I sat down and fired down the top camo last night. I read some scuttlebutt about these Russian E models in 1942 that may have been in the earlier Battle of Britain camo scheme. It's not clear when they changed at the factory to the newer RLM 74/75 over 76 and I'm sure many were in that scheme. Eduard shows this subject in 74/75/76 color scheme. I figured they did their research and I followed suit. I started with AK Real Colors 75. They did a nice job on this color. I also mottled the side fuselage.
Next I added some XF-2 White and mottled it up a bit for fading. Then I went back with straight 75, concentrating on the panel lines. I'm really starting to like this technque, especially in conjunction with the later oil wash.
I taped off the splinter scheme per Eduard's instruction and did the same technique for the RLM 74, except I added XF-57 Buff to fade it a bit. I may have mentioned that their 74 seems a bit too green to my eye. It's also entirely possible it's perfect and I have no idea what I'm talking about. Either way I can live with it. Off came the Montex and they worked perfectly.
I also painted the prop hubs as I wanted to see how they looked in place. I used the white flexible Tamiya tape to mask the yellow and it worked great....
I grunged up the underside a bit with a postshade.
One of the big weaknesses of this kit are the exhaust stubs, they're not hollowed out and there was no way I was manually doing it on all of those. Furthermore, they are too prominent on this plane skimp here, so I replaced them with Quickboost. They are designed for this kit, but for some reason I had a heck of a time trimming them enough to fit in there. I eventually got them to fit. As you can see they are worth it. This is the port side outboard exhaust.
I wanted to make them look realistic, so I spent quite amount of time pouring over photos (and some well done models too) to get an idea how they looked and how the exhaust stain pattern went. I didn't want to overdo it either. First I sprayed them XF-1 flat black then followed up with XF-64 Red Brown. I made sure to avoid the holes so they remained black. I superglued those turkeys in there.
Now for the staining. I took a deep breath then sprayed a very heavily diluted XF-69 NATO Black/XF-64 Red Brown mix, slowly building it up. I then sprayed the tips diluted XF-19 Sky Grey/XF-57 Buff mix and swept that back to simulate heat staining. I repeated these until I listened to that little inner voice telling me to stop. Before I knew it an hour had passed....
The undersides were more challenging, but I did the same technique.
Time for a clear coat then that dreaded wasp decal......
