1/48 B-25 Group Build! All Invited to Join!
    June 2008
Posted by Hans von Hammer on Monday, September 5, 2011 1:04 AM
Might wanna send that in to the Reader Tips before some unsrcrupuled bassige does it after reading the shared info here...   It's happened to me... Someone gets paid for a tip I FREELY gave up...
Posted by hutchdh on Monday, September 5, 2011 6:10 AM
I just may do that...thanks...
Hutch
 On the Bench: 1:48 HobbyBoss Ta152-C; 1:48 & 1:72 Hasegawa F-104G NATO Bavaria
In queue: 1:48 Academy F-4B & a TBD Eric Hartmann bird
Recently completed: 1:32 Trumpeter P-51B
    July 2011
Posted by icer22x on Monday, September 5, 2011 4:51 PM
Here is the inside of mine so far. No laughing!
Had to do the bombs in enamel. Waiting for Tamiya to get their colors shipped back in. I'd appreciate it if someone could post a picture of their fuselage at this step. I'm pretty stuck and don't know what I should add/fix (paint-wise).
Also... how in the world do you deal with seams like this so close to rivet detail? As you can see, I am masking off the detail and going to try and get some putty in there... I hope the tape prevents me from sanding it all away.
Posted by hutchdh on Monday, September 5, 2011 5:02 PM
Icer22x...take a look at page nine of this thread at my solution to the very same problem...it seems to work.  Hans suggested I send my Tip into FSM to may be publishes in a future issue....and I did just that this afternoon.  Hint...I found a way to effectively use acrylic caulk.....let me know what you think.
Hutch
Hutch
    July 2011
Posted by icer22x on Monday, September 5, 2011 5:55 PM
Yeah I saw that Hutch! Where can I get acrylic caulk? Any hardware store? I will go ahead and guess that since it's caulk, when it hardens there is no need for sanding? How do you get it fully flush? Just hope it dries like that?
Posted by hutchdh on Monday, September 5, 2011 5:58 PM
I just applied a healthy amount and wet the ole finger and glided it along the seam.  The shape of your finger gives it the necessary angle.  One of my seams shrunk a little...all I had to do was reapply.
I picked the caulk up at Home Depot.  That is where you can find the one I used.  You shouldn't have to sand.  Stay away from the silicone stuff, though.
Hutch
Hans von Hammer
Done!!!!
Hutch
    July 2007
Posted by troublemaker66 on Monday, September 5, 2011 6:29 PM
[/quote]What exactly kind of caulk did you use and why can`t you use silicone if you shouldn`t need to sand?
Len Pytlewski
Posted by hutchdh on Monday, September 5, 2011 6:48 PM
Go with the acrylic caulk...the silicone usually does not take paint well.....I am talking about the stuff that has a lot of silicone in it as more of a sealer vice caulk.
Hutch
    July 2011
Posted by icer22x on Monday, September 5, 2011 7:11 PM
What do you use to wipe off unneeded excess? Wet paper towel? I just picked some up here - can't wait to try it. I HATE puttys with a passion. HATE them.
    July 2007
Posted by troublemaker66 on Monday, September 5, 2011 7:14 PM
hutchdh
Cool...that`s what I have..bought a case of DAP "painter`s all purpose acrylic latex caulk"...purchased at the Home Despot...Big Smile I don`t know how many times I thought about using caulk for model seams and just never tried it...thanks for taking that step Hutch..lol.
Len Pytlewski
    July 2007
Posted by troublemaker66 on Monday, September 5, 2011 7:25 PM
icer22x
....Yep!
Len Pytlewski
Posted by hutchdh on Monday, September 5, 2011 7:27 PM
icer22x
Anything wet will wipe it up very easy.......it is very forgiving....a damp paper towel works well...so does a Q-tip...make sure the applicator is damp vice dripping wet.
Good luck....
Hutch
    February 2011
Posted by Reasoned on Monday, September 5, 2011 8:53 PM
First, DO NOT use silicone for it will not take paint.  Secondly, as Hutch said use a damp finger (smallest is best) and apply in joint, remove as much excess as you can, then let it set a few minutes (don't let it dry out) and gently go over with damp paper towel to remove any additional excess.  You will want to do this because this stuff does not do sanding well, it tends to ball up.
Oh, and since this has been the build from hell, I've nixed the Alclad NMF for left over Model Masters Metalizer from a rattle can. Why? because there is no sense in waisting the expensive stuff on this.  I hope to begin shooting after signing off.  And if it goes as bad, I will plan on attaching one of my son's Estes "E" rocket engins to the Mitchel and send it off in style! Angel
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    February 2011
Posted by Reasoned on Monday, September 5, 2011 10:59 PM
Okay, shot the MM NMF, now high as a kite Propeller.  Boy does that stuff show sins.  Will attempt to clean things up tomorrow and post some pics, over and out Sleep
Posted by VanceCrozier on Tuesday, September 6, 2011 7:44 AM
troublemaker66
 hutchdh:
The silicone stuff would be a bugger to deal with too at scale-model-size, along with not taking paint it dries quicker than the acrylic & doesn't clean up as nice.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    June 2008
Posted by Hans von Hammer on Tuesday, September 6, 2011 8:41 AM
hutchdh
 Hans von Hammer:
Done!!!!
Atta boy...
Posted by Texgunner on Tuesday, September 6, 2011 8:43 AM
My old painter Uncle Elzy used to say, "ain't nothing new boy!" Big Smile
/forums/p/20511/200391.aspx#200391
"All you mugs need to get busy building, and post pics!"
    February 2011
Posted by Reasoned on Tuesday, September 6, 2011 9:21 AM
Well Tex, you were ahead of your time and spot on, thanks for the reference. Beer
    June 2008
Posted by Hans von Hammer on Tuesday, September 6, 2011 9:52 AM
Probably means I could dig up that tip in something like a 1979 issue of Military Modeler too, lol...
Posted by Texgunner on Tuesday, September 6, 2011 9:57 AM
Hans von Hammer
Yeah no doubt.  Prolly some other old painter figured that one out a long time ago.  Prolly closed up some gaps in an old Tiger...Wink
Posted by hutchdh on Tuesday, September 6, 2011 10:03 AM
Aw shucks...another example of me having no original ideas....so says my wife...Stick out tongue
Look at it as a refresher.
Hutch
Posted by Texgunner on Tuesday, September 6, 2011 10:16 AM
hutchdh
That's the ticket!  At my age anyway, refreshers are always good.  Remind me what? lol!
Gary
    February 2011
Posted by Reasoned on Tuesday, September 6, 2011 2:44 PM
Did a little B-25 research and came across this You Tube Vid, the props are FREAKING ME OUT! Indifferent
http://www.youtube.com/watch?v=w-Dm-fjUm6U
Posted by VanceCrozier on Tuesday, September 6, 2011 3:06 PM
Wow, that's funny. Just the way the "frames per second" on the camera syncs up with the propeller speed. It justifies us showing a prop-plane in-flight without prop-blur though!!
    July 2007
Posted by troublemaker66 on Tuesday, September 6, 2011 4:06 PM
Reasoned
That`s "Panchito"...seen that one up close a couple times. I have some vids with props doing the same thing..something with the speed of  the camera or somethin`...
Len Pytlewski
    December 2008
Posted by psstoff995's lbro on Tuesday, September 6, 2011 8:39 PM
Really nice looking build there! I've always wanted to do a natural metal build.
-Will young modeler Test fit master
    July 2011
Posted by icer22x on Tuesday, September 6, 2011 11:41 PM
I was lucky enough to see a B-25 in flight at Little Rock AFB last year. Amazing planes. They also did a re-enactment of Pearl Harbor with REAL Zeros (the actual planes used in Tora! Tora! Tora!). I have to say - for a 25 year-old USAF applicant - it was pretty powerful to sit there and watch a few planes do that - even knowing I was completely safe.
ANYWAY - on to why I am posting tonight. I don't know if you guys have read into the B-25J, but I found some awesome finished kits and good info here:
http://modelingmadness.com/reviews/allies/us/usaaf/48b25.htm
VERY interesting. The B-25s talked about in this article were flown to Corsica after the eruption of Mt. Vesuvius and were RE-PAINTED over their aluminum bodies with OD (or the Euro equivalent) to camouflage them from bombing raids.
Now, if you look on the front of the box for our kits, you can see the bottom half of the Mitchell is a shade of what should be aluminum. I wonder of it is making reference to these Corsica Mitchells... even thought it's a J.
I'm curious if anyone is going to try and go for this paint scheme. It might look weird to have an OD top with a aluminum bottom... but that is technically what happened to that squadron!
What do you guys use in your airbrushes to get that aluminum fuselage look? Lacquer?
Also found this for you guys that are going ALL OUT and adding rivets and panel lines:
http://www.primeportal.net/hangar/mark_hayward/b-25j_mitchell/index.php?Page=1
    July 2007
Posted by troublemaker66 on Wednesday, September 7, 2011 4:58 AM
[quote user="icer22x"]
Unfortunately, those Zeros are not real, they are T-6 trainers made to look like the real deal. The Vals they used in the movie were B-18`s I think....saw one at the Milleville airshow.
Len Pytlewski
    June 2008
Posted by Hans von Hammer on Wednesday, September 7, 2011 8:49 AM
BT-13s..
The CAF Tora Squadron operates the Vals, Kates, and Zekes... There's also the one authentic Zeke airframe we have as well, although it's been re-engined with a P&W mill..
