Lancair IV wrote: | raptordriver wrote: | Randy, you said you foiled a whole wing with the T-bolt, but did only one panel at a time with the mustang. Why? |
Hey Raptordriver....The B-24 I posted pictures of was done 1 panel at a time. This was done to show different panels of the aluminum. By rotating the BMF grain during the application, it gives the appearance of real life panels. I also burnished some panels and polished others as I went. Pictures really don't do her justice. Hope this helps. Cheers |
Hey Raptordriver Lancaire has one of the reasons I did one panel at a time,actually was a nice side effect I discovered. I had HUGE trouble foiling around compound curves, wrinkles, air bubbles and such, on the P-47 almost drove me to drinking. Foil will streach a bit but ya cant shrink it. Doing it one panel at a time solved that, especially on a P-51 with all its compound curves, it was a breeze compaired to the 47. To be honest the only problem I had on the P-51 was at the wingroot I ended up using a narrow piece about 1/4 inch wide to make that work. Also as Lancaire said turning the grain differant directions really made it look real. Wish I could take better pictures to show it. Oh one more thing I found if I started the foil at the smallest part on a curve and worked it to the larger part it came out with little trouble. Hope this answers your question |
