Tom, thanks for the kind words. Scribibg is actually quite simple, it just requires practise.
The Meteor is looking great, sorry to hear about the missing parts.
For CA I use Zap Super Thin.
Warhammer, thanks for the encouragement.
Rbaer, the Pershing looks top notch.
Progress from me this week.....
Seeing as this is a Luft late 45/46 machine I decided to go with an RLM 84 finish for the undersides.
I used Tamiya Sky, with Gunze Sky for the lightened panel centres as there is quite a difference in shade between the two brands. It may look overstated, but I usually undercook the contrast, not this time!
Next up was the RLM 82.
Like most Gunze acrylics, these come up slightly glossy, which really highlighted the fact that I hadn't properly hidden the top seam!
I ended up scraping the top seam and sanding again. You can see the grey primer down the spine on non 82 sections here.
Like the 84, I lightened all the panel centres, with 84 and a touch of Sky.
I did think about free handing the RLM 83, but wanted a factory finish for the bulk of the airframe, so masked up with good old Tamiya tape.
Is it just me, or does it look a bit like the Jamaican flag? Note beverage in back ground,Non-alcoholic obviously!
The Gunze 83 has come out looking more like 81, which is weird as I have used it before and it looked right. Think I might have mixed up a batch of 81, and stuck it in the wrong jar, not that it matters with this build.
Karl
