Endgame 1946 GB - 1/1/09-12/31/09
    May 2009
Posted by -Neu- on Sunday, August 30, 2009 7:17 PM
Hey people...
Would it be a problem if I made a very late entry into this build? I've got a Academy 1/72 Tempest V that I'd like to do in an all metal scheme (but using the decals that came with the kit.) It would be a quick build... hopefully two weeks or so. Any problems?
Weekend Madness GB tag
    January 2009
Posted by eptingmike on Sunday, August 30, 2009 8:43 PM
Well, here it is, my 1/48 Czech Model ME-309.  I have to say that overall I am quite happy with the results, all things considered as I think of myself as a beginner in many ways having only recently returned to modeling(less than a year ago I think).  I would have to say that the kit itself was a nice challenge to the current level of my abilities...a lot of cursing to be sure!  Overlall I wish that I had put a little more time and TLC into the build but, that said, I am amazed at what I was able to do in what amounted to 10-15 hours total time.  Heck, it may not have even been that much!  Now for some of those juicy details we all love to read about! Firstly, I put WAY too little weight in the nose so she is a tail-sitter.  I nearly scrapped the project in favor of one of the two ME109s in my stash but pressed on(I am easily discouraged at times!) I managed to get around the weight issue by putting a pin in the nose gear which will eventually be glued into the wood base I have for it.  There are many other little things I wish I had done or should have done.  There are a few seams and a tiny gap here and there which I hid from you in the photo!  I also made the mistake of not putting down a gloss coat before the decals(I was in a big hurry trying to get it done by the ending date.  Decalling began Sat. morning and put two coats of Dull on earlier today!).  One of the upper wing crosses peeled up a bit after I laid on some gloss and then chipped off when I tried to lay it flat.  I snuck a little thinned white glue under the bit that was still slightly raised up and then did a little touch up with white.  The crosses and swastika are from this kit and a CM BV-70, the yellow 20 is from a Hasegawa ME-109, and the wolf is from a Hobby Boss Sherman!  They look WAY, WAAAAAY better in the photo than in real life.  I believe that I have what is called 'silvering' with them but it didn't translate over in the photo which is great.  The paint scheme is Testors MM Acryl Dunkelgrun RLM 82 and Braunviolett RLM 81 on top and a mix of Apple Barrel Pewter Grey and Delta CeramcoatBlue Jay.  The MM stuff was a bit of a pain at first but I started adding an acrylic extender to it and didn't have the drying on the needle problems I had at first.  Also kept a Windex soaked swab near at hand.  I used a Badger Anthem 155,which I really enjoy(I also use a Badger 250[cheap as dirt spray gun]for Future but I think I may get a slightly better brush than that in order to have a bit more control, but I digress), first preshading with Delta Ceramcoat Charcoal.  The only post shading/washy kind of stuff is on the landing gear and in the wells.  I have had very poor luck with that sort of stuff so I figured I would hold off.  Regardless, here she is:
http://farm3.static.flickr.com/2629/3872186683_b2fdfae1bb_b.jpg
And a close up of the nose art:
http://farm3.static.flickr.com/2462/3872970576_b9afd55103_o.jpg
Enjoy and thanks to  WarHammer25 for hosting this party!
Horten_IX_Go-229
    April 2005
Posted by carsanab on Sunday, August 30, 2009 10:15 PM
Mike:
That 309 looks very very nice...I really like the subtleness of the camo and panel shading.
I give the build two..Thumbs Up [tup]
Carlos
 Photobucket
    January 2009
Posted by eptingmike on Sunday, August 30, 2009 10:29 PM
Carlos
Thanks for the kind words!
Horten_IX_Go-229
Posted by Swanny on Monday, August 31, 2009 9:32 AM
Very nice looking build and done so quickly.
    May 2009
Posted by -Neu- on Wednesday, September 2, 2009 5:09 PM
Hey Mike
That was quite the nice build, especially for a Czech kit. I always liked the 309... it reminds me of the Spits, Mustangs and Jugs progressive development over the war. Too bad it was ultimately a failure.
As for my Tempest V, I've gotten some work done on it. Most of the fuselage interior is completed; I added some wires and belts to make it look "busy," and gave the radiator a nice coat of alcad before I glue both halves together. I think I'll have most of the major construction done by this evening.
    May 2009
Posted by -Neu- on Thursday, September 3, 2009 2:56 PM
And final assembly of the main parts... hopefully I can get to some painting this weekend.
    January 2009
Posted by eptingmike on Sunday, September 6, 2009 11:30 AM
Thank you!
The 309 on your site is very nice as well!
Horten_IX_Go-229
    February 2006
Posted by DantheMan85 on Wednesday, September 9, 2009 11:14 AM
Nice work everyone!
Well my Ju-88 and He-111 are close to glueing the to fuse's together, I'll post pictures later tonight to Thursday.
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
Posted by Bish on Wednesday, September 9, 2009 2:55 PM
Am i right in thinking the build time for this GB is over or has it been extended and i missed it. Just i notice people still building.
    April 2005
Posted by carsanab on Friday, September 11, 2009 2:10 AM
Let me check with the CEO...
CS
 Photobucket
    May 2009
Posted by -Neu- on Tuesday, September 15, 2009 3:17 PM
Well I'm basically done my Tempest V, It needs a bit of shading on the engine exhaust but that should be it. It was an okay build, but I made few mistakes that for some reason seem to all be on the left side of the aircraft; the side I'm not going to show you :p
    February 2006
Posted by DantheMan85 on Tuesday, September 15, 2009 3:54 PM
Nice looking Tempest V Neu, did you dip the canopy in furture? its to shinny.
Up Coming: ?
    May 2009
Posted by -Neu- on Tuesday, September 15, 2009 4:02 PM
I didn't but I will in awhile. When I did the canopy framing with alclad I didn't notice there was a bit of blue paint in the airbrush which gave it a bit of a blue tinge to it (its more visible on the left side of the aircraft.) So I'm waiting for the opportunity when I need to alclad something else to fix that, then I'll dip it into future.
    February 2006
Posted by DantheMan85 on Monday, September 21, 2009 4:08 PM
My He-111, and Ju-88.
Up Coming: ?
Posted by Bish on Saturday, September 26, 2009 3:17 AM
I know i am to late for the deadline, but thought i would post the finished pics here first anyway. The kit was painted useing xtrolor enamels and i used a pastel wash on the trolly and a lighter one on the underside of the 162. This is my first aircraft kit in about 7 years and i am quite pleased with it.
Sorry i couldn't make the deadline, to much over commitment on GB on my part.
    September 2008
Posted by WarHammer25 on Monday, September 28, 2009 5:25 PM
Everyone, I am very sorry for my longterm absence from this GB and this forum. My summer was very crazy and my first semester of college started at the beginning of August so I have had very little time to check the forums and do any real modeling. I would pop on every now and then just to check progress but I didn't post anything. So, as it seems some aren't finished with their builds (myself included), I have extended the end date to December 31. Now, lets see what has happened since I last posted:
jcheung5150: Nice work on the E-25. I am glad to see that some armor might actually get done other than Russ's M-26 and mine. I see that post was from June so I hope you are still out there and will finish it.
C. Alan: Very nice Pfeil! Those Tamiya kits are so much better than the 1/72 Dragon I built. I really like the brown and dark green splinter camo and the subtle weathering. Nice work. Thumbs Up [tup]
Feldmarschall: Glad to see you went ahead with the He-111 as well. I had added it earlier I believe. Anything else you want to add to this GB would be fine as well. Both the He-111 and Ju-88 look great. Keep up the good work!
Neu: I am also glad to see you went ahead and joined as well. Nice work on the Tempest! I like the NMF look on it. Looking forward to seeing it weathered.
Mike: The Me-309 looks sweet! I love the way it turned out. The finish looks great. Thumbs Up [tup]
Bish: Great job on the Mistel! Looks awesome. I am glad you stuck around and finished it even in my absence and you still made it on time now that the date was extended. Very nice job for your first aircraft in seven years. And I know what you mean about over commitment. Since I haven't been able to build at all during the summer months, I am WAAAY behind in my GBs. Great work again! Thumbs Up [tup]
As for me, due to my hectic summer, I have had very little build time. I have managed to paint, clear coat, decal, and another clear coat my 109K-4 though. Hopefully I will have it done shortly and have pics up. I also just barely started my King Tiger II: running gear and turret. It should be done by the end of the year though. I am going to have to pick and choose what builds I do now though as I am over committed on my GBs and will probably have to drop out of some. But, I will try my hardest to finish my other two builds for this one.
Thanks to all of you who kept this GB going. I should be back now to checking things pretty regularly. And keep up the good work everyone!
The only easy day was yesterday - U.S. Navy Seals
Posted by Bish on Monday, September 28, 2009 5:36 PM
Nice to see you. I wasn't sure if the build was extended or not, i thoguth i would post the pics here anyway. I was just about to finish when i got a short notice trip to california for 5 weeks. So can i assume i am good to collect my badge
Edit: just seen the extension. Hopefully i can get the dio done in a couple of weeks, will post pics then to as it will be really finished.
    September 2008
Posted by WarHammer25 on Monday, September 28, 2009 5:44 PM
Looking forward to seeing the finished dio Bish! You are more than welcome to collect the badge anytime. And thanks for the welcome.
    September 2008
Posted by WarHammer25 on Tuesday, October 13, 2009 12:52 PM
Alright, the Bf-109K-4 is now finished. All in all a very nice build (even if it was drawn out) and I am very happy with the results. Mostly OOB excpet for some Eduard belts and EagleCal decals for "Black 15" of IV./JG-53 stationed in Schleissheim, Germany. Questions and comments are welcome.
    February 2006
Posted by DantheMan85 on Monday, November 2, 2009 4:46 PM
Very nice Bf-109K WarHammer! Thumbs Up [tup]
Up Coming: ?
    May 2005
Posted by deeve on Tuesday, November 3, 2009 11:52 PM
I just wanted to post an update on my Hasegawa 1/32 me163B build.
I basically took the summer off from building and have gotten back for the season. Continued on and have now completed the build of the engine, wired it up and added some detail. Primed the rest and preshaded. All I need to do now is paint and decal and we are done. No pics at the momment, but I should add some later.
I am so far pretty pleased with my work. The engine has turned out pretty good considering it is my first attempt at detailing with wiring and whatnot.
Oh, one other thing I had to do is scratch build a revi-b gunsite due to me losing the kit's. I think my scratchbuilt one is better :)
I almost forgot to add. Thanks to whoever extended the finish date :) I was a little worried about getting it done on time, then realised it had already passed! Next time I look, its been extended! W00t!
Deeve
    May 2005
Posted by deeve on Monday, November 9, 2009 12:12 AM
Here are some pics of my ME163.
I wired up some detail on the HWK-509-a motor. I freehanded the mottling and the camo on the wings using a Iwata HP-BC. So far this has been a decent build. Just taken a long time. :)
 A shot of the camouflage
 The underside, I did some preshading.
 The plumbing on the motor. I used some wire solder and tin wire.
The dolly, tail and motor. I am going to weather the dolly and wheel some more.
Anyways, Should be done this sucker in a few days. Just some touch ups, clearcoats, decals and done.
Deeve
    May 2005
Posted by deeve on Wednesday, November 25, 2009 9:26 AM
Finally finished my ME163b.
Finished it up last night at around 2am.
I scratchbuilt a jackstand to hold the tail up off the ground when the tail is off the plane.
 I will post some pics as soon as I am able. I didnt have time last night as it was pretty late and I was quite tired :)
Deeve
    May 2005
Posted by deeve on Wednesday, November 25, 2009 7:55 PM
It is done, here are the pics.
I scratchbuilt the jackstand, the revi gunsite, the antenna and the pitot tube.
Anyways, here are some shots of it.
Thanks again, I am glad I had a chance to finally complete this kit. This was one of the first kits I bought when i got back into the hobby in 2005.
Deeve
    February 2006
Posted by DantheMan85 on Friday, November 27, 2009 11:04 AM
Very Nice Deeve! Thumbs Up [tup] The detail looks great.
Up Coming: ?
    May 2005
Posted by deeve on Friday, November 27, 2009 11:32 AM
Thanks, I spent a fair amount of time detailing the engine.
hows that JU88 coming along? Just curious as I have the kit. Is there any issues?
Deeve
    February 2006
Posted by DantheMan85 on Friday, November 27, 2009 4:31 PM
I would say theres a few small fit problems, nothing major.  I'm used Welders Glue on the main body joint, that stuff's strong when it drys.  I'll post pictures later on what has stopped me.
Up Coming: ?
    February 2006
Posted by DantheMan85 on Saturday, November 28, 2009 6:27 PM
Heres the fit problem I have, on the Ju-88
And front of the canopy doesn't match up with the main body in the front. There's a small gap.
And here's my He-111
Up Coming: ?
    May 2005
Posted by deeve on Sunday, November 29, 2009 12:16 PM
Zoinks.
Now I am scared. I submitted both those kits for the In My Stash IV group build :)
I am kind surprized by the fit on the JU88. A little dissapointed considering the cost of the kit!
Deeve
