Messerschmitt BF109 GB 2012
    February 2011
Posted by Reasoned on Wednesday, June 20, 2012 8:35 AM
Hans von Hammer
Well.. I'm out..
The "Von Hammer" Bf109 is junk.. I got a massive dose of silicone-contamination with the paint, resulting in thousands of little "Fish-eyes" on the finish... I don't know what happened, or how (I washed the model to remove any mold-release), but the thing isn't worth saving... In order to remove th piant, I'd have to sand all the surface- details off, since niether brake fluid or  Simple Green will remove it..
*sigh*
I might build the Monogram Bf109E in order to finish the GB, but at this point, I'm too disapointed to care..
Rats Hans!
Ever tried oven cleaner?
check this link out about halfway down:
/forums/t/142716.aspx?PageIndex=17
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    January 2003
Posted by p38jl on Wednesday, June 20, 2012 10:45 AM
Hans.. got any Laquer thinner? try some on a qtip or rag.. wipe it on.. then rub some.. be carefull.. to much can soften the plastic..it might loosen it up enough to wipe off.. then sand it smooth after an not loose the detail..
[Photobucket]
    December 2011
Posted by Luft Modeler on Wednesday, June 20, 2012 10:48 AM
The sucks Hans, hate when that happens. Well the groupe build goes til Jan so if you change your mind.
    November 2011
Posted by 70gtvert on Wednesday, June 20, 2012 10:54 AM
I use Easy Off oven cleaner, the formula with lye in it (there are 2 formulas, only one with lye) It takes off acrylic, enamel and lacquer and does not harm the plastic. Put it in a tub, spray it down and use plastic wrap placed around it to prevent early dry out. After about an hour and a half, take it under a water faucet and with water running on it scrub the model with an old toothbrush. May take 3 tries or so but it does work.
    June 2008
Posted by Hans von Hammer on Wednesday, June 20, 2012 11:53 AM
Thanks for the suggestions.. I might try them later, but right now I'm just too bummed-out about it to care... Guess I need a "grief period", lol..
Meanwhile, I'll tinker with the MonoSchmitt.....
    June 2008
Posted by Hans von Hammer on Wednesday, June 20, 2012 12:33 PM
For What It's Worth:
*Sigh*....
 I have an idea to save it if it comes to that though.. A diorama of the bird gettng re-painted in the field with Von Hammer's Red...  So it would get painted in factory camouflage first, then partially re-painted with the red..  I can build a couple figures painting it, while Von Hammer, standing next to his Kubelwagen, looks on.. Or even better, pose him personally painting over the Hakenkreuze..
    July 2011
Posted by handiabled on Wednesday, June 20, 2012 12:39 PM
        That blows bigtime,,, I've had the same thing happen from a rattle can once,, sounds like some cool suggestions how to fix ,,still,,,  that sucks  Censored
    January 2003
Posted by p38jl on Wednesday, June 20, 2012 12:55 PM
Hans... I don't think you have "fish eye".. I think you have "solvent popping" , this occurs when the first coat is not dry enough, and the 2nd coat goes on to quick. The first coat has not had time to let all the solvent evaporate out of the paint, then the 2nd coat traps the solvent, and then it pops up thru the top coat. You can get this even if you put only "1" coat on.. as a few heavy passes can create 2 coats..
Was this color a gloss color ? was it humid that day? or muggy? rainy ? .etc..?,,, this can aggravate it..
The reason I say, this is that your pops, are very consistant over all the model.. not in a few locations..
[Photobucket]
Posted by VanceCrozier on Wednesday, June 20, 2012 1:08 PM
p38jl
I'm gonna Ditto P38 here, looks like a reaction more than fisheye. (I avoid this problem by building everything slowwwwwlyy Snail) May have to sand her down & consider that a base-coat. Loving the red on that machine btw.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by VanceCrozier on Wednesday, June 20, 2012 1:25 PM
Rigidrider
http://i1250.photobucket.com/albums/hh531/Devil-Dog7275/Bf-109-E%20Winter%20Camo/2009_0915ME109-E0016.jpg
Nice!!!
Man, I'm gonna have to go back a dozen pages to get caught up! At this point I'm planning on hitting one of my 1/72 109s this summer, maybe try it as a 2-week blitz - yes, that is "blitz speed" in my world. Embarrassed
    January 2003
Posted by p38jl on Wednesday, June 20, 2012 1:40 PM
Hans.. put it in the sun.. or a warm dry area to let the rest of the solvent pop/evaporate..
[Photobucket]
    June 2008
Posted by Hans von Hammer on Wednesday, June 20, 2012 2:04 PM
p38jl
Yeah, it was gloss.. Krylon was the brand..
Regarding the "solvent popping", there wasn't a second coat.. That was the first coat, there was't a second one..... Hence my suspicion of "fish-eye" from silicone contamination...  Weather wasn't a factor, my war room is A/C'd so it's pretty comfortable, with low humidity..   You could be right though..
At any rate, I'm walking away from this one for now.. Oh, I'm sure I'll finish it before the deadline, hopefully,but it'll be a couple weeks before I pick it up again...  Otherwise, it'll get "Hammered"...
    December 2011
Posted by Luft Modeler on Wednesday, June 20, 2012 2:08 PM
Love the red color, I assume it is a gloss paint which I hate painting a gloss color because of stuff like that. But it doesnt look too bad to save. Sometimes walking away and then coming back to it after the anger is gone helps. Looks like von Hammer is going to have a "nice" talk with the makers of the paint and send them to the Russian front for making a poor paint. Lol
    June 2008
Posted by Hans von Hammer on Wednesday, June 20, 2012 2:22 PM
LOL.. Actually, the Russian Front is where Major Hans Von Hammer fought during the "Bf109 Phase".. So he be able to get his hands on 'em easily, lol..
 He was promoted to Oberst (Colonel) and then went back West and formed a Riechsverteidigung Geschwader in Me262s...   So I have a red Me262 in the hangar as well..
Wish he'd flown a Fw190...
Posted by VanceCrozier on Wednesday, June 20, 2012 2:30 PM
Hans von Hammer
Hey, you're already painting a -109 in red, why not a -190??
Posted by Anonymous on Wednesday, June 20, 2012 2:31 PM
When I was the German Naval Attache' to Japan in the late '30's I was given my own fighter in "Cherry Blossom Red" while participating on sea-manuevers on the Zuiho...
    January 2003
Posted by p38jl on Wednesday, June 20, 2012 2:35 PM
Hans,, even tho you didn't spray a second coat,, consequtive passes to get coverage, might have resulted in the same effect..
hard to say for sure,, but the dots are all over,and fairly even,  so unless its a bad can of paint.. or somehow you got silicone or cheeseburger grease all over it... lol.. I'm still going with the solvent pop... Whistling
[Photobucket]
    June 2008
Posted by Hans von Hammer on Wednesday, June 20, 2012 2:40 PM
That's what I said.. Silicone Contamination.. But your theory is just as good too..
    September 2005
Posted by Sprue-ce Goose on Wednesday, June 20, 2012 4:25 PM
Manstein's revenge
Oh, no!
Another cigarette lighter?!
    September 2005
Posted by Sprue-ce Goose on Wednesday, June 20, 2012 4:28 PM
Hans von Hammer
Sorry to see the damaged paint finish.
Good color, too.
Hope you are able to fix it for the build.
OTOH, you still have it for spare parts
    June 2008
Posted by Hans von Hammer on Wednesday, June 20, 2012 4:38 PM
Lol..  I like to get photos of them finished before I start to make 'em "Hangar Queens", lol..
    April 2006
Posted by jgeratic on Wednesday, June 20, 2012 6:37 PM
Hans - tough break on that one, but do hope you will get back to it later.
So I've started on a 109, but the one I was slated for has been changed to Hasegawa's 1/48 scale 109F-4.  After building a Malta Spitfire flown by  Beurling, I want to do it's dogfight double.  On May 8th 1942, he was credited for shooting down one, no information known other than it was a 109.  During that time JG53 had both it's staff and II gruppen still stationed in Sicily, so markings will reflect this.
I have a spare pilot cast in metal from Airwaves, but does not fit.  So I cannibalized the one from the Airfix kit.  It has been a while since building one of these, and have since learned that there should be a seam running along the length of the fuselage, both top and bottom.  There is still debate though at which scale this becomes visible.
What I've tried here is to clean up the fuselage edges before cementing them.  A sanding stick was used to apply about a 60 degree bevel to the outer edge of the fuselage where the panel line should be.  Pictured is just the halves dry fitted.
regards,
Jack
    September 2009
Posted by satch_ip on Wednesday, June 20, 2012 7:17 PM
Hans von Hammer
Silicone contamination?  What, are you modeling in a Strip Club now?
Big Smile
    September 2005
Posted by Sprue-ce Goose on Wednesday, June 20, 2012 8:56 PM
satch_ip
 Hans von Hammer:
Big Smile
Big SmileBeerYes
    December 2011
Posted by Luft Modeler on Friday, June 22, 2012 3:57 AM
Manstein's revenge
Is that you on the far left standing up? Or were you the one taking the picture?
Posted by VanceCrozier on Friday, June 22, 2012 8:21 AM
pzl66
 Manstein's revenge:
When I was the German Naval Attache' to Japan in the late '30's I was given my own fighter in "Cherry Blossom Red" while participating on http://i1016.photobucket.com/albums/af282/chadhill/JapaneseBF109.jpgsea-manuevers on the Zuiho...
Squatting, second from the left. The plastic surgery was done in Buenos Aires....
    June 2008
Posted by Hans von Hammer on Friday, June 22, 2012 9:25 AM
pzl66
 Manstein's revenge:
Trivia: What was the Allied code-name for the Jap Bf109 ?
Ten-Thousand Hammer-Marks to the person who names it within 24 hours..
    January 2003
Posted by p38jl on Friday, June 22, 2012 9:29 AM
are Hammer-marks good for trade in Buenos Aries ??Whistling
[Photobucket]
    January 2003
Posted by p38jl on Friday, June 22, 2012 9:33 AM
Hans von Hammer
 pzl66:
 Manstein's revenge:
  MIKE
[Photobucket]
    July 2011
Posted by handiabled on Friday, June 22, 2012 9:36 AM
Hans von Hammer
 pzl66:
 Manstein's revenge:
                            Wasn't it a "Mike" ?
