BIG Intruder GROUPIE GROUPBUILD...
Posted by VanceCrozier on Tuesday, June 5, 2012 11:27 AM
The picture you're showing with the red moon looks like red-to-lighter red. I wonder if that one was airbrushed instead of decalled? the colours don't seem to transition as cleanly. I think I'd stick with the red-over-yellow decals that are on the sheet. I think you'll get the right look once you lay them over each other.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by Anonymous on Wednesday, June 6, 2012 9:21 AM
VanceCrozier
I don't have that sheet...I think I'll cut a template and airbrush it...
    June 2008
Posted by Hans von Hammer on Wednesday, June 6, 2012 10:19 AM
Echo139er
 VanceCrozier:
 Scorpiomikey:
 Hans von Hammer:
Got this patch from an A-6 driver offa the Ranger that had been refueling F-14s for a cruise or two from KA-6s.. Thought it might give ya a chuckle..
http://img.photobucket.com/albums/v233/HansvonHammer/Drawings/AnytineBabyKA-6.jpg
Lol, dodgy.
A patch like this could get more pilots to sign on for air-to-air assignments...
A dio idea maybe....
A dio of the patch?
    June 2008
Posted by Hans von Hammer on Wednesday, June 6, 2012 10:21 AM
Actually, the patch is pretty rare, ever since the advent of female Indifferent Tomcat pilots in the Navy...  *Sigh*...
Posted by Anonymous on Wednesday, June 6, 2012 1:55 PM
    June 2008
Posted by Hans von Hammer on Thursday, June 7, 2012 12:38 PM
THIS would make a diorama..
http://www.youtube.com/watch?v=Z6DQEPIWLFc
Posted by Kolja94 on Thursday, June 7, 2012 1:49 PM
Thanks to Manstein's revenge for pointing this build out to me! I'm working on an Italeri 1/72 Intruder that I started in late April!
A couple points that were brought up earlier in the thread: The centennial scheme was a Prowler (not sure if the distinction matters to anyone or not, though they were technically separate airframes), all the Intruders having long since been put to bed. Sadly, that Prowler itself was sent into retirement a few months ago.  The seat arrangement, like that in the front of the Prowler, was in fact (to my understanding) for pilot visibility.  The seats' first 6 feet of travel is actually via catapult - no explosives initially.  When the rocket motors ignite the seat is clear of the airframe; if you've ever seen a video clip of an Intruder or Prowler ejection, you see that thanks to the delay built into the sequence the seats are clear of each other before the rocket motors ignite.
For the speedbrakes, that change was actually relatively early on in the Intruder's service life.  They found that, especially at approach angles-of-attack, the position of the speedbrakes adversely affected the airflow over the elevators - a less than desirable thing behind the boat.  So the fuselage ones were bolted shut and the wingtip ones installed.
Anyway, I'll start a thread with some of the in progress pictures so far!
Karl
Posted by Anonymous on Thursday, June 7, 2012 1:55 PM
This kit is so cherry that it is too bad there aren't more AM decals out there in 72nd for the A-6...
Anyone who knows of a good source or has any "spares" please chime in...
    January 2006
Posted by DiscoStu on Thursday, June 7, 2012 6:15 PM
Manstein's revenge
This is the set that I have that I don't need:
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
Posted by Kolja94 on Friday, June 8, 2012 1:50 AM
As promised, here's some pictures of my project so far.  My first one in almost 4 years thanks to a move and three deployments!
Karl
Posted by Anonymous on Friday, June 8, 2012 9:40 AM
DiscoStu
 Manstein's revenge:
http://i110.photobucket.com/albums/n85/Stugeorge/003-5.jpg
I have that sheet and like the scheme of the a/c at the bottom, but that moon, according to my refs, should be red with a yellow tip...
Thanks for the offer though...Yes
Posted by Anonymous on Friday, June 8, 2012 9:41 AM
Kolja94
http://i6.photobucket.com/albums/y241/Kolja94/Italeri%20A6E%20Intruder/photo-2.jpg
http://i6.photobucket.com/albums/y241/Kolja94/Italeri%20A6E%20Intruder/photo-5.jpg
http://i6.photobucket.com/albums/y241/Kolja94/Italeri%20A6E%20Intruder/photo-4.jpg
http://i6.photobucket.com/albums/y241/Kolja94/Italeri%20A6E%20Intruder/photo-3-2.jpg
http://i6.photobucket.com/albums/y241/Kolja94/Italeri%20A6E%20Intruder/photo-2-7.jpg
Nice!  How's the overall fit???
Posted by VanceCrozier on Friday, June 8, 2012 9:54 AM
fuselage sides all sealed up... Kolja94 is taking the lead!
Posted by Kolja94 on Friday, June 8, 2012 3:28 PM
Generally, the fit is fairly decent.  The keel section fits better than other Intruder/Prowler models I've done in either 1/48 or 1/72.  The main joint down the center of the spine is a nice fit, the only reason I put any putty on it at all is there's no actual panel line there so I wanted to try to make it truly invisible.
The only area that stands out as problematic was the wing roots; I feel as though the recesses in the fuselage may have been slightly oversized.  I filled them with some styrene strip, melted by cement, to take up most of the volume, then just added a little putty to clean up.
Karl
    January 2009
Posted by fermis on Sunday, June 10, 2012 12:22 AM
I finally managed to get started today!
Started with getting rid of the molded on detail, and rebuilding the rear deck. (using a bit of "artistic license" and refering the Revellograms 1/48 pit)
I jacked up the PE ejection handles for the True Details seats, so I just used fine wire. I also shortened the control stick...that thing woulda been in the pilots face!
Posted by Anonymous on Sunday, June 10, 2012 10:59 AM
fermis
http://i661.photobucket.com/albums/uu340/fermisb/2012%20models/others/IMAG0872.jpg?t=1339304130
http://i661.photobucket.com/albums/uu340/fermisb/2012%20models/others/IMAG0873.jpg?t=1339304142
WOW...that PIT looks great!Yes
    October 2009
Posted by Gregbbear on Sunday, June 10, 2012 7:04 PM
What a great start Fermis!  Very nice indeed.
I'm still waiting on my "Iron Hand" parts from Roll Models.  I also ordered Squadron's "Wild Weasel, the SAM Suppression Story", which is supposed to have some good detail drawings on the A-6B.  I'm looking forward to getting started on this one.
Cheers,
Greg
- yat yas!
Posted by Kolja94 on Monday, June 11, 2012 12:01 AM
Major painting done as of last night:
(Soft edge on the demarcation, even though it doesn't show well here).
Hopefully will get to spray some Future tonight...
Karl
Posted by Anonymous on Monday, June 11, 2012 6:55 AM
Kolja94
http://i6.photobucket.com/albums/y241/Kolja94/Italeri%20A6E%20Intruder/photo-2-8.jpg
Looking good!  What scheme you going with???
Posted by VanceCrozier on Monday, June 11, 2012 7:42 AM
fermis
You just couldn't leave it alone could ya!!! Bang Head Whistling
The deck additions look really good fermis, busies it up quite a bit. I'm seriously considering adding some goodies back there now, it is a large spot to leave blank...
Posted by Kolja94 on Tuesday, June 12, 2012 12:54 AM
Manstein's revenge: I think I'll go with VA-85.  I got those markings on a Hi-Decal sheet I originally got for another project, but that one will be an extensive rehab of a not-so-great kit.  I really like the markings, and I'm pretty happy how this one's going so far, and thinking odds are good it will turn out better than the Revell rehab I'll do down the road.  I'll save the Italieri kit markings for VMA*AW)-332.
Karl
    January 2006
Posted by DiscoStu on Tuesday, June 12, 2012 9:00 AM
Got back into the Kinetic Intruder over the past couple of nights.  Pit is painted and right now the coat of Future is drying.  I had thought of using some resin seats from the spares box but found they fit too proud in the pit.  So kit seats it is.  The seats built up nice but had a nasty V shaped seam running down the headrest.  I used some sheet plastic to level that out.  I assembled some of the major sub-assemblies: Wings and stabs and started test fitting.  So far the fit is less than promising.  The wing join is ugly.and getting a flush fit on the lower fuselage means about a 2mm step on the upper portion of the wing.  So I'll be sanding, sanding and sanding.  Lots of injector pin marks on the stabs.  Had to sand the lower half almost paper thin to get it to fit flush.  I'll post some pics this evening.
    March 2010
Posted by Hercmech on Tuesday, June 12, 2012 7:04 PM
VanceCrozier
 fermis:
Agreed...note to self...don't join group builds with Fermis...unless I want to feel even more inadaquate.
13151015
    January 2006
Posted by DiscoStu on Tuesday, June 12, 2012 7:09 PM
Here are the pics from my Kinetic build so far.
Kit seats with the headrest fixed
The nasty wing join:
Posted by Anonymous on Wednesday, June 13, 2012 12:49 PM
DiscoStu
http://i110.photobucket.com/albums/n85/Stugeorge/001-4.jpg
http://i110.photobucket.com/albums/n85/Stugeorge/005-4.jpg
http://i110.photobucket.com/albums/n85/Stugeorge/006-5.jpg
Wow---and I thought those Kinetic kits were supposed to be state-of-the-art???  Still doing a great job despite the issues!!!
Posted by VanceCrozier on Wednesday, June 13, 2012 1:36 PM
Manstein's revenge
"Communist State" perhaps...
Posted by Anonymous on Wednesday, June 13, 2012 2:04 PM
Image Detail
Posted by Kolja94 on Friday, June 15, 2012 12:05 AM
Started decals last night - the good news is, as they dried, that 'off color' looking carrier film on the tail went away.
Karl
Posted by Anonymous on Friday, June 15, 2012 6:52 AM
Kolja94
http://i6.photobucket.com/albums/y241/Kolja94/Italeri%20A6E%20Intruder/photo-2-9.jpg
Sweet...looks like you went with one of the kit schemes...very nicely done...
Posted by VanceCrozier on Friday, June 15, 2012 7:00 AM
Nice progress! I expect to have some bench time this weekend, I've had a good run of weather up here for ball this past week, and recuperating a cut-up hand the week before that... Black Eye
