Frank , Still undecided about the ailerons, the elevators and the rudder, but I had to do the slats and flaps. That IMO is one of the interesting features of this aircraft and the Me 109. Just wish the guys there at Tamiya would've worked it into this kit as well as they did in their older Emil offering.
Anyway, I just finished up seperating the slats and flaps. The tools that were used:
1)a #2 Xacto(with a NEW blade)
2) a pair of duckbill pliers(helps make a clean break)
3) a piece of 1500 wet/dry sanding paper(for the topside sanding)
4) water(to sand with)
5) a sanding block(helps keep things square)
6) patience(keeps the quarters out of the swear jar).
This is how I cut panels
Starting in one corner of the flaps hinge line, gently follow the seam with the knife, stopping just short of the opposite corner. Make several light passes allowing the knife to cut, not shear. Once you've got a good line to follow(usually indicated by ridges), reverse the cut, by starting in the opposite corner. Work slowly with an even drawing motion of the knife. If you do have a slip, Stop, and reverse direction with several light passes in order to get the groove thing working for ya again. Once you've made several dozen passes in both directions along the length, switch to cutting the perpedicular lines starting in the corner and following thru to the edge. Make several passes on these lines until your all the way thru. Check the reverse side to see how close to being cut thru the flap is, usually the plastic will become a lighter color as it gets thinner. After your satisfied that the flap can be "snapped" out along it's hinge line, use the duckbill pliers and work along the length of the flaps hinge line until it either snaps or gently works loose.
*NOTE: Please be careful when working with Xacto knifes, they are SHARP. Don't scratch your nose with the same hand that your holding one in.
Moving along, The cutout area will have a slightly raised edge from the knife...
that can easily be taken care of with a little careful wet sanding, and the corners squared up again with a little care and the Xacto knife, if needed.
This being the upper surface I wanted to knock these out of the way first. Fortunately for me the flaps aren't built like the ones on the F4F, but on the other hand the Wildcat didn't have slats.
Mobious
