012
Posted by Striker8241 on Wednesday, October 24, 2012 11:10 PM
Bockscar
Dom
Nice! Big Smile
    April 2012
Posted by Striker8241 on Friday, October 26, 2012 9:21 AM
The ram air intake port at the left wing root is not rendered correctly, at least on my model. The model has it extending into the upper wing, similiar to the input port near the pylon. However, the port should only be on the lower wing root, as shown below. To correct this, you'll need to fill in the upper section.
Tags: B-52D , wings
    April 2012
Posted by Striker8241 on Saturday, October 27, 2012 11:14 AM
I discovered that the easiest way to cut out the ailerons and keep them straight on the B-52 model is to cut from the bottom of the wing following the edges of the flaps. The aileron outline on the bottom seems to be more correct that those on top. There may be some ragged edges on the top wing, flaps and top of the aileron, but you can fill and sand these.
Cheers,
Russ
    April 2012
Posted by Striker8241 on Saturday, November 3, 2012 9:48 AM
Hi, All,
Sorry I haven't posted any updates in a while. I've been struggling with these wings. And I thought the fuselage was difficult!  At any rate, I finally got the wings scribed (I decided not to scribe the undersides since they won't be seen anyway, so that saves a lot of work).
Updated 7/9/19.
When I tried the wings on the fuselage I discovered that they don't have the necessary droop for the outrigger gear to touch properly. I read previously of one modeller's solution to this, but he cut slots in the top wing to insert strips of styrene. I didn't want to mess up the top so instead, I removed a 1 mm  strip on the underside of the wing. If you want to try this, follow the steps below.
NOTE: You will need to have the fuselage assembled with the main wheels attached to test the wing droop.
1.) Assemble the top and bottom wing sections according to the kit instructions and glue them together. Do not glue the flaps in! Once the wing is dry, pull the flaps all the way out, or remove them.
2.) Lay each wing with the bottom side up.
3.) Measure 135mm from the wing root along the leading edge of the wing and make a mark.
4.) Starting from the mark, draw a line parallel with the inboard slot for the nacelle strut, to the trailing edge of the wing.
5.)  Using a sharp #11 Xacto blade, carefully make a 1 mm wide cut along the line (see first photo below). Remove the cut material.
6.) Place objects under the wing on either side of the cut so that when a weight is placed over the cut, the walls of the cut will close together.
7.) Remove the weight and apply a strong glue to the cut, then reapply the central weight.
8.) Perform the same procedure on the second wing. Allow the wings to dry for at least 24 hours.
9.) Sand and finish the cut areas.
10.) To verify the wing droop, cut two wooden toothpicks to the length of the outriggers from the bottom of the tires to the tips of the mounting pins at the top of the gear.
11.) Insert the toothpicks into the mounting holes for the outrigger gear.
12.) Place the model on a flat surface and temporarily install the modified wings in the fuselage. NOTE: If you've already flattened your main gear tires, you will need to flatten the outrigger tires to match the length of the toothpicks. Keep in mind that the outriggers slant slightly backwards with the wing installed so flatten the tires accordingly.
13.) Verify that the wing roots are flat against the fuselage with the tips of the toothpicks resting on the surface. If the the toothpicks are too long, you can compensate by flattening the outrigger tires accordingly. If the toothpicks are too short, You can lengthen the pin at the top of the outrigger assembly.
14.) Carefully re-install the flaps. You may have to shorten the length of the flap assemblies slightly and institute a slight curve to match the wing's new curve.
Cheers,
Russ
Tags: B-52D , wings
Posted by Bish on Sunday, November 4, 2012 3:13 AM
Russ, your a braver man than me re scriding those huge wings. This is looking good.
    April 2012
Posted by Striker8241 on Sunday, November 4, 2012 7:20 AM
Thanks, Bish Big Smile.
The re-scribing wasn't actually that hard - I spent more time correcting my mistakes Big Smile. I couldn't seem to find two panel diagrams that were the same, and these disagreed with actual photos so it was difficult to decide which lines should be included. I went by the photographs wherever possible, but there are few that show the top wing panels and even fewer that show them clearly.
The hardest part was smoothing and thinning the trailing edges, and cleaning up the leading edges. They're pretty ragged and needed a lot of filling. And the plastic for the wings was harder than for the fuselage, probably because the plane was intended to be suspended from the ceiling.
Russ
    April 2012
Posted by Striker8241 on Wednesday, November 7, 2012 7:36 PM
I'm close to finishing the wings and right now I'm tackling the spoilers. The kit has a slot for the spoiler but the whole spoiler assembly (including the "feathers") fits into the slot when actually, the feathers overlapped the wing as shown below:
I filled in the lower part of the slot with a 7 mm strip of plastic.
I then had to sand the strip, the wing along the edge of the strip, and the back side of the spoiler behind the feathers to get the spoiler to lay flat. I also sanded the feathers from the top to make them thinner (the spoiler is just tacked on in the picture below to see how it fits).
Cheers,
Russ
Tags: B-52D , wings
    February 2010
Posted by Bockscar on Wednesday, November 7, 2012 7:45 PM
Great looking work there Russ,
those spoiler feathers in the photo almost look like dentils, are they actually flat or raised up a bit like teeth?
Dom
    April 2012
Posted by Striker8241 on Wednesday, November 7, 2012 8:31 PM
Bockscar
Dom
Thanks, Dom. They were actually flat, as you can see in the photo below, just like they were rendered in the kit. On the other hand, the spoiler body was really tapered but the kit rendered it flat. To compensate and keep the spoiler even with the top of the wing, you end up tapering the feathers.
(Photo courtesy The Boeing Company)
I further thinned the feathers so it's hard now to see that they are slightly tapered. You have to be careful not to get them too thin or they'll break off. Being tapered slightly makes them a little stronger.
Tags: B-52 , spoilers
    February 2010
Posted by Bockscar on Thursday, November 8, 2012 8:49 PM
  • Hey Russ, I've been looking at that spoiler shot you provided:
     What I am seeing is that the top of each feather on the spoiler has a re-enforcement, like a small bubble ridge that goes from the back edge up past the feather root and a few inches back from that. Maybe to stop those feathers from ripping off?
    you can see the arch and shadows of those ridges if you blow up the photo.
    Am I seeing things?
    Dom
    Edit
  • Bockscar
    Am I seeing things?
    Dom
    No, no, no.  I think you are way off base there Dom.  I think they are back scratchers!  Big Smile
    Ken
  • Son Of Medicine Man
    Bockscar
    Am I seeing things?
    Dom
    Ken
    Errrr, that's very embarrassing Ken;
    I thought I was the only one who used 'em fer that!Big Smile
    See Themza' onez' bent up an' all like that?
    they'za the wons' wot hit warts.....Ick!Big Smile
    Hey:
    There's a great shot of the upward wing flex:
    Dom
    Edit
  • Walter Boyne:
    air-boyne.com/b-52s-60th-birthday-coming-up
    Dom
    Edit
  • Big Brother:
    http://rbogash.com/B47.html
    Dom
    Edit
    February 2010
Posted by Bockscar on Thursday, November 8, 2012 8:55 PM
By the way Russ, for the upward Flex shot, see how the wing root up to the inboards has very little flex.
That's one of the pics I used to base my wing flex on for my build.
Dom
    April 2012
Posted by Striker8241 on Thursday, November 8, 2012 9:01 PM
Bockscar
Dom
I see that. Pretty extreme eh? Must have been a pretty turbulent approach.
Russ
    April 2012
Posted by Striker8241 on Friday, November 9, 2012 10:32 AM
B-52D outriggers:
I didn't care for the way they did the outrigger wheels on this model - the wheels are molded together with the strut yokes. It's possible they did this for strength so the outriggers could support the pressure from the sloped wings.
I decided to remedy the problem. I happened to have the main gear wheels from an old 1/72 F-4 model that were just about the right diameter. They are a little thick, but you can't have everything Smile.
For the axels, I used a common sewing pin. I inserted a pin through each wheel with the head on the outside hub and glued it into the wheel, making sure the pin was perpendicular to the wheel all around.
Next, I carefully cut away the wheels from around the yokes. If you use a spru cutter, be careful not to deform the yoke. Then I cleaned out and sanded the yokes. I drilled a hole the size of the pin through each yoke at the axel point.
NOTE: If you plan to flatten your wheels, do not glue them to the struts at this time. Wait until the model is ready to stand on its feet and then attach the wheels so you can match the flat spot to the tilt of the wings.
Once the glue around the pin is hardened, insert each wheel through the hole in the axel and cut off the excess pin, then glue the axel in place.You will also need to file down and finish the hub on the outside of the axel.
Cheers,
Russ
    February 2010
Posted by Bockscar on Friday, November 9, 2012 6:02 PM
Striker8241
B-52D outriggers:
I've never been happy with the way they did the outrigger wheels on this model - the wheels are molded together with the strut yokes. I know they did this for strength so the outriggers could support the pressure from the sloped wings. Any type of plastic axel that could support the weight would have to be oversized - anything smaller would break.
Once the glue around the pin is hardened, insert each wheel through the hole in the axel and cut off the excess pin, then glue it in place. I also plan to glue the inside of the wheel to the strut for added strength. You will also need to file down and finish the hub on the outside of the yoke.
 Cheers,
Russ
Nice work there Russ!Yes
They never painted those outriggers up in Hawaiian colours,
did they?Smile
I don't think anyone other than the super-geeks will spot they
are from a 1/72 F-4. By the way, nice drilling job there,
yeah, you get a pass for Grade 9 shop pal!!!GeekedCool
Dom
Edit tags
    April 2012
Posted by Striker8241 on Friday, November 16, 2012 8:34 AM
Bockscar
did they?Smile
Dom
Thanks, Dom,
Sorry bud, I thought I already replied to this post.
Lol, I'd like to see those outriggers in Hawaiin colors! That would add some interest! Big Smile.
Thanks for the passing grade! Smile Beer
Russ
    April 2012
Posted by Striker8241 on Friday, November 16, 2012 8:53 AM
Hello, Everyone,
Haven't made a lot of progress lately - been pretty busy. I did manage to finish scribing the horizontal sabilizers (see below). I  cut the trim tabs loose and positioned them at a slight angle. I also thinned out the vortex generators.
Cheers,
Russ
    April 2012
Posted by Striker8241 on Friday, November 23, 2012 8:29 PM
Hey All,
Ran into a bit of a problem. I was masking my gunner's canopy when it developed a series of fine cracks. They were so tiny I figured I could take them out with Future. But as I was about to paint it, the thing fell to pieces (see below - I glued it back together for measurements). Heartbreaking Sad.
Anyway, I decided to try and build the canopy from scratch. Not sure how this is going to turn out. So far, I have the frame finished and once it's painted on the inside, I'll start on the clear panels. Wish me luck! Big Smile.
Cheers,
Russ
