Boy, work for a whole day and look what happens in here.... posts by the bucket !!!!
Mike - the 76mm guns from Italeri should be replaced with AM barrels for accuracy reasons, the 17 pounder barrels from Academy aren't the greatest, any 75mm barrels that I've seen are quite workable.
Chris - the early runs of the M7 were based on the M3 but after the M4 came on line the M7 started to use M4 parts instead as standard equipment. The Italeri kit is based on the later M4 improvements.
Domi - indeed the Sherman did start out with many of the parts from the M3 Lee / Grant series of tanks. I've always considered them to be part of the family so to speak. Anyone have any complaints about the M3 being included ??????
Beav - the Ram in question is a mountain goat that the tank was names after. The Germans were the only ones that came up with a ram tank that hit things, but I beleive they even gave up on that concept.
To add to the Sexton, it was similar to the M7 Priest except that it had a slightly different configuration both externally and internally and carried the 25 pounder instead of the 105.
Mark - not only was the M7 used, but also the Ram tank was converted to Kangaroo configuration too.
Happy Modelling and God Bless
Robert
