1/48 Monogram B-17G Flying Fortress
    December 2003
Posted by hkshooter on Monday, December 6, 2010 8:28 AM
It's always very interesting to me to see the intimate details of aircraft I've admired since I was a kid. Thanks for posting Rob!
Now a question.
When you reworked the tanks you left of the rubber locking plugs. Is there a reason?
    March 2010
Posted by Scorpiomikey on Monday, December 6, 2010 1:59 PM
Wow, you learn something new every day, thanks heaps for that.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    June 2005
Posted by Lancair IV on Monday, December 6, 2010 6:44 PM
hkshooter
Now a question.
Hi hkshooter,
    I'm going to add them back on, and the filler hole.  I didn't like the way the foil formed around the pins.  Next weeks project if I can get home.
Cheers
Rob Byrnes
Novi, Mi
    March 2008
Posted by modelchasm on Wednesday, December 8, 2010 9:43 AM
I love this build, Rob.
Call me crazy ... but I want to almost this exact build on that new 1/32 '17 that's coming out from WingScale... Gonna have to bookmark this thread and clear my calendar for about a year ... or two!
"If you're not scratching, you're not trying!"  -Scott
    June 2005
Posted by Lancair IV on Sunday, December 19, 2010 9:47 AM
Back at it again.  I should have some time between now and the first of the year to get a lot of work done... Ya right!!!&8&8&8
I started installing the circuit board into the wing and because of the openings, the wiring isn't long enough to reach the navigation lights, so Clyde is sending me more wiring.  In the mean time, I installed the motors into the engines this morning.
First I drilled out the front of the engine with a 1mm drill.  I chucked the engine into my lathe and gradually opened up the hole to a #10 drill (.1935) on the back side, being careful not to go too deep.  The motor fits like a glove, and there is no prop wobble at all.
Happy Holidays
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Sunday, December 19, 2010 6:59 PM
Finished up the Wing Tanks today
Cheers
Rob Byrnes
Novi, Mi
    March 2008
Posted by modelchasm on Tuesday, December 21, 2010 3:25 PM
Nice work, Rob. The wing looks sweet!
Did you just get lucky on the "no prop wobble" or how did you do it?
Looking forward to more ....
    June 2005
Posted by Lancair IV on Wednesday, December 22, 2010 8:09 PM
      I started installing the electronics into the right wing tonight.  I started by sanding the landing light LED flat at the end and finishing with 600 grit sand paper.  I drilled a 3mm hole in the landing light pocket and secured the light with micro crystal clear.  The flat of the LED sits just over flush with the wing so I can add a bezel later.  I also painted the LED and the surrounding area black to eliminate light bleed thru.
      The navigation light is handled a little different.  A 2mm hole was drilled in the top and bottom wings skins and a fiber optic rod is installed to reflect the light from the green LED.  I added a "V" notch and will paint the surrounding area black tomorrow.
       I started detailing the engines as well.  Started by spraying metalizer paint to the jugs.
Thanks for looking
Happy Holidays
Rob Byrnes
Novi, Mi
    March 2008
Posted by B-17 Guy on Wednesday, December 22, 2010 10:55 PM
Awesome rob, simply awesome!
    September 2006
Posted by raptordriver on Thursday, December 23, 2010 9:18 AM
Very nice Rob! Those wing seams are going to be an inconvenience to fill huh?
Andrew
    July 2008
Posted by vetteman42 on Friday, December 24, 2010 12:18 AM
Simply AWESOME Rob !! I hope one day to be skilled enough to justify a build like this one.
Randy So many to build.......So little time
    June 2005
Posted by Lancair IV on Friday, December 24, 2010 6:06 PM
Last night I decided to test the packaging space of the wires in the gear well and make sure the motors still worked.  So far, so good.  (knock on wood)
Started adding small details to the engines today and added spars and started the aileron hinging on the left wing.  Wouldn't you know it, I broke my last #76 drill a month ago, and forgot to order new ones.  Now I have to wait.....-=--=--=  I also started detailing the props.
Have a Merry Christmas everyone.  I hope Santa brings you everything you asked for.
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Wednesday, December 29, 2010 5:26 PM
I worked on the engines and props today.  One more engine to go.  You can see the pushrod tubes are screwed up in a few places.  I didn't see these until I posted the pictures, so now they are corrected.
Cheers
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Friday, December 31, 2010 4:10 PM
Today I started adding detail to the main gear wells, applied the decals to the props and tomorrow I will shoot the dull coat.  I decided to make one of the props a new one and the other 3 with black hubs will be weathered.
Happy New Year
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Saturday, January 1, 2011 7:19 PM
Main gears are ready for paint, and the right gear well is ready to be closed.  Tomorrow, I'll try to get the left wing to the same level as the right.
Props are ready for weathering
Cheers
Rob Byrnes
Novi, Mi
    September 2006
Posted by raptordriver on Saturday, January 1, 2011 9:47 PM
Great job!
I am amazed to see how much work it takes to turn a Monogram Monster into a work of art.
Andrew
    June 2005
Posted by Lancair IV on Saturday, January 8, 2011 4:24 PM
Back to work on the 17.  I've been spending all my time in Grand Rapids for work and weekends at home, so today, I finally made it down to the shop.
  The Left wing is just about ready to close up.  Did a test today making sure the lights still function.
Left Nav Light Off
Left Nav Light On
Left Landing Light Off
Left Landing Light On
Main gears were drilled and a guide wide fed through the holes.  These will be the wires that will feed power from the base to the model.
More tomorrow.  I hope.
Cheers
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Saturday, January 22, 2011 5:10 PM
Spent a few hours today on the Fort.
Wings are closed after a final electrical test.
Weathered the Tires and Wheels
Weathered the Props
Cheers
Rob Byrnes
Novi, Mi
    January 2009
Posted by fermis on Saturday, January 22, 2011 10:54 PM
 This project is most spanktaculous!!! I can't wait for it to beat me off the conest table!!!!Stick out tongue
Seriously though, I'm lovin it!!!Yes
BTW, contest in Bay City...Feb 5 (check out ... www.midmichiganmodelmakers.com)
I know this won't be ready by then, but you've got plenty that will raise the bar at the show!!!
Not sure yet if I'll go, but if you go, I'll go!
    February 2007
Posted by Buckeye on Sunday, January 23, 2011 10:41 AM
That is just way over the top! Bow Down
    March 2008
Posted by modelchasm on Tuesday, January 25, 2011 9:30 PM
Yet again, more great stuff, Rob! Nice job .... But if I may, I think that the props need a little more suttle weathering. The marks on there now just lokk like small, stiff, pencil marks. Just thought I'd share what I see....
Thanks again for the inspiration with this awesome build!
    June 2005
Posted by Lancair IV on Wednesday, January 26, 2011 6:35 AM
Thanks.  That's the kind of feedback I need.  Now to figure out how to make them look better.
Toast
modelchasm
Rob Byrnes
Novi, Mi
    January 2007
Posted by Gigatron on Wednesday, January 26, 2011 10:48 AM
Hey Rob,
I'm assuming you're using a prismacolor pencil for the weathering on the prop.  What I do on props, instead of using the point, is use the side of the point.
Hold the point of the pencil parrallell to the leading edge of the prop blade and just kind of drag it towards the trailing edge, in the direction of airflow.  If a prop is going to wear down, the heaviest will be at the leading edge and fades towards the trailing edge.  It will hardly ever be uniform, unless there was some kind of impact damage.
My Corsair is the best picture I have on hand to show what I'm talking about
-Fred
    February 2007
Posted by Buckeye on Wednesday, January 26, 2011 11:34 AM
Great weathering on that Corsair Gigatron.Yes
    January 2007
Posted by Gigatron on Friday, January 28, 2011 8:07 AM
Thanks, Buckeye Cool.  It's my favorite weathering job, of all the ones I've attempted.
-Fred
    October 2004
Posted by jschlechty on Friday, January 28, 2011 10:19 AM
modelchasm
Also, in RL the backs of the blades will have more weathering damage on the back of the blades than the fronts for reasons that I don't understand.  I read that somewhere and a couple of months ago looking at the prop blades on the CAF B-17 Sentimental Journey, I saw that it was actually correct.
    October 2004
Posted by jschlechty on Friday, January 28, 2011 10:33 AM
I'm going to try and post the pics I took of the front and back of the B-17G "Sentimental Journy's" propeller blades.
    March 2010
Posted by Hercmech on Friday, January 28, 2011 10:39 AM
Rob,
Very cool set up your going for. Those are some small motors for the props. Can't wait to see this one done.
13151015
    June 2005
Posted by Lancair IV on Sunday, January 30, 2011 1:55 PM
Thanks for the advice.  How does this look?
Cheers
Rob Byrnes
Novi, Mi
    March 2008
Posted by modelchasm on Monday, January 31, 2011 5:26 PM
Now THAT'S what I'm talking about!!! Very nice job, Rob!!!! Did you end up using the pencil still? ... If so, try taking a strip of paper, roll it up tightly and try feathering the trailing end of the chip marks. I think blending them in just a little more will really hit it off!
Nice job though ....
Thanks for posting that bit about the props, Isch ... never knew that!
