Well it looks like were off. I'll get started on my project tonight. here's some tips fo late war 109's. G-10/K-4 did not have much if any stenciling. Fuel markers were about it. If fact many 109's the wing walk and other stenciling were usually either worn off, painted over or never there. For those of you building hasegawa 1/48 scale kits, don't forget you need to scribe a additional panel line on the upper wing surface and for those building the K there is a vent in the center of the lower wing assembly under the fuselage. This will need to be removed. The K had totally different wing from the G.
For those building G-10's and want accuracy, check your references. Kit maufactures can't tell the difference between a G-10, G-14/AS or a mitt reg 130 block G-10. Hasegawa has G-10 kits out with marking for all the above. I have them If you want to know or confirm what you have.
Wing nut Yellow 11 looks good, you catptured the rough look of the temp winter camo very well on yellow 13.
Espins That looks real nice. I plan no doing that in 1/24 scale trumpy kit. I hope I can pull it off. You did a great job marbling the temp white paint. The only 2 things I see is the canopy should be the base color as these were usually not painted in the temp white and the stenciling would have been under the white.
mike and frank both of you are way too talented for your own good.
I can't remember any others right now.
