1/48 Monogram B-17G Flying Fortress
    June 2005
Posted by Lancair IV on Monday, November 14, 2011 4:26 PM
vetteman42
Next Rob will figure out a way to have exhaust coming from those stacks Propeller
Amazing work Rob Bow Down
Believe me.  I tired.  Smoke generators are too big to fit in the wing and even if they did, they get too hot.  (like the ones used on model railroads)  and they provide continuous smoke.  I only need a puff at start up.  I started looking at those fancy battery powered cigarettes, but I would have to the computer chips reprogrammed and they are already buried in the wings and fuselage.
Cheers
Rob Byrnes
Novi, Mi
    March 2008
Posted by modelchasm on Tuesday, November 15, 2011 7:40 PM
Rob,
Been out of the loop for a good minute .... and WOW! It's really nice to come bakc to something like this. Thank you for posting this thread up ..... it definately inspires me to finish up my Fort when I get back home.
Lookin' great .... keep up the good work!
"If you're not scratching, you're not trying!"  -Scott
    January 2010
Posted by CrashTestDummy on Wednesday, November 16, 2011 2:04 PM
Lancair IV
It took awhile, and 3 attempts, but I finally have an exhaust ring that looks acceptable.  A little paint and weathering this week, and the engine will be complete.  I'll leave the tube going to the turbo long until I install it onto the airframe.
http://i70.photobucket.com/albums/i107/LancairIV/Monogram%20B-17G%20Flying%20Fortress/111113ExhaustRing002.jpg
Cheers
Just Wow!  I am guessing that's copper and/or brass wire and tubing that's been soldered up and painted, but could you please explain in detail how you created that?  Thank you.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    June 2005
Posted by Lancair IV on Wednesday, November 16, 2011 3:36 PM
CrashTestDummy
 Lancair IV:
Cheers
Gene Beaird,
Pearland, Texas
Hi Gene,
    Ya.  It's all brass soldered and filed, then primed with Tamiya primer.  I made a jig out of wood.  I drilled 9 holes at a 15 degree angle to the main tube.  These 9 holes were spaced every 40 degrees and about 7/8 dia.  The length of the pipes are long right now and will be trimmed to fit the cylinders after I make and install the fixed cowl.  The jig held the cylinder tubes in place, while I soldered the ring to them.  How's that?  Clear as mud!
Speaking of Fix Cowl.  I picked up the mold on the way home tonight.  Should be able to try my vacuum molder tomorrow.
Cheers
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Saturday, November 19, 2011 11:11 AM
Adventures in Vacuum Molding.
       I did the first pull and learned a lot.  The plastic was not close to being hot enough.  On the second pull I let the plastic get warm enough to sag about an inch in the holding fixture.  I placed it on the mold, my wife threw the vacuum switch and bingo bango, we have a fixed cowl.  I did use a heat gun to help get the plastic into the tight areas.  Geeked
Cheers
Rob Byrnes
Novi, Mi
    July 2007
Posted by troublemaker66 on Saturday, November 19, 2011 12:39 PM
Lancair IV
http://i70.photobucket.com/albums/i107/LancairIV/Monogram%20B-17G%20Flying%20Fortress/111119VacumMoldedFixedCowl.jpg
Cheers
Very cool! What kind of plastic did you use...sheet styrene? I`ve been tinkering around with making a vac-mold and have the vac part made. I`m having trouble with the part that holds the plastic...can you post a shot of yours?...need a general idea of what to make so I can start doing some molding! Looks like a frame to me...?  Thanks,  Len
Len Pytlewski
    June 2005
Posted by Lancair IV on Saturday, November 19, 2011 2:06 PM
Hi Len,
   You got it.  Sheet Styrene.  Worked really well.  I made the frame from 1/2" X 1/2" strips.  I secured the plastic to the frame with metal binder clips.
Cheers
Rob Byrnes
Novi, Mi
    July 2007
Posted by troublemaker66 on Saturday, November 19, 2011 2:58 PM
Just to be clear...the frame opening is wide enough to allow the plastic to make contact with the vac-box after heating? ( I`m an electrician...not a carpenter..lol) I think I can see that on your earlier post, just want to be sure. Do you use your stove top for heating?
Len
Len Pytlewski
    June 2005
Posted by Lancair IV on Saturday, November 19, 2011 3:15 PM
Hi Len,
    Yes.  The frame is just wide enough to go over the box.  The legs are just short enough to allow the top for the frame to be about 1/16" below the vacuum face.  I used the oven set at 400 degrees and the it only took about 3 minutes for the plastic to sag.
Cheers
Rob Byrnes
Novi, Mi
    July 2007
Posted by troublemaker66 on Saturday, November 19, 2011 3:38 PM
Lancair IV
Hi Len,
http://i70.photobucket.com/albums/i107/LancairIV/Tools/Frameoverbox.jpg
Cheers
That`s awesome! Very simple design....I was WAAY over thinking mine! Thanks so much for the complete picture. Do you mind if I copy?
Len
Len Pytlewski
    June 2005
Posted by Lancair IV on Saturday, November 19, 2011 4:01 PM
Not at all Len.  Not at all. Yes
Here's the fixed Cowl all trimmed and almost ready for detailing.
Cheers
Rob Byrnes
Novi, Mi
    March 2008
Posted by modelchasm on Sunday, November 20, 2011 7:06 AM
Very nice vac set up, Rob .... I was wanting to do something similar as a side project when I went home on leave. Shouldn't be too hard to build up in a day....
If you dont' mind me asking ... what type of vaccum do you use? Household or shop-vac?
Things are looking great! Can't wait for more updates....
    June 2005
Posted by Lancair IV on Sunday, November 20, 2011 9:04 AM
Thanks.
I used a Rigid, 6 gallon, 2.5 hp shop vac.
Rob Byrnes
Novi, Mi
    July 2007
Posted by troublemaker66 on Sunday, November 20, 2011 11:52 AM
Lancair IV
Thanks.
LOL!  I have the same one...now I know it`ll work perfectly!
Len
Len Pytlewski
    March 2008
Posted by modelchasm on Monday, November 21, 2011 2:20 AM
Great ... thanks, Rob. While I don't have the same one, I know I've got one of similiar capacity.
    January 2010
Posted by CrashTestDummy on Monday, November 21, 2011 1:43 PM
Lancair IV
 CrashTestDummy:
 Lancair IV:
It took awhile, and 3 attempts, but I finally have an exhaust ring that looks acceptable.  A little paint and weathering this week, and the engine will be complete.  I'll leave the tube going to the turbo long until I install it onto the airframehttp://i70.photobucket.com/albums/i107/LancairIV/Monogram%20B-17G%20Flying%20Fortress/111113ExhaustRing002.jpg
Gene Beaird,
Pearland, Texas
Hi Gene,
<SNIP>
<SNIP>
Cheers
That helps a LOT.  Thank you very much.  Your scratch-building work is really nice, and descriptions very helpful.  Thank you.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    June 2005
Posted by Lancair IV on Friday, November 25, 2011 7:16 PM
Well.....  What can I say.  The 3rd attempt at the exhaust ring was not the last.  I just couldn't get it to fit right.  This time, (5th or 6th time) I made it right on the engine.  When everything fit right, I cut it off so I could finish off the fillets and clamps.  Firewall is ready for hoses and wiring.
Thanks for looking.  Happy Thanksgiving.....
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Sunday, November 27, 2011 3:45 PM
Exhaust system is painted.
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Monday, November 28, 2011 8:49 PM
Exhaust Ring and Fixed Cowl mounted to engine
Thanks for looking
Rob Byrnes
Novi, Mi
    January 2009
Posted by fermis on Monday, November 28, 2011 10:29 PM
Daaaaaaamn dude!!!Bow Down
    September 2009
Posted by B17Pilot on Monday, November 28, 2011 11:04 PM
Ditto
    March 2008
Posted by modelchasm on Tuesday, November 29, 2011 7:19 AM
That's great work, Rob .... really great work. I'm sure that it's covered in previous pages, but what engines are you using???
Looking forward to more ....
    June 2005
Posted by Lancair IV on Tuesday, November 29, 2011 4:32 PM
modelchasm
Thanks guys.  I'm using Vector engines.
Rob Byrnes
Novi, Mi
    June 2005
Posted by Lancair IV on Thursday, December 1, 2011 8:20 PM
Plumbing and Motor Mount installed
Cheers
Rob Byrnes
Novi, Mi
    March 2010
Posted by Scorpiomikey on Wednesday, December 7, 2011 8:55 PM
Hey lanc, not sure if you've seen this.
http://home.comcast.net/~szee1a/Al_overcast/Al_overcast.html
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    June 2005
Posted by Lancair IV on Saturday, December 31, 2011 7:37 PM
Happy new Year all.  I can not believe how long it is taking me to do this airplane.  Last year at this time, I was working on the engines and props.  Today, I'm applying rivets to the fuselage.  I do see some light at the end of the tunnel and a goal.  February 4 is the IPMS Mid-Michigan contest.  I'm going to try like hell to get her done for that.  What do ya think Fermis?  You going?
Happy New Year.  Stay safe and have fun tonight.
Rob Byrnes
Novi, Mi
    June 2011
Posted by Ghostriderp-47 on Saturday, December 31, 2011 8:59 PM
Vary cool good thinking with the styrene
    June 2011
Posted by Ghostriderp-47 on Saturday, December 31, 2011 10:57 PM
    June 2011
Posted by Ghostriderp-47 on Saturday, December 31, 2011 11:11 PM
this is the picture out of the B-17G flying fortress walk around bye squadron signal
http://s1184.photobucket.com/albums/z323/P-47DD/?action=view&current=B-17GRevell116.jpg
http://s1184.photobucket.com/albums/z323/P-47DD/?action=view&current=B-17GRevell115.jpg
Yes i did buy 2 of the Revell B-17G only because i know when ever you open up a Revell box you never know what you will find haha
    December 2010
Posted by Heavens Eagle on Sunday, January 1, 2012 12:49 AM
Those rivet decals really are working well for you!  The B-17 was not the smoothest of aircraft, but it was one of the sturdiest.  I saw some test shot photos a number of months ago of a 1/32 scale B-17 model  (nope not out yet by anyone) and it was just like this!  All rivets all over!
Oh and they were actual photos of a kit assembled from the mold test shot!  Can't wait for that one! ($$$ though I bet)
