Never one to disappoint....
The Cutting Edge decals went on really well, as did the markings from the Trumpy sheet.
Overall not particularly impressed with the CE decal set, as the
instructions were very poor, with no top side view of the camo scheme,
and the side view showing a green on the fuselage that didn't even
feature in the colour key!
You can see that the yellow line decal isn't quite long enough, so I feel a little masking and painting coming on to cure that.
All the stencils came from the Trump sheet as the CE set has only the bare minimum markings for this bird.
A quick view of the underside..
You can see the built up mount in the nearest engine nacelle to which the engine attaches.
I need to touch in the nose band, as you can see in this shot.
I've ditched the kit wheels & tyres, and opted for a really nice resin set from Mastercasters instead.
Just check out the detail on the hubs...
Most of the above was done last week, so I spent the weekend sorting out the under carriage, a job I wasn't looking forward to, however I got stuck in....
I drilled the pivots for the torque links, as well as adding the brake lines, and the hydraulic lines for the retraction cylinders.
I did the same on the nose gear, and did my usual building the gear as a complete assemble and test fitting before painting. I find this saves tears further down the line.
One key element missing from the Trump part is the prominent weld seam, so I've added one in with strip styrene softened with solvent, and worked over with a scalpel blade. Now it just needs sanding down a little.
I also removed the upper torque link bracket, and modified the lower bracket by drilling it out and making a notch.
Next step will be cleaning up the resin wheels, and prepping the under cart for paint.
Karl
